Home » Eclipse Projects » Nebula » PGroup not redrawn correctly
PGroup not redrawn correctly [message #26815] Tue, 06 February 2007 07:04 Go to next message
--------------000603010104030201080700
I have the problem that I put a Table in a PGroup and when the widget is
opened the there are some strange scrollbar pieces left. When forcing
the PGroup to repaint e.g. by moving another window above the control
these pieces are removed. Maybe this also a problem because this PGroup
is a subcompontent of a PShelf?
Tom
Content-Type: image/png;
name="problem.png"
Content-Disposition: inline;
filename="problem.png"
iVBORw0KGgoAAAANSUhEUgAAANcAAACWCAIAAADCG4orAAAACXBIWXMAAAsT AAALEwEAmpwY
AAAAB3RJTUUH1wIGCzY21rdhhgAAHsdJREFUeNrtXXl4FMW2/1V3z2SbrCSs SQwm7CAIqKgo
GHFHvXmy3St8guJ9KshD9utyjSKSQLwXEXnqE3c/UfweoF5EH5sKirIIXpUg RAIBiRCyTsgs
XXXeHz0zmWQmZDKZJELq9/U3X0/1qe6aU785VafqdBUjIkhItCkUqQIJyUIJ CWgNXbh2pVSO
RIjx5UP+05lvv/DqF2RPUaIFseNh1ggLhy0TUk0SLY2dM5UGWXjZc7pUkETr YNdszX+/kHPZ
Fku0AWpt4cDFDqkOieZj/9/MAXJp/9/M9W0h14PqEQ4w/fgnFb84+7/PG0kM GOPHhz/REzvW
2f7z322jxzYvwPmLH58IN+jVf6Et8Fxag83xQPOBLLX2a4n+lxXO731vYGQi qpPdb2LAoNrs
jYnWLWTRDtuN/6e8mm2+GvzpbMd7waqyCQWQ8MKB7AgAfbJrDmRH/PhEeJ/s mmazUBAA5Dt6
vntOl8UQo7rZ/SYGDCM3RGMkGGT+JUv1KaHhfJHgFDSFAi2AhBd+WRgJoOcT Z43PXxZGHsiO
ML42iYV1W2Thrk3v9EvDC8a6s5Q4xv3Dsce4mKhtXmhOqZdo5PXNYqSUiKJE pTYLMHGS5ak+
XgZJCM79PdEtMCRJAVB0Svcu4cRJ5qsBQMteqGVDf3INnhqr4YAt/W3duP/2 NdZ70LwCNFD+
do70R63GScGzlvRHrZ6vgaB22EZwqnMY9qBPeMGzloJnLdtuYqKTedtYreiL 6u7zq7p/oCPR
/NxNzCUGfdb8qr8fABLNMwa584KakGVQ+FN9gAM13Y1EANRAdncJdxULACnX RtaWkNNbb9Rs
BwD97/Orus+vectTEu72woiaWwC/2bk8SHAqeNZiEDEQ4UBaZADAzzWprzmN hMtHR6QAGBF1
ZIRLJCVJ4ScBAKf4t5x6G+2wcDeFhCEDtQCzTLxEA/DVfifnrm4ZCfKf3dNM fnc29TvTu3kR
1xiXRkQdSapJfc3dKTVaZJdVBudE9YoXdAH8/mTZdgPH8mIApM6pPJYXcyQ3 OnVOZRD9wjot
