Home » Newcomers » Newcomers » ClassNotLoadedException in Eclipse debugger
ClassNotLoadedException in Eclipse debugger [message #268905] Thu, 26 February 2009 16:36 Go to next message
1. I'm not certain this is the right forum.
2. I will be happy to file a bug should it prove necessary.
3. I apologize for cross-posting this to JavaRanch; I probably should have
posted it here first.
4. One of the places I found a reference to this problem via Google was in
an Eclipse forum, however, the circumstances may not be mine and the
poster found a work-around; so far, I have not.
This only happens when I attempt to run my JUnit test in the debugger. It
does not happen when I run my JUnit test without debugger nor does it
happen in a production run of my greater product.
What I see:
"org.eclipse.debug.core.DebugException:
com.sun.jdi.ClassNotLoadedException: Type has not been loaded occurred
while retrieving component type of array."
As the first line of my test (not in setUp(), but in the first line of
"real" code), I have:
1. public void TestQuickUser()
2. {
3. GQUser[] smacko = new GQUser[ 0 ]; <-------------
4. ProgGlobals.setJUnitTest( true );
5. .
6. .
7. .
GQUser is a class in another of the five smallish projects that make up my
application. In the project of which my JUnit test is a part of, I get it
via a JAR. Once I step past that statement, however, and I click on smacko
in the (debugger) Variables pane to see its value, the value appears as
(the exception) noted above.
This happens regardless of whether I put this code in my test method or in
setUp().
I've Googled this and found 9 results--several people have seen this, some
in exactly my same circumstances. Only 2 of them are interesting in that
they have answers and neither shows any real explanation or an encouraging
solution. One answer is by someone who completely gives up. The other one
waffles. I've also asked around a bit here, but none of my acquaintances
have ever seen it.
It would appear that the catastrophe in this is limited to ever wanting to
examine GQUser in the debugger. If I put in print statements, it appears
that things are working; it's just a disaster that I cannot look at this
in the debugger, that's all, but this class is used all over.
While my example is created to simplify what's happening (which it does
very nicely), I have a class, ProgGlobals, that must instantiate several
pieces of static final data of this class in order to function. I am
unable to see a way to program around it and I can't examine the sanity of
any of those initializations (nor subsequent assignments, uses, etc.).
Thanks for reading this and for any comments made.
Russ Bateman
Re: ClassNotLoadedException in Eclipse debugger [message #268906 is a reply to message #268905] Thu, 26 February 2009 16:39 Go to previous messageGo to next message
Uhhhh... it looks like my formatting was not retained. Here's the very
short sample:
Sorry for the mess.
QRe: ClassNotLoadedException in Eclipse debugger [message #268942 is a reply to message #268905] Sun, 01 March 2009 23:39 Go to previous message
"Russell Bateman" <russ@windofkeltia.com> wrote in message
news:ee35b7a553137cfc7c50ccca96a1d1bf$1@www.eclipse.org...
> What I see:
> 1. public void TestQuickUser() 2. { 3. GQUser[] smacko = new
> 4. ProgGlobals.setJUnitTest( true ); 5. . 6. . 7. .
> setUp().
> have ever seen it.
I'm adding eclipse.tools.jdt to the newsgroups list, because that's where
the JDT debug folks hang out.
I assume you've read, and scratched your head over the possible significance
of, the javadoc (e.g.
http://www.potu.com/man/java/guide/jpda/jdi/com/sun/jdi/Clas sNotLoadedException.html)
of the exception itself, which gives some clues but no answers.
Have you looked through the bugs in Bugzilla? I searched there for
"ClassNotLoadedException" in comments (after filtering for the Eclipse/JDT
component) and found several hits but I didn't look at them in detail.
Are you able to determine anything special about GQUser? E.g., if you made
a similar test method that started with assigning an array of some other
type, does the problem still repro?
What version of Eclipse are you running, and what version of the JRE are you
running it on?
Are there any errors in your error log (Window -> Show View -> PDE
Runtime -> Errors, or just look at .metadata/.log)?
Previous Topic:What is this means?
Next Topic:Problem with passing arguments in eclipse CDT
Current Time: Tue Jul 08 18:39:25 EDT 2025
Powered by FUDForum. Page generated in 0.32158 seconds
