Looking for Simple EJB Tutorial [message #269554] |
Wed, 18 March 2009 17:27 |
I am looking for a tutoria similar to "WTP Tutorials - Building a Simple
EJB Application". Unfortunately this tutorial does not track with the
current versions of Eclipse and JBoss. I am trying to learn JBoss 5.0.1
and Eclipse 3.4.2 (both of which I have just installed). (I followed
instructions elsewhere for adding WTP tools from callisto).
When I tried using this tutorial despite the inconsistencies the first
trouble comes when I create a new EJB Project. At first I could not get
xdoclet to create my home, local, etc. files; I found that if I use EJB
Module Version = 2.0, I could then modify the configuration to check the
"EJB Doclet" facet.
Well, the tutorial tells me to uncheck the "Add Project to an EAR", but if
I do this I cannot check the "Create EJB Client JAR" module. So, I go
ahead and check the Add Project to EAR, and set the name to ZooBeansEAR. I
can then set my client name=ZooBeansClient and JAR=ZooBeansClient.jar.
So now the challence: The project explorer does not track with the
tutorial. I now have root folders ZooBeansClient, ZooBeansEAR, and
ZooBeansProject. The tutorial tells me to add TigerBean to the folder
ejbModule; however, I find this folder in multiple locations. I take a
guess and add the TigerBean class to the ejbModule under ZooBeansProject.
When I save (after removing all the "@Override"'s) xdoclet completes and
under ZooBeansClient/ejbModules I now have Tiger, TigerHome, TigerLocal,
TigerLocalHome and TigerUtil.
SO far I am thinking I have made this work. But alas, I try to deploy to
JBoss and jBoss gags: I added my JBoss installation under servers, then
right-click to "Add and remove projects". My only choice is ZooBeansEAR
which lists under it ZooBeansClient (which I found is an empty .jar and
likely what is broken) and ZooBeansProject. JBoss gives an error
indicating it cannot find/load the TigerSession.class.
I would like to fix the deployment, but even more I would like to know how
to use eclipse properly. Is there an updated version of this tutorial
somewhere, or has someone run into this before?
TIA,
Steve B.
FUDForum. Page generated in 0.07565 seconds