sstieLXIQhCAY1uqrvy4VuV0meYRc1ee0OE+CziL58SLBP6z14V9wiN2AJQc vnN2eGoSG+r6
MxFxwev+Ct/iBVcAv+WXLDzxzzgA3R4pNz5P/DPuWF6M8bUZ3gnV9zC+PskB NTUzbPK66lX+
xDyupXBVcxOy/FTM0U9N66Rwzj2J/rP7RWclFcDv/GuOmS4WEvc8K0m9nDt8 ixdkAfyVX7Kw
84yyc3wN2kd2qbw2/WtrUlHEngURi5abFxkWeFPFkJO1YoS6TR6IB5xl+/9a Xx8QO+X6mOLr
a40x3+kv+1rX7e9/MOHZ/l7NgftS3qbwa0eZFy03L4Lj0Wk1r99gntIxfO3y cPgWL7gC+P3J
skVuBmrnThL+s0SqQ6I1UfpyYmO2UEKitSBZKPHHYqGMLJSQtlBCslCyUKLt WShkiyzR5iwE
QGuSpUYkWgds7HHPuXwfWaLtIVkoIVkoIXGOtRkAZL/2uVSQRKiQfe+NwbDw 3DklJJpAwXNa
NK3R/CWnD0slSnigqpGxcUmKYgpQvqz0t/iErsG3yBIS/p0JxXSyjJ+qgMPO HQ6hC3ABQYIL
RkRCKIKELmhAd1N6F3NFtR6fAMlCidDjVAXioxR7mOJwCk6MOAnBdDcXOYfD KQqK7OldzOXV
jS87I1koEQwcdm4PUwQXnDPOoQtGRDoHBOOAzgECUxmAUiuXLJRoGRbqwrCC OiedAwBxsjsZ
F65V4RiDQgTAWuNsvImXCpUIioVM18E5uGAkiAQtylvi6heSICJBLmrV2Kll WTiuY49x755w
fSn6YNz4D4pk/bQPkCAuQJyIiCls0dIlAJa/kEMgAUYggvu1bd7CLMR1U/t+ 9Pg7knrtD05O
OgcXjIE9k5vrSV+xYgkxEmAABDEYfcQWbpG73zej9yOrvvVOKnp3SlLHHkkd eyR1nPJOkWEj
c7PH90jq2CN7x4l3XCdu8+ktKXEe2UKj6RViYW6OkTJn1jzj5L9fWEKMOOAx hy3fL7x6/lpM
dLEKAJBy9+unTx06ferQ6bVugm7Nz8g7dHrt1BezHodxsvyDInybPeTIDENy zy0fzZGt+fkE
LhgnV0MMYMGc+UxhM72JCDKWIgyEiyHwTobft+jn5V4c8li4rFdx4GgRgOtu GZECpHa/znMC
oOjoz3g1y5Ac8tjWrUeOyro9j1hI4AIL5s4HsGDufKMJ5ozdP2MegPtnzNMF PA5Kq4zUpIx7
7o4pq768xUXBIZ/esefQBylA0Qfj5py7W7lo7/vjUmSVnofQdVeHb96sBZwI LneEmTT215nz
ddeqFYFG74dmpCbl7gfwyGNbXdy6ZUQKABR9+enWc+W5qO/Wx1btkBV6vvYL dQ6dQ5DQdeg6
dAFOMEZtIEBECHi9ilCNF16RvXaqYRdn9HlscMceSR17zD7U+7pzZ9mz6Oes Hi5XRo7ynFcQ
QnDBnYKcOgkuOOe6DnKQrkPoQhijiCAADKxlW+QP3h/n7aacvhoAUrIPnc6u J+ZquP2cnBon
a/R8xKXppsNFNhKMu0lGIE4qAxQQE0SC+lykAYiJUlulXyjRzrD9p+Lh/Tpn JIc1Krl2x28j
B8RKFkqEHn1TLGu+OHaqwmY9S07udOiMkTDcZMZcptGkKQmWsAmZXeEsDQEL a6yVUu8SHlhi
I+MsYWNHpAYoX9Y4CQNgodVaLVUv4cVCP1GugCvQFQAXzKmTJ8rV7hAhYGF1 df3NAhxOZ3lZ
