Home » Newcomers » Newcomers » Port listener
Port listener [message #269973] Sat, 04 April 2009 18:06 Go to next message
Originally posted by: hopebt.gmail.com
Hello everybody;
Would you please tell me the easest way of listenining port in eclipse?
I've a web service and i want to learn messages which is received.
Which plug-in i can use?
Re: Port listener [message #270139 is a reply to message #269973] Thu, 09 April 2009 02:01 Go to previous message
Lacivert wrote:
> Hello everybody;
Not sure about the "easiest" but Java Communication API should definitely help you.
You can also use Eclipse Communication Framework (http://www.eclipse.org/ecf/). Not sure how easy/difficult it is to use.
hth,
Ankur..
Previous Topic:Doesn't stop on break points (using Debug, not Run)
Next Topic:RCP query
Current Time: Mon Sep 22 15:33:52 EDT 2025
Powered by FUDForum. Page generated in 0.07654 seconds
