Home » Language IDEs » AspectJ » Can Auto-Build be added to the Work Task list?
Can Auto-Build be added to the Work Task list? [message #26587] Thu, 16 October 2003 18:04 Go to next message
Originally posted by: ajdt.thewoolleyweb.com
I would really like for the autobuild to work with AJDT. In other words,
the following should still work if AspectJ is enabled:
1. Preferences - Workbench - Perform build automatically on resource
modification
2. Preferences - Debug - Build (if required) before launching.
I don't see this on the Work Task list. Is it possible to get it added?
If not, is there another list for "nice-to-haves" that don't belong on the
Work Task list?
I might even try to tackle this myself, although I have no idea how hard
it would be. I've never looked at the eclipse or ajdt source.
Chad
Re: Can Auto-Build be added to the Work Task list? [message #27194 is a reply to message #26587] Tue, 28 October 2003 03:09 Go to previous message
Originally posted by: lists.thewoolleyweb.com
I found this FAQ item:
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/org. eclipse.ajdt/faq.html#q:autobuild
This seems to imply that autobuild should work if you have all the
settings in preferences and the project as it describes.
However, in another recent post, Wes said that autobuild was not
implemented yet:
http://www.eclipse.org/newsportal/article.php?id=339&gro up=eclipse.technology.ajdt
Which is true? Should it work, and this is a bug, or is it not
implemented (in which case the faq is misleading)?
If it's a bug, I'd be glad to open a bug report. If not, could it be
added to the task list?
Chad
Chad Woolley wrote:
> modification
> Work Task list?
> Chad
Re: Can Auto-Build be added to the Work Task list? [message #572473 is a reply to message #26587] Tue, 28 October 2003 03:09 Go to previous message
implemented yet:
Chad
Chad Woolley wrote:
> modification
> Work Task list?
> Chad
Previous Topic:Sharing aspects between AspectJ projects
Next Topic:Debugging example causes "Absent Line Number Information"
Current Time: Tue Jul 08 11:58:16 EDT 2025
Powered by FUDForum. Page generated in 0.06370 seconds