RUVlVWVlldVa7XC4NvphjIExEAlBuq5rmsYYmKKQEBeGAGPMZDLFxFji4mIT 4uMslihVVdsn
F/cftsdbzFAUTVMUKIBrmAaATUBVSSUUnLCldzFv3Fs2+dbk5rJw6LCbvL9W VFR8/fXXa9Zu
+vzzz4uLi42hI89VxlzLchKRoihCCEVRLiQBxpiqqunp6VlZWXfddVe/fv3C w8PbFf/KSn+D
ewZPFQT3HJ0CcPe4HxdMIRH4ZmJN807sdvuaNWuefvrpoiL/o3vedSmE8Hxe MAJEJITIz89f
vHjxd9999/jjjw8fPlzTpJPXLDRNffv378/Ly2uIgu0NmzdvTk5Ovuiii7p3 797ueKNCU8Gg
CAjGmdEvJGPKjjNNQAFjCmsRFn744YenT5+W/PNg165du3fvbm8s/J8NBfff mu7+5j39Vm8q
Tlvz1Yk7h3UIMQv37NlTWSkHbmpRWFhYWFjY3n71XcM7vbjul7Jqh8PJ/AZu KYoSpiLWEh6y
8cK6ozZWLvdUqNtRttls7e1Xm2GfnNkBisIMKKrCGJiqKAxggOuKIVwewL4n TYtmSElJMZvN
knwexMfHJyQkSD00E01jYWZmZmxsrNSaB3369Ondu7fUQ6uy8M4777z00ku1 gH2fCxuxsbGZ
mZmDBw+WqmhVFnbr1u2ppx7olUARMR3a7bQBAMbUTl273nvvvZMmTYqPj5c0 aiaaPNx6Racz
Sf2Xjh8buWvjxvz8/KqqMxXFVUq02WGDJSZcUxTXMK9eU12jREWhuppFRZuZ e+JBIUd5FVks
sJZZvd7ZN0XVvYOwV5ZZYYkNs1fUEbPEhDlsLCrarBgjyc7qMitFJ8SZmb36 TI0aFx2uMsVV
BlFTWXbWldlsiY82MwKg15RW1sBkiY8xOSs9ZTBHx0ebGbdVVbvKYLeerqwB AHNEBOlqdDSr
qqKoaHOYyZQQrVScTXvyxXljR4yQFGwbFiLtvq1GIP9DD/2Bfse2uexft9HS kbJGL/wW+Q+L
woIf59wmKXjh2sIzpw7+8X9G9O3LFuDgmVOyQlvebmnRbcDCDh17nV+MlLiQ +4VlZWUbPt20
8bMtP/zwc2lZucPhFJwDECRURSUiIwiPiBRVjY62ZKSnDRrY/+KLLzKbzUTC 6dRNJg2MKUwx
wiEBMDAjjOo8FWBgYWHmuNiYDokJiYkdYqKjNU2VrGopFhYUFLz44ovvv/9e SUmpJ6z1XO34
mdLCwmObNn/pmcm5oCMOlbS01NtuHXX7bTf17p0RFhYmiRV6FpaVlb399tuv v/56eXl5Ux/Q
TiIODx36ddnzr+zd++/Zsx684vIh0iKGnoV79+7dsmVLEBRsb/jyq2+6du2U nNz1olS5o2Co
R2ry8/MPHDgglRUIVr+/bshloxI7TZVr4YWYhaWlpWVlZVJZgSAiIjz773NL 1vac+dp3Uhuh
ZGF4eLjscQcIW40t++mliVmv4cAxaQ1DycK0tLS0tDSprEAQGRefu/iJkt3P XCd1EVoWDh06
9LLLLpPKCgS9eqf36HFx0Vcbt0pdhJaFKSkpkydPHjVqlNRXI4bQjL07d//H mCmzDvWUtjBw
BDRSo2nasGHDcnJy3nt31acbNx8+fIQLQUR+B3K9h9baD0wmrUOHhKw7b73v 3r+kpaVKYoWe
hYaDMnDgwBjLPWPH3FFeUVleXmGz2XVd953Uqjlr+/VI4Y8/HSwsPGa1Vus6 b2iiDwBjzLM6
