Home » Eclipse Projects » GEF » Eclipse version supported by GEF?
Eclipse version supported by GEF? [message #2226] Fri, 17 May 2002 10:32 Go to next message
Originally posted by: mhaney.NOoneSPAMshield.com
We are using WSAD 4.03, which is based on Eclipse 1.0. Will we be able to
use the GEF plugins, or are they being designed for 2.0 only?
Re: Eclipse version supported by GEF? [message #2258 is a reply to message #2226] Fri, 17 May 2002 10:49 Go to previous messageGo to next message
Originally posted by: none.ibm.com
4.03 has GEF in it already. Version 1.0.
"Mike Haney" <mhaney@NOoneSPAMshield.com> wrote in message
news:ac33m3$un0$1@rogue.oti.com...
Re: Eclipse version supported by GEF? [message #3152 is a reply to message #2258] Mon, 20 May 2002 09:27 Go to previous messageGo to next message
Is that a workable version of GEF that's in WSAD 4.03? Is it documented so
we can use it in our apps?
While we're on the subject, do you know if any of the other IBM plugins in
WSAD are documented so that we can extend them? Specifically, we would like
to extend the SQL tools.
"Randy Hudson" <none@ibm.com> wrote in message
news:ac34le$v8s$1@rogue.oti.com...
to
Re: Eclipse version supported by GEF? [message #3219 is a reply to message #3152] Mon, 20 May 2002 09:39 Go to previous messageGo to next message
so
The current documentation will be more useful than 4.03 DOC.
like
Sorry. Can't answer that. Take that question to WSAD newgroup on IBMs
server.
Re: Eclipse version supported by GEF? [message #3678 is a reply to message #3219] Wed, 22 May 2002 09:45 Go to previous messageGo to next message
Where can I find the current documentation?
news:acatj1$1gp$1@rogue.oti.com...
> so
in
> like
> server.
Re: Eclipse version supported by GEF? [message #19840 is a reply to message #3219] Mon, 16 September 2002 13:04 Go to previous messageGo to next message
Originally posted by: hd.ibm.com
Randy Hudson wrote:
> > Is that a workable version of GEF that\'s in WSAD 4.03? Is it documented
> so
Where can I find the \"current\" documentation? And what version is it?
> > While we\'re on the subject, do you know if any of the other IBM plugins in
> like
> Sorry. Can\'t answer that. Take that question to WSAD newgroup on IBMs
> server.
Re: Eclipse version supported by GEF? [message #19884 is a reply to message #19840] Mon, 16 September 2002 13:31 Go to previous message
Current documentation is included in the zip file on the download page. The doc
plugins are org.eclipse.gef.doc.isv and org.eclipse.draw2d.doc.isv. They
include integrated help through the workbench, but you may also unzip the
doc.zip file from each plugin to get direct access to the documentation.
Eric
"hd" <hd@ibm.com> wrote in message news:am52v9$nkj$1@rogue.oti.com...
> > so
in
> > like
> > server.
Previous Topic:Routing
Next Topic:Where can I locate "advanced tracing preference page" in 2.0.1
Current Time: Wed May 07 23:21:40 EDT 2025
Powered by FUDForum. Page generated in 0.03414 seconds
