Home » Newcomers » Newcomers » Eclipse won't start up
Eclipse won't start up [message #270939] Wed, 20 May 2009 05:26 Go to next message
I've been using eclipse for for some time now (over a year) and have
finally gotten into a situation where the work-arounds I know won't work
after a crash.
- tried ./eclipse -clean
- tried a completely new download and install
I was working on some java files (java perspective) for several hours
and eclipse crashed.. thereafter I could not get it started again.
There is a workspace that I use for php projects... that one is the only
one that works fine.
If I try to create a new workspace or try to use a newly downloaded
version of eclipse, it crashes with a message:
An error has occurred. See the log file
/home/rgeddes/workspace-j/.metadata/.log.
here's what I'm seeing in the .log file...
!SESSION 2009-05-20 04:11:37.229
eclipse.buildId=M20090211-1700
java.version=1.6.0_13
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64 -clean
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2009-05-20 04:12:18.027
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.JSPJa vaHyperlinkDetector'
extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the 'or
g.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
will be ignored because it contains invalid attributes.
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2009-05-20 04:12:18.028
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector'
he 'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension
point will be ignored because it contains invalid attributes.
!ENTRY org.eclipse.osgi 4 0 2009-05-20 04:12:22.367
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: XPCOM error -2147467262
at org.eclipse.swt.browser.Mozilla.error(Mozilla.java:1638)
at org.eclipse.swt.browser.Mozilla.setText(Mozilla.java:1861)
at org.eclipse.swt.browser.Browser.setText(Browser.java:737)
org.eclipse.jdt.internal.ui.infoviews.JavadocView.doSetInput (JavadocView.java:928)
org.eclipse.jdt.internal.ui.infoviews.JavadocView.refresh(Ja vadocView.java:776)
org.eclipse.jdt.internal.ui.infoviews.JavadocView.setBackgro und(JavadocView.java:763)
org.eclipse.jdt.internal.ui.infoviews.AbstractInfoView.initi talizeColors(AbstractInfoView.java:363)
org.eclipse.jdt.internal.ui.infoviews.AbstractInfoView.creat ePartControl(AbstractInfoView.java:226)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:371)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:230)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 6)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:53 1)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:668)
org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:576)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:568)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:271)
org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:968)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2593)
org.eclipse.ui.internal.WorkbenchWindow$25.run(WorkbenchWind ow.java:2873)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2854)
org.eclipse.ui.internal.WorkbenchWindow$19.runWithException( WorkbenchWindow.java:2171)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1363)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2295)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Really need some advise on this one
Richard
Re: Eclipse won't start up [message #270941 is a reply to message #270939] Wed, 20 May 2009 06:46 Go to previous message
I think I just resolved my problem:
I discovered that I had 2 versions of xulrunner on my system:
xulrunner-1.9.0.10
xulrunner-1.9.1~b4 (I think this is a beta)
I removed the 1.9.1~b4 version
don't know how it got in there... but getting rid of it seems to get me
back into my java workspaces and back on track.
After finding many reported problems with xulrunner and eclipse, is
there an alternative to using xulrunner in eclipse?
Also, I found a suggestion that says that this option:
-Dorg.eclipse.swt.browser.XULRunnerPath=<path to xulrunner>
will force eclipse to use a specific xulrunner. That did not work for
me... did I make a mistake on this?
Richard
Richard Geddes wrote:
> Hello,
> after a crash.
> and eclipse crashed.. thereafter I could not get it started again. There
> is a workspace that I use for php projects... that one is the only one
> that works fine.
> !MESSAGE The
> !MESSAGE The
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> Richard
Previous Topic:Remove all breakpoints
Next Topic:Can not switch workspaces with Eclipse 3.5 Galileo RC1
Current Time: Sun Aug 31 14:18:28 EDT 2025
Powered by FUDForum. Page generated in 0.36134 seconds