RysL6LZKO4uK0Jr7CM2kxcfFDRrUf/RtN1x15eVxcTGSVaFnoXcEQ0J8XEJ8 nNSaRGuz0Dum
RkLCWKembVrk2kKUlX3xxRcfffTR3r17z5w543A4jDeUhRCqqnr6iJ62TPG8 A9AOBBRFCQ8P
v/jiizMzM+++++709HTJ2tCz0IisWbNmzenTp+12u1SfXxw/fnzfvn2rV69e tmzZjTfeKBUS
mpEajxU0ImuOHz8uKXgOEFFFRcWBAwceeOCBgoICqZBQslBG1jQVR44cWbVq ldRDKFkoI2uC
wNq1a6USQslCGVkTBGSLHGIWysiaIBAXJ4dXQ8pCGVkTBEaOHCmVEEoWysia IPDggw9KJYSS
ha7Imqv7Sq0FiMWLF1955ZVSD42iCaPWrsia599at27d+vXrDx48yDlvKLLG k6vlX9MkgsLw
h3hVlDEmhIiNjR0+fPjkyZOvv/769rAPBfv1iLriRWbsi2Ox0H/NQEZ6S7EQ 7siatLS0iRMn
lpWVlZWV1dTU6LouhHA6nSaTyXuyy6gbo3paTqBka85nnR+d2JfasAweAVVV IyMjO3bsmJSU
1LFjxwuHgmfOYN8+LFiAkpJYwQH3S+buhSzZ0WMeWdqwAVdcgXfeQsBrCwa5 Tk1iPBLj44E/
wLpp162e8Eest5rqyqPV5/tC9JyHv/Zu2Mefad/uCbwPxwqPovAo9e+PBfMC JKJcp0bCDyLy
Vph2fAfA9HXAbxIaht+91jx74u/4vZgWPxv6Fvnkyd8/3bh585avDh3+1Wqt 1p16mwerXuAC
qmY2m5K7dbniiiF33H5T/369W3p1e23v/siFz9Ujn+jaWfmt2HHDSMftNzM1 XFU05u6IuLoj
jNHVwxWFsTffVp5d7Mq2YiV74y3TS8tx95SQsfDbb7999G+P7dv3Y0Vlldxv ojVRXHzqQP6h
jZ9tmfbQvXfefnNMTIjXblNOn4l65DEt/xAApehEvauOW0ZZly8m90MVLdqk hdXuJ+G10wQp
jJ7KRmIi++gjtu0LALBaLZP/Cl0BuoSAhSdOnHjyySe//OobXZf8a20QkdVa ffjwkbznVnbp
3Onaa4aF0CJGLHspcvEy33T7hCz7mDsoKlIfPLBJNxQPT1em3stuvBk7vwUA XcfMmb0nzgRu
bO544fr167///ntJwbbFiRMnP/nk85KS0lDdMOrRhWGr/9fX+FVsWWd9frHz miubSkH3faPo
/z7DqOtdX8vLx61ciDffbC4Lt2zZUlFRIXnQ5ti6fWdllTUk/m/EspfCV72r HnENslBCfNUr
/yj/9vOqN1bo/c61iUukJSYqpkOUJT4yKi4iMjY83GIOizKbwzUtTNPMmmZW FBOzxGLdegwd
6uKZ4MjJQQMduUBb5KKiokCWLZRo8T7ibyedza6IsPfXRbzwinroVxf/YmOs yxc7bhgZ4MCK
717xxkbxXBijqoog4dorftu2mptvjti+HQDy8zFxIt55x/cpgbLQYrGoqqrr uuRB28ISFaU2
cztmzr0paPvrPWf/NpMiI5p0j1MViI9S7GGKwyk4MeIkBNPdXOQcDqcoKLKn X245NntBr+2j
XdlWrwaA994LskUeMmRITIx807btkXZJP4slqlnuyMrXPBTUB/UPgoIAHHZu 1yG44JxxJxw6
c3Jy6sSdjHPoHCAwlQE4kdwTK1bU5ly9Gvv3B8nCMWPGJCUlSRK0OXoOvymx Q/D7P6qFx8I+
