Home » Eclipse Projects » Remote Application Platform (RAP) » Closing Dialog with ESC key
Closing Dialog with ESC key [message #26841] Wed, 23 May 2007 06:29 Go to next message
Hi all, Can I avoid dialog closing when ESC key is pressed ?
I'm using org.eclipse.swt.widgets.Dialog as parent class for my Dialogs
and in Login Dialog I would like to prevent dialog closing when user
press [ESC] key.
I've tryed to use a callback function in close() method but It doesn't
work, close() method is never called.
My LoginDialog is created without icons:
SWT.APPLICATION_MODAL + SWT.TITLE
Any idea ?
Thanks in advance.
Roberto
Re: Closing Dialog with ESC key [message #26881 is a reply to message #26841] Wed, 23 May 2007 09:06 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Roberto,
> press [ESC] key.
In SWT, a dialog shell (i.e. every Shell that has another Shell as its
parent), can always be closed with the ESC key.
You can prevent a Shell from closing if you register a ShellListener and
set the doit flag to false. Unfortunately, this is not yet supported by
RAP but we plan to implement the doit flag until the M5 milestone [1].
As a workaround, you could either consider to use a top-level Shell for
your login dialog or to bring the login dialog back to front in the
dialog callback.
Hope this helps,
Ralf
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=187258
Re: Closing Dialog with ESC key [message #26960 is a reply to message #26881] Wed, 23 May 2007 09:50 Go to previous message
Hi Ralf, Thank you, It works fine creating a Shell without parent, But I
had to change my Dialog parent class because
org.eclipse.swt.widgets.Dialog doesn't allow null Shell in constructor.
In any case it was easy, I was already using my own DialogBase that
extended from org.eclipse.swt.widgets.Dialog and now It extends from
Object and implements all methods I need from Dialog RAP class.
Regards.
Roberto.
Ralf Sternberg escribió:
> Hi Roberto,
>> Dialogs and in Login Dialog I would like to prevent dialog closing
>> when user press [ESC] key.
> dialog callback.
> Hope this helps,
> Ralf
Previous Topic:How does RAP team automate test RAP ?
Next Topic:How to Center a Button
Current Time: Sat Aug 02 14:16:48 EDT 2025
Powered by FUDForum. Page generated in 0.03192 seconds
