Home » Newcomers » Newcomers » Java Perspective Missing
Java Perspective Missing [message #269663] Fri, 20 March 2009 18:05 Go to next message
I do not see a java perspective, at start, nor in the windows >
perspectives menu. I have read the responses about getting the swt, not
the ide, and tried many downloads. I also saw a suggestion to remove the
'.eclipse' file. None of these had any effect. While this is a newbie
forum, I have been using eclipse since eclipse version 1.x. I do not
remember ever having this problem.
Please suggest a way to check what I have and how to activate the java
perspective.
Re: Java Perspective Missing [message #269668 is a reply to message #269663] Sat, 21 March 2009 10:52 Go to previous messageGo to next message
I found a reference that suggested eclipse requires jdk1.5, so I used
jdk1.5.0_16. Same result.
I also tried to add the Java Development tools, using software update. It
failed dependency checks, with details:
Cannot complete the request. See the details.
Exception writing problem file in: null.The system cannot find the path
specified
Any help would be appreciated. I have tried:
eclipse-jee-ganymede-win32
eclipse-jee-ganymede-SR1-win32
eclipse-jee-ganymede-SR2-win32
eclipse-java-ganymede-SR2-win32
I still do not see a java perspective?
Re: Java Perspective Missing [message #269670 is a reply to message #269668] Sat, 21 March 2009 11:58 Go to previous messageGo to next message
If I go back to eclipse classic sdk 3.4.2, then it works?
Re: Java Perspective Missing [message #269689 is a reply to message #269670] Mon, 23 March 2009 03:25 Go to previous messageGo to next message
"Jeff Oakes" <jeff.oakes@comcast.net> wrote in message
news:c8b2b8447cc4546c16eeffe20b17e9ed$1@www.eclipse.org...
What OS are you running on?
What is your JRE?
Are there any errors in the error log?
What is your launch command and your eclipse.ini?
Are the JDT plugins (for example, org.eclipse.jdt.core and .ui) present in
the installation directory?
Re: Java Perspective Missing [message #269759 is a reply to message #269689] Wed, 25 March 2009 15:14 Go to previous messageGo to next message
Thanks for the reply. You ask several questions. Here are the answers:
What OS are you running on? Windows XP Pro SP2
What is your JRE? I've tried 1.6.0_12 & 1.5.0_16
Are there any errors in the error log?Yes, as I have tried several things
the list is long. See below.
What is your launch command and your eclipse.ini?I do not see an
eclipse.ini
the installation directory?Yes
Here is the log - note this is from a common workspace.
!SESSION 2009-03-21 11:43:18.343
eclipse.buildId=M20090211-1700
java.version=1.5.0_16
Command-line arguments: -os win32 -ws win32 -arch x86 -data
C:\data\source\java\eclipse
!ENTRY org.eclipse.ui.console 4 2 2009-03-21 11:57:05.265
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.console".
!STACK 0
org.eclipse.swt.SWTException: Device is disposed
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.SWT.error(SWT.java:3666)
at org.eclipse.swt.widgets.Display.error(Display.java:1180)
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:648)
org.eclipse.ui.internal.console.ConsoleDropDownAction.consol esRemoved(ConsoleDropDownAction.java:150)
org.eclipse.ui.internal.console.ConsoleManager$ConsoleNotifi er.run(ConsoleManager.java:154)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.internal.console.ConsoleManager$ConsoleNotifi er.notify(ConsoleManager.java:174)
org.eclipse.ui.internal.console.ConsoleManager.fireUpdate(Co nsoleManager.java:262)
org.eclipse.ui.internal.console.ConsoleManager.removeConsole s(ConsoleManager.java:244)
org.eclipse.debug.internal.ui.views.console.ProcessConsoleMa nager.removeProcess(ProcessConsoleManager.java:98)
org.eclipse.debug.internal.ui.views.console.ProcessConsoleMa nager.removeLaunch(ProcessConsoleManager.java:81)
org.eclipse.debug.internal.ui.views.console.ProcessConsoleMa nager.shutdown(ProcessConsoleManager.java:198)
org.eclipse.debug.internal.ui.DebugUIPlugin.stop(DebugUIPlug in.java:388)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1050)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1046)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:457)
org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:531)
org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1104)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:655)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:312)
org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:257)
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:236)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:678)
org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:576)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:424)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:200)
!ENTRY org.eclipse.ui.console 4 120 2009-03-21 11:57:05.265
!MESSAGE An exception occurred during console notification
!STACK 0
!SESSION 2009-03-21 13:11:52.656
java.version=1.6.0_12
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2009-03-21
13:25:50.578
!MESSAGE No repository found at http://subclipse.tigris.org/update_1.6.x
!SUBENTRY 1 org.eclipse.equinox.p2.updatesite 4 1002 2009-03-21
13:25:50.578
!MESSAGE Error reading update site
http://subclipse.tigris.org/update_1.6.x.