/MhDwcq1bwdBQQAOXTicws6ZzslpRBNwsjtx1snsTsYFA4MCAmCtcWLatC1Z k2szjxqFgweD
YeHAgQPnzJnTrVsXyYM2RLer73xi3MiIiOCnp6PvmabmH3K1xfdMCI6CABw6 03VwDi4YCSJB
YHD1C0kQkSAXtWrsBODL0X+utYglJZgwIRgWhoWFjR079rmlT/15Qlbnzh0V RVE8g5bGyKX7
KwBFUYzP807AAwCez6AE0JBAUwvJGIuMjLjqqsvylmR/uuKRzp07ehasbyrM 6zd4KGhdnmP/
y5ig2UyCuABxWpiTwxTGFFZlUwQJAq1YsYRAnt27de6OPJo2DQsWuM737VOJ N9k7ARAbG3vt
NcO6p6VmZl7zww8///pr4emSUofDoeucMcY5V1WVhPAEQYExGHFQRH8oAcG5 w+msrj5bUVFZ
U+Nnj20jRsv49F8HjQvAV0BRlKSkDkMGXzL40ku6dOkEoNFdLcLCwqKiIhM7 JCR0iE/skBAR
ER40BdXDR6Ifmmuc2ydk2cf/qTlW2clJ53gmNxfAM7m5c2bNM5uo2on/fmEJ gBUrlkyfPk8Q
A1BniHn0aOTkGKcL8lcCuYGy0DuCobKy6rtd33/8yWff7/t3aWm5Z3GCCw+e aMIQCnDOi4tP
/WvDpqqq6tbfCiBi5WsGI0TXztULH22+fkjQY3PnLVq6BEDeP5bMmTXPoCCA Bx+exwkqfJQz
dCiGDsXu3QAyqo80wRZ6Ymqqq6u/2fDNypfeku+DNhNffvVN94t7Dhg4vHvX 7q30yB078O4a
l0m+d2pCxtCg72SsU8MF48QALJgzPycv1yCih4IACKQLGCfeHTsPC4eX7ALn xthhEyL+Dx48
uHbtWknBkGDXrl27d+9uveft3Fnrnz7+ePPvxwlcAAxgWDB3vif9/hnzdAad QRfwOCh14PZL
MqyFcGugCSz84Ycf9vuM9EgEh8LCwsLCwtYzhHl5rvOMDITidV5dh87BOQRn nDB3znwAD8+e
b9IYUxgncIKA8JNzxAh4Rt3dwYhN8E5OnjxZXFwsCRQS2O12m83WGk/iHNOn w6i4xERMnRqq
frPhdqiK4DoDMHPWPAeBBJEABIgIvGEK14UmCdEmiI+PT0hIaI0nvfEG9u1z nX/4IYYMCcld
hRBccGKKEAQQgYRQSJAOCCGEACNh9AgZfJx6TatHxCa0yF26dOncubMkUEjQ p0+f3r17t/hj
jh6tbYsBJIdsX7RL001w2shZw5127rQLp4McNdzpYE6Hwp0adyi6s0+qBiAm Sg2lLbzkkksG
Dhx49OhRyaFmIjY2NjMzc/DgwS3+pIkTkZ/vOn/1VYRoVc/tPxUP79c5I7nx /uXaHb+NHBDb
qC1sAgt79eqVlZV16NAh6SYHDZPJlJSUNH78+EmTJsXHt/wbjJ5l/h5/HPfd F6q79k2xrPni
2KkKm/UsObnToTNGQqB2PgmASVMSLGETMrvCWRoCW+i9jvFVVw2eNu2vH3/8 r71795eWlp7X
o9aeKTJNUzXNZDJpmqa13MLDmmaKj4+7dNDA0bffcvVVV8bFRbTEAtH1EB1u Niq44k+3ihA9
TuhV0Ksy+9T+sxqWdaLmqB8/OQhbGBuXpCiuJ8UndO3WLf3KK6/dt29ffn7+ 8ePHz549a0S/
6rquaRoREemA6vlPqKpqVIxHQNM07zjFlhD4rdSRFKMq7pECRVVIkLeAOcwc GRHRtVvXXj16
