Chart Object [message #26626] |
Thu, 14 April 2005 16:37  |
Is there any documentation on how to use the Chart object from within the
designer. Then's plenty of documentation on how to programmatically use
it, but not from within the designer. I'm trying to do what I thought was
a simple bar chart of the SFDATA test data showing the following from
"items":
Data X Series: row["itemcode"]
Data Y Series: Sum of row["quantity"]
Basically I just want to see the itemcode vs total bought. Yet when I try
and bind that I keep getting
ERROR MESSAGE
Semantic errors in C:\eclipse\workspace\My Reports\charttest.rptdesign.
The value of the property "keyExpr" is required.
Re: Chart Object [message #26667 is a reply to message #26626] |
Thu, 14 April 2005 19:29  |
Hi Hank,
The documentation for using the chart within the BIRT designer is under
construction. As soon as we have something available, we will try and post
it. Also, we're working on some core integration points between charts and
the BIRT reporting system which may not work at your end (depending on the
sources/binaries that you are working with).
In general, as described in a previous post, here's how you would make a
chart work in the context of a BIRT report:
A] Create a new report; define a datasource and a dataset
B] Drop in a chart; select the appropriate chart type in the chart
selector; click on DEFINE CHART or OK
C] Select the dataset binding in the 'DATA' property sheet (or leave it as
none if the chart is embedded within a parent table/grid containing a
bound dataset)
D] Define the data definition for the X series ( e.g. row["itemcode"] )
E] Define the data definition for the Y series ( e.g. row["quantity"] )
Now, if you wanted to group data, the procedure would be:
A] First, drop a table into the report design
B] Insert a group into the table; define the grouping as column 'category'
C] Insert the chart into the HEADER or FOOTER of a table; do not define a
dataset binding in the DATA property sheet because all columns from the
table's inherited dataset should be made available to the chart data
definition; hide all other rows/columns of the table that are not needed
Total.sum(row["quantity"]) )
This grouping implementation is however not yet fully implemented due to
some improvements we are making to the underlying extension framework. I
will post a message as soon as we get this done.
Note: if you get the error 'The value of the property "keyExpr" is
required.', this usually indicates that a GROUP was created without
defining a group key.
Rohit Colaço
ECE Project Lead
Subject: Chart Object
Newsgroups: eclipse.birt
Organization: not organized
Date: Apr 14 2005 15:37:42
"items":
and bind that I keep getting ERROR MESSAGE
FUDForum. Page generated in 0.03308 seconds