!STACK 0
java.io.IOException: The system cannot find the path specified
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(File.java:1704)
at java.io.File.createTempFile(File.java:1792)
at java.io.File.createTempFile(File.java:1828)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadSi teFile(UpdateSite.java:154)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.load(U pdateSite.java:105)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository. <init>(UpdateSiteMetadataRepository.java:52)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepositoryFactory.load(UpdateSiteMetadataRepositor yFactory.java:48)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:485)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:452)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:435)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.loadMetadataRepository(ProvisioningUtil.java: 71)
org.eclipse.equinox.internal.provisional.p2.ui.dialogs.Avail ableIUGroup$6.run(AvailableIUGroup.java:404)
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 0 2009-03-21
13:28:42.828
!MESSAGE Unable to load repository: http://findbugs.cs.umd.edu/eclipse
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception:
Unable to read repository at http://findbugs.cs.umd.edu/eclipse.
org.eclipse.equinox.internal.provisional.spi.p2.artifact.rep ository.SimpleArtifactRepositoryFactory.load(SimpleArtifactR epositoryFactory.java:102)
org.eclipse.equinox.internal.p2.artifact.repository.Artifact RepositoryManager.loadRepository(ArtifactRepositoryManager.j ava:426)
org.eclipse.equinox.internal.p2.artifact.repository.Artifact RepositoryManager.loadRepository(ArtifactRepositoryManager.j ava:403)
org.eclipse.equinox.internal.p2.artifact.repository.Artifact RepositoryManager.refreshRepository(ArtifactRepositoryManage r.java:492)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.refreshArtifactRepositories(ProvisioningUtil. java:202)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Re freshColocatedRepositoriesOperation.doBatchedExecute(Refresh ColocatedRepositoriesOperation.java:51)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Re positoryOperation.doExecute(RepositoryOperation.java:63)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Un doableProvisioningOperation.execute(UndoableProvisioningOper ation.java:77)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
org.eclipse.equinox.internal.provisional.p2.ui.ProvisioningO perationRunner$1.run(ProvisioningOperationRunner.java:92)
Caused by: java.io.IOException: The system cannot find the path specified
org.eclipse.equinox.internal.provisional.spi.p2.artifact.rep ository.SimpleArtifactRepositoryFactory.load(SimpleArtifactR epositoryFactory.java:53)
... 10 more
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1002 2009-03-21
13:28:42.828
!MESSAGE Unable to read repository at http://findbugs.cs.umd.edu/eclipse.
!STACK 0
13:28:42.828
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception: Error
reading update site http://findbugs.cs.umd.edu/eclipse.
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadSi teFile(UpdateSite.java:172)
org.eclipse.equinox.internal.p2.updatesite.artifact.UpdateSi teArtifactRepository. <init>(UpdateSiteArtifactRepository.java:45)
org.eclipse.equinox.internal.p2.updatesite.artifact.UpdateSi teArtifactRepositoryFactory.load(UpdateSiteArtifactRepositor yFactory.java:33)
... 13 more
13:28:42.828
!MESSAGE Error reading update site http://findbugs.cs.umd.edu/eclipse.
