Home » Eclipse Projects » Mylyn » Different Task Categorization Wanted
Different Task Categorization Wanted [message #26759] Fri, 07 September 2007 10:29 Go to next message
Originally posted by: markphip.GoogleMail.com
I was trying to use the task categories feature the other day to
solvea problem I am having, and found it just did not meet my needs.
I have a task filter, let's say "All Open Tasks". What I wanted to do
was some triage and planning. What I would have liked to have been
able to do was create some folders/categories that lived within
thefilter, and then drag and drop tasks into the folders.
You can almost do this with the existing feature. The part that is
missing is that when you have a big list of tasks in a filter there is
no way to know which tasks have been put into one of these categories
and which ones have not. For this purpose it made the feature useless
because I could not even keep track of which tasks I had already
assigned categories too, let alone the fact that new tasks might come
inon the next synchronization etc...
I could have perhaps used the scheduling system as a bastardized way
of doing this. It is just that I am not personally going to be doing
any of these tasks, and I am not that interested in actual dates at
the moment. I just wanted to make some ad-hoc grouping of tasks so
that
I can get a better picture of the work.
Mark
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Re: Different Task Categorization Wanted [message #27754 is a reply to message #26759] Mon, 10 September 2007 16:57 Go to previous messageGo to next message
Mark,
I've been trying to work out very similar feature probably even before
Mylar 1.0.
First of all, since recently we have pluggable presentations. So, I've
used that and contributed several grouping presentations: by owner, by
repository, by priority, by due and by scheduled date. Though Mik
resisted to enable two last ones and he is also hesitating to make
TaskGroup class used by thouse presentation a public API, which would
enable to use it from custom actions or drag and drop stuff. See bug 175318
At the same time there is very old ongoing discussion (mainly pushed
by me) about allowing to stick arbitrary data to the task data and then
convert present tagging mechanism (part of the sandbox) to store tags
within that custom task data. See bug 199818 and bug 168363
The last piece of the puzzle is to use another custom presentations
that will group by these tags.
So, if you also think those are good ideas, please vote, comment, or
chime in on the above bug reports.
BTW, custom presentations could be also used to group on something
like component or other connector-specific attributes, but it require
enhancements from the bug 199818
regards,
Eugene
> that
> Thanks
> Mark
Re: Different Task Categorization Wanted [message #27906 is a reply to message #27754] Tue, 11 September 2007 22:33 Go to previous messageGo to next message
In article <fc4b35$1o9$1@build.eclipse.org> Eugene
Kuleshov<eu@md.pp.ru> wrote:
> Mark,
> before Mylar 1.0.
> I've used that and contributed several grouping presentations: by
> owner, by repository, by priority, by due and by scheduled date.
> Though Mik resisted to enable two last ones and he is also hesitating
> to make TaskGroup class used by thouse presentation a public API,
> which would enable to use it from custom actions or drag and drop
> pushed by me) about allowing to stick arbitrary data to the task data
> and then convert present tagging mechanism (part of the sandbox) to
> store tags within that custom task data. See bug 199818 and bug 168363
> presentations that will group by these tags.
> or chime in on the above bug reports.
> regards,
> Eugene
>> to do was some triage and planning. What I would have liked to have
>> been able to do was create some folders/categories that lived within
>> is missing is that when you have a big list of tasks in a filter
>> there is no way to know which tasks have been put into one of these
>> categories and which ones have not. For this purpose it made the
>> feature useless because I could not even keep track of which tasks I
>> had already assigned categories too, let alone the fact that new
>> tasks might come inon the next synchronization etc...
>> way of doing this. It is just that I am not personally going to be
>> doing any of these tasks, and I am not that interested in actual
>> dates at the moment. I just wanted to make some ad-hoc grouping of
>> tasks so
>> that
To me, the key would be that the grouping would have to take place
inside the context of an existing filter (probably the UI too).
Because my main problem with the category approach is that there is no
way to knowwhat you have not categorized yet.
It is possible that additional groupings like you propose would help,
in my case probably not since there is no field in the issue
trackerthat I can group by.
Anyway, I could probably work with the categories if I could get
themto appear as child nodes to my filter.
Mark
Re: Different Task Categorization Wanted [message #27946 is a reply to message #27906] Wed, 12 September 2007 00:45 Go to previous messageGo to next message
I am not sure what you mean by context or existing filter. We have
queries, categories and working sets. Newly added presentations provide
grouping of tasks from within existing queries and categories (by
assignee/owner, repository, priority and due date). You can try this
already with the recent dev build (2.1m2 code), just install sandbox
feature from "extras" update site.
Right. With those grouping presentations there is an <unknown> group.
Unfortunately right now task list UI only allow to visualize data from
the AbstractTask object, which currently don't allow to store arbitrary
data. Enhancement request 199818 should remove this limitation.
I don't think that won't work well. But features from bug 168363
implemented on top of the new API from bug 199818 would give local
representation you are looking for. Patch I've contributed for the
latter one about a month ago, been considered as not good enough for
inclusion into the 2.1 release and this new API won't be implemented
before the early 3.0 time.
regards,
Eugene
Re: Different Task Categorization Wanted [message #29181 is a reply to message #26759] Tue, 18 September 2007 16:18 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
Mark,
Here is a quick summary of our current mechanisms for manually
organizing your Task List;
QUERIES (aka Filters in JIRA): good because they're flexible, e.g. you
can subdivide them as much as you want and name them in a way that
simulates nesting.
