| share classes [message #268806] |
Thu, 26 August 2004 08:07  |
Originally posted by: fgarriga.sam-meteo.com
I need share the same .java file in differents projects, how I do it with
eclipse ?
| Re: share classes [message #268960 is a reply to message #268820] |
Fri, 27 August 2004 05:36  |
That's ok but the files that we want to share, have references to other
files that I don't want to share. For resolve this, I refer the
sharedProject to the others project and A cycle was detected in the build
path of project (error). For example:
Project A:
not share file A
not share file B
not share file C
share file SA (reference to A)
share file SB (reference to C)
Project B:
not share file A
not share file D
Solution ->
Project A:
not share file A
not share file B
not share file C
--> reference to Common Project
Project B:
not share file A
not share file D
Common Project:
share file SA
share file SB
-> reference to Project A
-> reference to Project B
* Note: If I don't make the references in the common project to project A
ans B, common project don't compile.
Eric Rizzo wrote:
> > eclipse ?
> Projects can depend on other projects. Put the shared classes in one
> Project (called, for example, Common or Shared), then on the Properties
> dialog for other Projects you can select Project References and choose
> the Common/Shared project.
> HTH,
> Eric
FUDForum. Page generated in 0.03314 seconds