!STACK 0
!ENTRY org.eclipse.equinox.p2.ui 4 0 2009-03-21 13:28:42.937
!MESSAGE No repository found at http://findbugs.cs.umd.edu/eclipse.
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception: No
org.eclipse.equinox.internal.p2.artifact.repository.Artifact RepositoryManager.fail(ArtifactRepositoryManager.java:249)
org.eclipse.equinox.internal.p2.artifact.repository.Artifact RepositoryManager.loadRepository(ArtifactRepositoryManager.j ava:414)
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1000 2009-03-21
13:28:42.937
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-21 13:31:23.796
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-03-21 13:31:23.796
!MESSAGE Unable to satisfy dependency from
org.springframework.ide.eclipse.beans.ui 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.wst.xml.core/0.0.0.
requiredCapability: osgi.bundle/org.eclipse.wst.sse.core/0.0.0.
requiredCapability:
osgi.bundle/org.eclipse.wst.common.project.facet.core/0.0.0.
org.springframework.ide.eclipse.osgi 2.2.2.RELEASE to requiredCapability:
osgi.bundle/org.eclipse.wst.xml.ui/0.0.0.
org.springframework.ide.eclipse.aop.mylyn 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.mylyn.resources.ui/3.0.0.
requiredCapability: osgi.bundle/org.eclipse.mylyn.context.ui/3.0.0.
requiredCapability: osgi.bundle/org.eclipse.mylyn.ide.ui/3.0.0.
requiredCapability: osgi.bundle/org.eclipse.mylyn.context.core/3.0.0.
org.springframework.ide.eclipse.beans.core 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.wst.xsd.core/0.0.0.
requiredCapability: osgi.bundle/org.eclipse.emf.common/0.0.0.
requiredCapability: osgi.bundle/org.eclipse.xsd/0.0.0.
org.springframework.ide.eclipse.aop.core 2.2.2.RELEASE to
com.springsource.javax.servlet.jsp.jstl 1.2.0 to requiredCapability:
java.package/org.w3c.dom.traversal/0.0.0.
org.springframework.ide.eclipse.beans.osgibridge 2.2.2.RELEASE to
org.springframework.ide.eclipse.webflow.ui 2.2.2.RELEASE to
org.springframework.ide.eclipse.ajdt.ui.visualiser 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.contribution.visualiser/0.0.0.
org.springframework.ide.eclipse.security 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.wst.xml.ui/0.0.0.
org.springframework.ide.eclipse.beans.ui.refactoring 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.wst.sse.ui/0.0.0.
org.springframework.ide.eclipse.webflow.ui.editor 2.2.2.RELEASE to
org.springframework.ide.eclipse.webflow.mylyn 2.2.2.RELEASE to
org.springframework.ide.eclipse.aop.ui 2.2.2.RELEASE to
org.springframework.ide.eclipse.webflow.ui.graph 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.gef/0.0.0.
org.springframework.ide.eclipse.mylyn.feature.feature.group 2.2.2.RELEASE
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.context_feature. feature.group/3.0.0.
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.ide_feature.feat ure.group/3.0.0.
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.java_feature.fea ture.group/3.0.0.
org.eclipse.equinox.p2.iu/org.eclipse.mylyn_feature.feature. group/3.0.0.
org.springframework.ide.eclipse.beans.mylyn 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.mylyn.monitor.ui/3.0.0.
requiredCapability: osgi.bundle/org.eclipse.mylyn.monitor.core/3.0.0.
requiredCapability: osgi.bundle/org.eclipse.mylyn.java.ui/3.0.0.
org.springframework.ide.eclipse.beans.ui.graph 2.2.2.RELEASE to
org.springframework.ide.eclipse.mylyn 2.0.6.RELEASE to requiredCapability:
osgi.bundle/org.eclipse.mylyn.commons.ui/3.0.0.
