Home » Eclipse Projects » Eclipse Platform » Problem logging in CVS via SSL (sf.net)
Problem logging in CVS via SSL (sf.net) [message #270616] Wed, 08 September 2004 11:01 Go to next message
Originally posted by: benjamion.cordes.sme.de
had a hard time today trying logging in the sourceforge CVS server via SSL.
Eclipse Version:
Version: 3.1.0
Build id: 200408122000
Platform: WinXP
SDK: 1.5 (beta)
First I tried with pserver: no problems with viewing, but I couldn't
commit anything because I don't have the add-right.
Tried following manuals and tips:
http://www.gnegg.ch/archives/eclipse_cvs_and_putty.html
http://krook.net/os/eclipse-cvs-setup.txt
http://www.stefanheimann.net/documentation/sf-cvs.php
A bug is reported here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=21180
No result.
I tried using PuTTy and Pageant:
1. Generated a public & private key.
2. Updated key in pageant.
3. Logged on to shell.sf.net with PuTTy.
4. Opened eclipse and connted with ext mode while giving the arguments
{host} -l {user}
I also tried {user}@{host} -pw Password
Also I tried using WinCVS and got the following:
cvs -z3 -d:ext:nnai@cvs.sourceforge.net:/cvsroot/myproject co myproject
***** CVS exited normally with code 1 *****
cvs checkout: warning: unrecognized response `The server's host key is
not cached in the registry. You
' from cvs server
cvs checkout: warning: unrecognized response `have no guarantee that the
server is the computer you
' from cvs server
cvs checkout: warning: unrecognized response `think it is.
' from cvs server
cvs checkout: warning: unrecognized response `The server's dss key
fingerprint is:
' from cvs server
cvs checkout: warning: unrecognized response `ssh-dss 1024
02:ab:7c:aa:49:ed:0b:a8:50:13:10:c2:3e:92:0f:42
' from cvs server
cvs checkout: warning: unrecognized response `If you trust this host,
enter "y" to add the key to
' from cvs server
cvs checkout: warning: unrecognized response `PuTTY's cache and carry on
connecting.
' from cvs server
cvs checkout: warning: unrecognized response `If you want to carry on
connecting just once, without
' from cvs server
cvs checkout: warning: unrecognized response `adding the key to the
cache, enter "n".
' from cvs server
cvs checkout: warning: unrecognized response `If you do not trust this
host, press Return to abandon the
' from cvs server
cvs checkout: warning: unrecognized response `connection.
' from cvs server
cvs checkout: warning: unrecognized response `Store key in cache? (y/n)
error unrecognized request `requests Checked-in New-entry Checksum
Copy-file Updated Created Update-existing Merged Patched Rcs-diff Mode
Mod-time Removed Renamed Remove-entry Set-static-directory
Clear-static-directory Set-sticky Clear-sticky Template Notified
Module-expansion Wrapper-rcsOption Clear-rename Rename EntriesExtra M
Mbinary E F MT'' from cvs server
cvs checkout: cwd=C:\ ,current=C:\
cvs server: cannot find module `lostcities' - ignored
cvs [checkout aborted]: cannot expand modules
Help or a pointer to further ressources would be very appreceated.
Re: Problem logging in CVS via SSL (sf.net) [message #270780 is a reply to message #270616] Thu, 09 September 2004 07:49 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I too can't get ssh2 to work internally to Eclipse, though I have no
problem using external putty.
benjamin cordes wrote:
> Hello,
> Eclipse Version:
> Version: 3.1.0
> Platform: WinXP
> SDK: 1.5 (beta)
> No result.
> {host} -l {user}
> ' from cvs server
> ' from cvs server
> ' from cvs server
> fingerprint is:
> ' from cvs server
> ' from cvs server
> ' from cvs server
> connecting.
> ' from cvs server
> ' from cvs server
> cache, enter "n".
> ' from cvs server
> ' from cvs server
> ' from cvs server
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Problem logging in CVS via SSL (sf.net) [message #270857 is a reply to message #270780] Thu, 09 September 2004 11:56 Go to previous messageGo to next message
How Did you get it work with putty?
What arguments do you hand over?
Is it {user}@{host}
or
{host} -l {user}
or
{host} -l {user} -pw yourpassword
or somehting else?
Did you use pageant?
Re: Problem logging in CVS via SSL (sf.net) [message #270971 is a reply to message #270857] Thu, 09 September 2004 23:28 Go to previous messageGo to next message
> Is it {user}@{host}
> or
> {host} -l {user}
> or
> or somehting else?
same as with 2.1
{host} -l {user} -i c:\dir\privKey.PPK -2
and the -2 is just to force the type 2 authentication or whatever, its
not necessary.
IIRC you have to connect manually first with putty from outside of
eclipse so you can answer putty's questions about the server if its your
first time connecting to it. I also do not have a password on my
private key. not sure if that makes a difference.
but i dont think 2.1 let you answer the putty questions about the new
server you are connecting to through the eclipse interface.
but i for the life of me can NOT get the 3.0 eclipse to use ssh at ALL!
Respectfully,
CL Gilbert
Re: Problem logging in CVS via SSL (sf.net) [message #270972 is a reply to message #270857] Thu, 09 September 2004 23:31 Go to previous messageGo to next message
> Is it {user}@{host}
> or
> {host} -l {user}
> or
> or somehting else?
looking back at your original question i believe your problem is that
you must first connect to sourceforce from outside of eclipse with
whatever ssh program you plan to use from within eclipse.
First connectin is always going to ask you a question, and eclipse does
not offer the capability to respond to questions. at least 2.1 didnt.
Respectfully,
CL Gilbert
Re: Problem logging in CVS via SSL (sf.net) [message #270979 is a reply to message #270972] Fri, 10 September 2004 03:41 Go to previous message
>> Is it {user}@{host}
>> or
>> {host} -l {user}
>> or
>> or somehting else?
Thanks for the response.
I logged on the shell.sf.net succesfully. Pageant handled my password
without any problems after it got my key from puttygen.
Then I gave eclipse a pointer to plink.exe
This is one the errors I got:
I/O has been interrupted.
The most likely cause of the interrupt is either an intermittent
network failure or a communications timeout.
The CVS communications timeout can be adjusted in the Team/CVS
preferences.
Another possible cause is the improper configuration of the "ext"
connection method.
The "ext" connection method can be configured on the Team/CVS/EXT
Connection Method preference page
Next I will try conntecting with eclipse 2.1
Previous Topic:Eclipse Images
Next Topic:add resource to version control and edit
Current Time: Mon Sep 01 00:03:06 EDT 2025
Powered by FUDForum. Page generated in 0.04648 seconds