CATEGORIES: useful for local tasks and for repository tasks with which
you are not using a query. As you point out, much less useful if you
are using queries since there will be duplication and no indication of
what's already been added to the category.
WORKING SETS: useful for grouping sets of related categories and queries.
SCHEDULING: useful for presenting and ordering tasks in the order in
which you want to work on them, both for your own tasks and for those of
others.
What I think we need to better understand is your use case for
tagging/categorizing the tasks. For example, what would you name such
categories? When would you move things into them? How would this
overlap with the use of Scheduled For dates?
We have to proceed extremely carefully in adding any arbitrary attribute
UI to the Task List because we already have 4 orthogonal mechanisms for
organizing tasks. We also have better support for subtasks now, and a
key goal of the Task List is to stay simple by minimizing hierarchy. If
we allow containers to cascade in addition to supporting subtasks, the
UI and interaction would become considerably more complicated.
Mik
> that
Re: Different Task Categorization Wanted [message #29333 is a reply to message #29181] Tue, 18 September 2007 19:55 Go to previous messageGo to next message
In article <fcpbru$2sg$1@build.eclipse.org> Mik
Kersten<beatmik@acm.org> wrote:
> Mark,
> you can subdivide them as much as you want and name them in a way
> that simulates nesting.
> which you are not using a query. As you point out, much less useful
> if you are using queries since there will be duplication and no
> indication of what's already been added to the category.
> queries.
> of others.
> such categories? When would you move things into them? How would
> this overlap with the use of Scheduled For dates?
> attribute UI to the Task List because we already have 4 orthogonal
> mechanisms for organizing tasks. We also have better support for
> subtasks now, and a key goal of the Task List is to stay simple by
> minimizing hierarchy. If we allow containers to cascade in addition
> to supporting subtasks, the UI and interaction would become
First let me say I do not pretend to have an answer. I guess in some
ways what I want to do ought to be doable in my issue tracker, it just
isn't. Also, when working in a collaborative open source world you
might want to do some organizing that you do not push into the issue
tracker. Theexisting scheduling features are a good example of this.
My scenario seems simple (to me). I have a query that pulls down a
number of issues. Let's say it is all open tasks with the 1.x
milestone. I have 30 tasks. I might not do any of them myself. I
wanted to organizethem in random ways. Basically I just wanted to
make some groups:
Critical - hard
Critical - medium
Deferrable
Needs Scoping
etc...
Then assign these 30 tasks to one of the groups. I started out using
categories but quickly realized there was no way to know what tasks I
hadalready categorized.
One way to approach this might be to be able to apply Web-2.0 style
tags to tasks. If you could see a comma separated list of tags
assigned in the task list you would at least know if you had assigned
one or not. You could then offer a view that grouped by tag. This
might be more flexibleassuming you can assign more than one tag.
Mark
Re: Different Task Categorization Wanted [message #29371 is a reply to message #29333] Tue, 18 September 2007 20:36 Go to previous messageGo to next message
That is exactly what I've been talking about.
As a current workaround, is to use highlighters from the sandbox, just
need to configure them according to your schema: "hard", "medium",
"Deferrable", "Needs Scoping" and assign distinguishable colors.
Unfortunately that allows to have only one classification and real
tagging would give much more flexibility.
regards,
Eugene
Re: Different Task Categorization Wanted [message #30119 is a reply to message #29333] Fri, 21 September 2007 19:53 Go to previous message
Thanks Mark, that's exactly the kind of feedback I was after. I've
appended this to the corresponding bug report and added some
summarization of similar requests on that same bug:
168363: provide mechanism for starring/tagging/bookmarking a task
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168363
All interested in such a feature please consider voting for and
commenting on that bug report.
Mik
> make some groups:
> Critical - hard
> Critical - medium
> Deferrable
> Needs Scoping
> etc...
Re: Different Task Categorization Wanted [message #580779 is a reply to message #26759] Mon, 10 September 2007 16:57 Go to previous message
Mark,
Mylar 1.0.
regards,
Eugene
> that
> Thanks
> Mark
Re: Different Task Categorization Wanted [message #580866 is a reply to message #27754] Tue, 11 September 2007 22:33 Go to previous message
> Mark,
> before Mylar 1.0.
> regards,
> Eugene
>> tasks so
>> that
Mark
Re: Different Task Categorization Wanted [message #580877 is a reply to message #27906] Wed, 12 September 2007 00:45 Go to previous message
regards,
Eugene
Re: Different Task Categorization Wanted [message #581432 is a reply to message #26759] Tue, 18 September 2007 16:18 Go to previous message
Mark,
simulates nesting.
others.
Mik
> that
Re: Different Task Categorization Wanted [message #581573 is a reply to message #29181] Tue, 18 September 2007 19:55 Go to previous message
> Mark,
> queries.
> of others.
make some groups:
Critical - hard
Critical - medium
Deferrable
Needs Scoping
etc...
Mark
Re: Different Task Categorization Wanted [message #581590 is a reply to message #29333] Tue, 18 September 2007 20:36 Go to previous message
regards,
Eugene
Re: Different Task Categorization Wanted [message #581809 is a reply to message #29333] Fri, 21 September 2007 19:53 Go to previous message
Mik
> make some groups:
> Critical - hard
> Critical - medium
> Deferrable
> Needs Scoping
> etc...
Previous Topic:update site link broken
Next Topic:Trac display
Current Time: Tue Jul 15 06:07:42 EDT 2025
Powered by FUDForum. Page generated in 0.06501 seconds
