Home » Archived » Java WorkFlow Tooling (JWT) » Re: Extending JWT's EMF metamodel
Re: Extending JWT's EMF metamodel [message #26641] Wed, 02 July 2008 04:39 Go to next message
Hi all
Please reply to this message instead so it also get posted in JWT's forum.
Marc
Marc Dutoo a écrit :
> Hi all
> In the project Eclipse JWT, we manage workflows using ecore-specified
> XMI models and we want to let our users define and add custom
> information in it.
> We've logically though about allowing to define ecore metamodels than
> extend ours, and about the possibilities of Dynamic EMF. So we've tried
> a few things (using Europa's EMF) and come across what seem to be
> limitations of extending EMF, especially concerning typing of relations :
> * a dynamic class can only extend a non-interface, non-abstract
> static class. OK, actually I can agree with this one ;)
> * in order to create dynamic extensions inheriting from this
> non-interface, non-abstract static class, I've had to create and
> register a custom factory that does this work for the package containing
> the dynamic ecore extension. Well, ok again, we could automatically do
> this for all ecores that are found in a given place.
> * Now to the fun stuff : I defined in a dynamic EMF extension to my
> core, static metamodel a containment eReference that whose target type
> is a core, static type, but any sample model fails to load. It appears
> that proxy resolution fails for my eReference at parsing : it goes
> through XMLHandler.setFeatureValue()'s proxy handling code at line 2628
> where either createObjectFromFeatureType() believes the eReference's
> eType is eClassifier (because it is the type of the "eType" feature of
> EReference), or createObjectFromTypeName() believes the eReference's
> eType is PropertyImpl (whereas it should be a ClassImpl with name
> Property).
> * and upside down, I defined a core, static-typed element under a
> dynamic defined, but was not able to load a sample following this model,
> for the same reason. Though proxy resolution works fine for attributes,
> or if typing the dynamic-defined relation with a dynamic-defined
> extension of a core, static type.
> Any feedback about this behaviour ?
> NB. for those more interested about the "requirements" side of our
> endeavours, you can look here see more here
> http://wiki.eclipse.org/JWT_Metamodel .
> Marc Dutoo
> Open Wide
> Eclipse JWT co-lead
Re: Extending JWT's EMF metamodel [message #26727 is a reply to message #26641] Wed, 02 July 2008 08:47 Go to previous messageGo to next message
--------------080602000607000309040703
Marc,
Comments below.
Marc Dutoo wrote:
> Hi all
> forum.
> Marc
> Marc Dutoo a
Re: Extending JWT's EMF metamodel [message #26767 is a reply to message #26727] Wed, 02 July 2008 09:35 Go to previous messageGo to next message
Hi Ed
First thanks for trying to make some sens of my questions ;)
Also much thanks for the EFactoryImpl customization code. It is nice to
be able to have such a fully generic solution whatever the extensions
ecores !
Now about the eReference proxy problem :
I would agree with you it is not a static vs dynamic problem, but an
external definition proxy problem, and in this case you are right to
point at the URI
So I've tried the following URIs when defining in my ecore extension the
target type of my "dynaspectproperty" reference :
OK (local type, no proxy) :
<eStructuralFeatures xsi:type="ecore:EReference"
name="dynaspectproperty" upperBound="-1" eType="#//CustomElement"
containment="true"/>
Not OK 1 :
name="dynaspectproperty" upperBound="-1" eType="core:Property
java://org.eclipse.jwt.we.model.core.CorePackage#//Property"
Explanation :
proxy resolution using XMLHandler.createObjectFromTypeName() fails while
trying to set the eType feature to an instance of EMF Property (backed
up by the java class PropertyImpl), whereas it should be the instance of
EMF Class (backed up by the java class ClassImpl) with the name "Property".
Not OK 2
eType="java://org.eclipse.jwt.we.model.core.CorePackage#//Property"
Explanation :
proxy resolution using XMLHandler.createObjectFromFeatureType() fails
while trying to set the eType feature to the instance of EMF Class
(backed up by the java class ClassImpl) with the name "eClassifier"
(because "eClassifier" is the type of the "eType" feature of the
eReference class)
Is there any other way (URIs) to refer to a static model ?