org.springframework.ide.eclipse.ajdt.ui.xref 2.2.2.RELEASE to
requiredCapability: osgi.bundle/org.eclipse.contribution.xref.ui/0.0.0.
requiredCapability: osgi.bundle/org.eclipse.contribution.xref.core/0.0.0.
requiredCapability: osgi.bundle/org.eclipse.ajdt.core/0.0.0.
requiredCapability: osgi.bundle/org.eclipse.ajdt.ui/0.0.0.
org.springframework.ide.eclipse.batch 2.2.2.RELEASE to requiredCapability:
org.springframework.ide.eclipse.feature.feature.group 2.2.2.RELEASE to
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.wst.xml_ui.feature.fea ture.group/0.0.0.
org.springframework.ide.eclipse.core 2.2.2.RELEASE to requiredCapability:
osgi.bundle/org.apache.xerces/2.8.0.
org.springframework.ide.eclipse.ui 2.2.2.RELEASE to requiredCapability:
org.springframework.ide.eclipse.ajdt.feature.feature.group 2.2.2.RELEASE
org.eclipse.equinox.p2.iu/org.eclipse.ajdt.feature.group/0.0 .0.
org.springframework.ide.eclipse.webflow.core 2.2.2.RELEASE to
org.springframework.ide.eclipse.beans.ui.editor 2.2.2.RELEASE to
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-03-21 13:31:23.796
!MESSAGE Exception writing problem file in: null.
!STACK 0
org.eclipse.equinox.internal.p2.director.Projector.persist(P rojector.java:212)
org.eclipse.equinox.internal.p2.director.Projector.encode(Pr ojector.java:99)
org.eclipse.equinox.internal.p2.director.SimplePlanner.getPr ovisioningPlan(SimplePlanner.java:242)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.getProvisioningPlan(ProvisioningUtil.java:210 )
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.computeProvisioningPlan(InstallAction.java:80)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.getProvisioningPlan(InstallAction.java:130)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Profi leModificationAction$1.run(ProfileModificationAction.java:61 )
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
!ENTRY org.eclipse.equinox.p2.ui 4 10005 2009-03-21 13:31:28.546
!MESSAGE Cannot complete the request. See the details.
!SUBENTRY 1 org.eclipse.equinox.p2.ui 4 10005 2009-03-21 13:31:28.546
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2009-03-21 13:31:28.546
!MESSAGE Cannot find a solution satisfying the following requirements
org.eclipse.jdt.feature.jar
[3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI].
!ENTRY org.eclipse.equinox.p2.ui 4 10005 2009-03-21 13:31:36.046
!SUBENTRY 1 org.eclipse.equinox.p2.ui 4 10005 2009-03-21 13:31:36.046
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2009-03-21 13:31:36.046
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-21 13:31:36.578
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-03-21 13:31:36.578
requiredCapability:
Re: Java Perspective Missing [message #269765 is a reply to message #269759] Thu, 26 March 2009 09:37 Go to previous message
> things the list is long. See below.
> eclipse.ini
You have to have an eclipse.ini file, unless the extraction of the ZIP
went awry. It should be right next to eclipse.exe
If you don't have that, I'd not bother looking at anything else,
especially since that is how you tell Eclipse what JVM to run in
(http://wiki.eclipse.org/Eclipse.ini).
The log you posted is much too large for me to analyze. Once you get a
valid install (one that includes eclipse.ini) and you've told it which
JVM to use (as described in the link above), then delete the log and
start up Eclipse. If you're still missing the JDT stuff, capture the log
immediately and post that.
Hope this helps,
Eric
Previous Topic:Re: Active Project Handling - Howto
Next Topic:attaching the XML file to graphical editor
Current Time: Thu Jul 17 09:06:41 EDT 2025
Powered by FUDForum. Page generated in 0.12474 seconds
