Home » Archived » Memory Analyzer (MAT) » OQL Preferences
OQL Preferences [message #2269] Mon, 30 June 2008 13:07 Go to next message
Originally posted by: slto.yahoo.com
In the OQL results window, by default it displays 25 rows at a time. Is
this configurable? I would like to export the entire result set to a
txt, right now it seems to export only the displayed rows so I have to
manually expand many times to see all the rows before I can export
Re: OQL Preferences [message #2299 is a reply to message #2269] Tue, 01 July 2008 02:25 Go to previous messageGo to next message
Found the Expand All option, so that solves my problem
Re: OQL Preferences [message #2328 is a reply to message #2299] Tue, 01 July 2008 04:50 Go to previous message
you can also export as CSV (which will always export the whole table).
Select the Export button in the tool bar and select CSV. This might be
easier to work with later.
Andreas.
Previous Topic:finding the size of a single object (& more)
Next Topic:Unsupported segment type 254 at position 366,014,124
Current Time: Sun Aug 31 09:04:19 EDT 2025
Powered by FUDForum. Page generated in 0.05037 seconds