Some more details on the context of my problem :
Base metamodel :
* defined as static EMF in WEMetaModel.ecore, and generated from its
genmodel as a host of packages, java classes and interfaces
* contains static classes like ModelElement, Property, Aspect
Extension metamodel :
* on ModelElement, an Aspect-typed "aspects" relation is defined
* Aspect's generated impl AspectImpl serves as the impl of dynamic
EMF extensions (in a generic manner, thanks to your code)
Custom extension metamodel :
* defined as dynamic EMF in WEMetaModel_custom.ecore
* contains a dynamic class CustomAspect extending Aspect, and others
like CustomElement
* on CustomAspect I've tried to define a "dynaspectproperty"
reference in different ways depicted above.
Marc
Ed Merks a écrit :
> Marc,
> Comments below.
> Marc Dutoo wrote:
>> Hi all
>> forum.
>> Regards,
>> Marc
>>> Hi all
>>> information in it.
>>> tried a few things (using Europa's EMF) and come across what seem to
>>> be limitations of extending EMF, especially concerning typing of
>>> relations :
> Yep. That's because it needs to be able to create an instance of the
> Impl class that it can extend. In hindsight, for dealing with proxies,
> it would have been nicer if you could always create an instance of even
> an abstract class, but some internal mechanism, but this would force
> clients to always provide a non-abstract impl class; it's too late to
> foist that on clients now.
>>> containing the dynamic ecore extension. Well, ok again, we could
>>> automatically do this for all ecores that are found in a given place.
> No, this logic in EFactoryImpl should do the trick of creating an
> instance of the first super type with an implementation class.
> public EObject create(EClass eClass)
> if (getEPackage() != eClass.getEPackage() || eClass.isAbstract())
> throw new IllegalArgumentException("The class '" +
> eClass.getName() + "' is not a valid classifier");
> for (List<EClass> eSuperTypes = eClass.getESuperTypes();
> !eSuperTypes.isEmpty(); )
> EClass eSuperType = eSuperTypes.get(0);
> if (eSuperType.getInstanceClass() != null)
> EObject result =
> eSuperType.getEPackage().getEFactoryInstance().create(eSuper Type);
> ((InternalEObject)result).eSetClass(eClass);
> return result;
> eSuperTypes = eSuperType.getESuperTypes();
> return basicCreate(eClass);
>>> my core, static metamodel a containment eReference that whose target
>>> type is a core, static type, but any sample model fails to load. It
>>> appears that proxy resolution fails for my eReference at parsing : it
>>> goes through XMLHandler.setFeatureValue()'s proxy handling code at
>>> line 2628 where either createObjectFromFeatureType() believes the
>>> eReference's eType is eClassifier (because it is the type of the
>>> "eType" feature of EReference), or createObjectFromTypeName()
>>> believes the eReference's eType is PropertyImpl (whereas it should be
>>> a ClassImpl with name Property).
> What's PropertyImpl? It sounds like some crossing of meta model
> boundaries here.
>>> model, for the same reason. Though proxy resolution works fine for
>>> attributes, or if typing the dynamic-defined relation with a
>>> dynamic-defined extension of a core, static type.
> I'm totally confused. :-P
> Maybe you could be a bit more concrete about the nature of these
> extensions you wrote. Generally EMF won't care if the type of an
> EReference is a dynamic EClass or a static EClass. BUT, it's important
> that if you want to static EClass, your Ecore model needs to refer to
> that static model (via the nsURI) and not tot he dynamic model (i.e.,
> the serialized .ecore version in the model folder).
>>> Regards,
>>> Marc Dutoo
>>> Open Wide
>>> Eclipse JWT co-lead
Re: Extending JWT's EMF metamodel [message #26802 is a reply to message #26767] Wed, 02 July 2008 13:07 Go to previous messageGo to next message
Marc,
Comments below.