DLhkQM8eGZGRkRee6VUPudatM/9ewnv09BWItMR4KjcQlJX+pmjR8QldP9td Ex9tNmbwAMyZ
NQ+AZwYPwPTp85iw3zA06s0NP95za7NtoU9grcpZ39RBvVMHwU9sbRdzYdGx tJRUI8vJ03Yu
mGeaytdwcuEiaz2ZhtIbvaSpSO+sZCSHvbjul8mZHdp5B4BVV7tOABZQ5bqi pg1l+lZuRbUe
G6Uh6Bm85vQL/QbWEogLVj+2tou5vFr3ZLHVmDl5sVD4sJB8KCXoHOmNXtJU HC6qzkgOK6t2
QFHaOQtrK1thDWmjqZVrsDDIGbwGbGFA9eQ3sDb72Vy/sbWlVu7JAgUqIwZm HFBQ71AZGUc9
mYbSG73EwIxiOJxMonaWouH4M9/KffLZHKeTzlG5aM4MnmELg2GhT2Ct0SHI ycv1H1sLOBzC
4XRN4QgI44BA/cPT54XISGYComeyCoGeqSqAnqmqn7xeWXwvCQhjmJRAkoUe q8PQMAvrVu7C
nBwAi5YuaTBw2m3OgpzBC94W1g2s9fRJZzy8oKHYWl2AExNQOJjgiutA/YOD GYfgCoDt+RzA
9l+8PvN5vbzeWXwvGfdxqV5R2/lBvXp6phz8CvhW7mNz5xk5/vl8bkOVC/cM ns4hSOg6dB0z
Z83jrhk8amQGLzhb6AmsJSKjN2o4QUZsrQDzH1vb1lAYa+cHOrj8MyUi3L9A 3co1Umc87IqI
fmFFbkOVa8zgOQU5dRJccM51HeQgXYfQhTAY3dAMXnC20Ais5YJ5e+bhZnAG zkCMjBFL79ha
44dxAghcuA+qf8B9cNHg0+vl9c7ie6nOfZja3o/fT7k08eUO/wJelWt0sm1O MpuEMfICYOWK
XN/Kbe4Mno8tDMhHNtxyQh3PfKa7oACIUT3PXJAQgpEgroDc/QMm6v8tPO0n QQD+A4+N7oUn
b90sqHeJIDx/XEVhaN+g6zNZQQEAbc5c/Z5J/jtphv/hVpqmMA4szcv1OLwE 0okgyOPwNncG
L7h5ZAdnDs6MN+oXzJ2fszQXwLJ/LHl49nyb091R4MS54t8zb7vxsvbOwtmz 8Mr/AKBu3RrS
huHtepZLEMSW5uXUOryuyoXi5fA2dwYvuPFCwyEy2nhSaO6c+cZ/5YXnch+a NV8X0Lkxciy8
h6N1AZuRwFnjrOBs92EBYHeBALD7SO2n3cjO/GTxc1vOnKRCou48MisoYD// TH37Nlq5Hgo+
PHs+J/hWbghm8ILrF/p1iAA8NGt+Qz6RUyebg3ROdsP/4uAcOqd6h12HcRgC /VI0nVPfVNWu
o9dFml1HvxStXt56Wepd4hzGbJ7xqmo7P1iPDBjBeDab8vnnvgK+lfvIzPkA ZsxaEKjDGwSC
6xf6DWmcNmOucDQY1agLcjgFiCkkFLex8vWeFfcbkPVkGkpv9JJiFAQIUxH0 S5MXDuLiaPYs
NnceAHbiBPwpxLdyp8+Yx3VOgvmt3JaYRw7IFvp1iOCwncMnGtDdxJ12Vdig 25lwHaqw1Tug
242jnkxD6Y1eYsLe5yINQKwlXDbIANDbvSz5ipV4862QVK73PLLx1Zi+qzOP fA4PIQhbGLhD
5O0TpXcxp3cxt5Xm13x1YkJmV8lAALjtVgwaiH37oevs4f+iCeO9334KrnJD Po/cOAvP4RA1
5BOVlf5md4gjp+wHj59tfbV3ijWN6hcDZ2m53MAUAKA+nxd942hmt8NqrXnl Jfufx3lc4r4p
