Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Discovering transaction insertion point
Discovering transaction insertion point [message #26542] Thu, 02 March 2006 10:16 Go to next message
Dear all,
i'm starting the process of converting an emf/gef editor into a
transactional one. The problem i'm currently facing is the one of finding
out the point into which transaction should be inserted (i.e. where the
resource' elements are read or modified). Is it there a way to
(automatically) find out them? Looking at the source code is boring and
error prone (expecially for the gef stuff).
Best regards
Re: Discovering transaction insertion point [message #26873 is a reply to message #26542] Thu, 02 March 2006 15:17 Go to previous messageGo to next message
Please refer to the transaction examples plugin within the transaction
examples sdk or the transactions sdk. The plugin is
org.eclipse.emf.workspace.examples.library.editor
This plugin conatins an example editor
(org.eclipse.emf.workspace.examples.extlibrary.presentation. EXTLibraryEditor
) that demonstrates the integration of the TransactionalEditingDomain into
the editor. This should be a good starting point
Vishy
"sf76" <sf76@hotmail.com> wrote in message
news:dfc98f34d58f9fd47e2da564d7769674$1@www.eclipse.org...
> Dear all,
> Best regards
Re: Discovering transaction insertion point [message #26954 is a reply to message #26873] Thu, 02 March 2006 17:22 Go to previous messageGo to next message
Yes, you might be particularly interested to see how the example editor
installs custom property sources for the Properties view, to ensure that it
reads the model in read-only transactions. Perhaps this illustrates the
considerable extent to which the transaction protocol will permeate a UI
application ...
Christian
Vishy Ramaswamy wrote:
> Thanks
> Vishy
<snip>
Re: Discovering transaction insertion point [message #27032 is a reply to message #26954] Fri, 03 March 2006 08:57 Go to previous messageGo to next message
Dear all,
i've already looked at the suggested plugin and, even not being an expert
of emf, i think it is a great source of example/ideas about the
integration of the emft component into an emf editor (and i've borrowed
many of them).
The point of my question was slightly different: is it there a way in
order to discover all the places in an application that should be
converted into an emft transaction?
At the moment i'm converting a gef editor into a transactional one in
order to evaluate emft capability. Since i don't own all of the code (i.e.
gef cmd) i need to look manually at the points in which to insert emft
constructs. Forgetting one gives an IllegalStateException throwed at
runtime. Is it there a strategy or some kind of tricks in order to avoid
such problems?
Thanks again,
Best regards
Re: Discovering transaction insertion point [message #27110 is a reply to message #27032] Fri, 03 March 2006 17:25 Go to previous message
Ah, I see what you are looking for.
We do not yet have any means to assist in finding what code needs to be
"transactionalized" (if I may coin a word). We have given thought to some
potential strategies for inserting debug-time assertions into EMF and/or
generated metamodel code to check that the caller is in a transaction
context, and have mostly drawn blanks.
For now, we have only the obvious rule of thumb: whenever you're calling
code that *may* read from the model, do it in a read-only transaction.
Unless that code might also write to the model, in which case a read/write
transaction is required. The latter case is more tricky because the normal
way of creating a read/write transaction is either to execute a Command on
a CommandStack or an AbstractEMFOperation on an IOperationHistory. In
either of these cases, you want to be sure that the command/operation will
actually make some change, otherwise the Undo menu will have an ineffective
undo action on it!
Some kind of code-flow analysis tool might be able to indicate points in
your code from which the control graph will eventually enter the EMF APIs
that perform reads, but this is complicated by the sheer number of APIs in
EMF that read.
Christian
sf76 wrote:
> Dear all,
> many of them).
> such problems?
> Thanks again,
> Best regards
Re: Discovering transaction insertion point [message #571038 is a reply to message #26542] Thu, 02 March 2006 15:17 Go to previous message
Vishy
> Dear all,
> Best regards
Re: Discovering transaction insertion point [message #571147 is a reply to message #26873] Thu, 02 March 2006 17:22 Go to previous message
application ...
Christian
> Thanks
> Vishy
<snip>
Re: Discovering transaction insertion point [message #571249 is a reply to message #26954] Fri, 03 March 2006 08:57 Go to previous message
Dear all,
many of them).
such problems?
Thanks again,
Best regards
Re: Discovering transaction insertion point [message #571326 is a reply to message #27032] Fri, 03 March 2006 17:25 Go to previous message
undo action on it!
EMF that read.
Christian
sf76 wrote:
> Dear all,
> many of them).
> such problems?
> Thanks again,
> Best regards
Previous Topic:ocl newbie question
Next Topic:problem installing ocl
Current Time: Thu Jun 19 16:41:13 EDT 2025
Powered by FUDForum. Page generated in 0.05693 seconds