Marc Dutoo wrote:
> Hi Ed
> to be able to have such a fully generic solution whatever the
> extensions ecores !
> point at the URI
> the target type of my "dynaspectproperty" reference :
> Not OK 1 :
> Explanation :
> while trying to set the eType feature to an instance of EMF Property
> (backed up by the java class PropertyImpl), whereas it should be the
> instance of EMF Class (backed up by the java class ClassImpl) with the
> name "Property".
Is "java://org.eclipse.jwt.we.model.core.CorePackage" the nsURI of your
package? I don't know of any PropertyImpl Java class, except for the
one in UML, so that's really confusing. Oh wait. What's core:Property?
Shouldn't this be "ecore:EClass"? This QName determines what type of
instance is created to act as a proxy.
> Not OK 2
> Explanation :
> eReference class)
The QName is needed to create a proxy of the right type.
> Base metamodel :
> its genmodel as a host of packages, java classes and interfaces
> others like CustomElement
> Marc
> Ed Merks a écrit :
>> Marc,
>> Comments below.
>> Marc Dutoo wrote:
>>> Hi all
>>> forum.
>>> Regards,
>>> Marc
>>>> Hi all
>>>> ecore-specified XMI models and we want to let our users define and
>>>> add custom information in it.
>>>> than extend ours, and about the possibilities of Dynamic EMF. So
>>>> we've tried a few things (using Europa's EMF) and come across what
>>>> seem to be limitations of extending EMF, especially concerning
>> proxies, it would have been nicer if you could always create an
>> instance of even an abstract class, but some internal mechanism, but
>> this would force clients to always provide a non-abstract impl class;
>> it's too late to foist that on clients now.
>> EObject result =
>> return result;
>>>> target type is a core, static type, but any sample model fails to
>>>> load. It appears that proxy resolution fails for my eReference at
>>>> parsing : it goes through XMLHandler.setFeatureValue()'s proxy
>>>> handling code at line 2628 where either
>>>> createObjectFromFeatureType() believes the eReference's eType is
>>>> eReference's eType is PropertyImpl (whereas it should be a
>> boundaries here.
>>>> a dynamic defined, but was not able to load a sample following this
>> important that if you want to static EClass, your Ecore model needs
>> to refer to that static model (via the nsURI) and not tot he dynamic
>> model (i.e., the serialized .ecore version in the model folder).
>>>> Regards,
>>>> Marc Dutoo
>>>> Open Wide
>>>> Eclipse JWT co-lead
Re: Extending JWT's EMF metamodel [message #26844 is a reply to message #26802] Thu, 03 July 2008 04:40 Go to previous message
Hi Ed
Oops you're right, with "ecore:EClass" it works :
name="dynaspectproperty" upperBound="-1" eType="ecore:EClass
loads OK !
Thanks very much, it was almost too simple ^^
Best regards & have a nice day,
Marc
Ed Merks a écrit :
> Marc,
> Comments below.
> Marc Dutoo wrote:
>> Hi Ed
>> extensions ecores !
>> point at the URI
>> Not OK 1 :
>> Explanation :
>> name "Property".
>> Not OK 2
>> Explanation :
>> eReference class)
>> Base metamodel :
>> Regards,
>> Marc
>> Ed Merks a écrit :
>>> Marc,
>>> Comments below.
>>> Marc Dutoo wrote:
>>>> Hi all
>>>> forum.
>>>> Regards,
>>>> Marc
>>>>> Hi all
>>> EObject result =
>>> return result;
>>> boundaries here.
>>>>> Regards,
>>>>> Marc Dutoo
>>>>> Open Wide
>>>>> Eclipse JWT co-lead
Previous Topic:Article on ESB mentioning Eclipse JWT & PVM
Next Topic:Article : XPDL vs BPEL in light of BPMN mode
Current Time: Fri Aug 22 21:45:17 EDT 2025
Powered by FUDForum. Page generated in 0.04445 seconds