MU2tXF/P2jNscg63uhYFBb4+MsgNjCmiunhy1WckcWEgJ6d2vH/0aNL1Vn5+ LZemT68tyb59
RlojtjD7tc+lLbkAYI7pM89k1pwOAPjkk213Tdl2x8Q2KMfLL3tW7nrp4kkP DBzYuC2UuKDw
zDNe05+g6dNbuwC6TnFxrqdbLEOu3+C5okg70V7w2GPYtq3264oVaOWVNnJy at/G2rhxT/yA
po3USFwgGDEChw9jtHuV6VGjUFDQek8/fNh1Yqzc1dTxQokLB+nptYuElJRg +HB0746XX27x
5/70E955x3Xev3+9tXIkC9sf7rwTGRmu8+JiFBbigQeQlYUpU7B+fYs8cfNm zJxZOzrju8KH
d/dROijtBTt30ujRdZwVzzF0KG3aFDJ3ZOdOGjqUNK32/mPGkNVaj2mShe0Y mzbRG29QYqIf
LmZnU04OlZcHf3ObzQ/Rhw0jq9WXaazeO8Js7HFakyxbrXaEigq89BI2bsTO nai3mF1yMl59
FSNHorjYtf2xxYKSEiQn4/hxAAgPR2EhLBboumt2uKQEAObMQXl5rTtiSL76 Ku6+2y/HmO+b
6mzscQCSi+0OBQXYvh2TJ9dP951wayoWLMDUqUhPb4harKGFZowMEu0N9xxd M+b4hn1xfUee
/mZ4ya7m3Mqmhr2T+h9zLnmiwuTaW7kh08Yu1EX6JUKAKVPw4Yfo3x8//ojE RFitSE5Gfj4y
MlBcDKsVcXEoLkZcHOCOlLFaASAtDTk5uPlmxMYG8hzJQonmoboaUVEAXLvO Gj3LqKbt1CdZ
KNH2kKPWEpKFEhKShRJ/BPw/ZRbb3FCncksAAAAASUVORK5CYII=
--------------000603010104030201080700--
Re: PGroup not redrawn correctly [message #26856 is a reply to message #26815] Tue, 06 February 2007 11:02 Go to previous message
Hi Tom,
That cheese is actually a bug in SWT and/or Windows. I've seen it off
and on and never been able to pin down when/why it happens. I see it in
the IDE as often as anywhere else. I don't think this has anything to
do with PGroup or PShelf. If you can pin down the details of this,
perhaps you can submit a bug to SWT.
-Chris
Tom Schindl wrote:
> Tom
Re: PGroup not redrawn correctly [message #577439 is a reply to message #26815] Tue, 06 February 2007 11:02 Go to previous message
Hi Tom,
-Chris
Tom Schindl wrote:
> Tom
Previous Topic:PGroup not redrawn correctly
Next Topic:grid viewer vs table viewer
Current Time: Fri Oct 24 15:56:09 EDT 2025
Powered by FUDForum. Page generated in 0.03609 seconds
