Home » Eclipse Projects » Eclipse Platform » Advanced: Emacs describe-key-binding like functionality
Advanced: Emacs describe-key-binding like functionality [message #268132] Sun, 22 August 2004 00:06 Go to next message
Originally posted by: sandipchitale.comcast.net
Emacs has a nice functionality to show what command a particular key is bound to. It is typically invoked by pressing CTRL+H, K.
I was wondering if it will be possible to do that in Eclipse.
Similarly I would like to do the reverse i.e. list all the key sequences a particular command is invoked by.
Both these should take into account current Context (scope), Key Configuration and Platform.
Is this functionality already available?
Re: Advanced: Emacs describe-key-binding like functionality [message #268141 is a reply to message #268132] Sun, 22 August 2004 09:00 Go to previous messageGo to next message
> key is bound to. ...
Not the Emacs way, but might be the KeyBinding View available at
http://fatborn.org/eclipse/plugins/bindings/
will help?
regards
___ ___
| + | |__ Georg Rehfeld Woltmanstr. 12 20097 Hamburg
|_|_\ |___ georg.rehfeld.nospam@gmx.de +49 (40) 23 53 27 10
Re: Advanced: Emacs describe-key-binding like functionality [message #268145 is a reply to message #268141] Sun, 22 August 2004 11:17 Go to previous messageGo to next message
I already have that. It is cool.
I would be great if the Keybindings View had a mechanism to select a column and filter the rows by typing a prefix.
For example on the KeySequence column could allow me to type keys to select matching rows. That could give me the functionality
partly. However describe-key-bindings like functionality is less interrupting. Expecially if the a small chromeless popup window
could be used to read a key sequence.
Sandip
"Georg Rehfeld" <georg.rehfeld@gmx.de> wrote in message news:cga5jk$okq$1@eclipse.org...
> will help?
> regards
> ___ ___
Re: Advanced: Emacs describe-key-binding like functionality [message #268244 is a reply to message #268132] Mon, 23 August 2004 11:31 Go to previous message
Check out I200408170800. Look at the Keys preference page. Also, from
anywhere in Eclipse, try "Ctrl+Shift+L".
cheers,
d.
Previous Topic:ClassLoading in 3.0-Plugins
Next Topic:[RCP] Showing multiple views
Current Time: Sat Nov 22 02:16:12 EST 2025
Powered by FUDForum. Page generated in 0.09250 seconds
