Home » Newcomers » Newcomers » JFace "Composite" and "Control" Query
JFace "Composite" and "Control" Query [message #267715] Wed, 14 January 2009 07:01 Go to next message
Hi everyone..Please could you explain as to why when we are doing a JFace
application and using the "method"
protected Control createContents(Composite parent){}
the return type is Control??
Because we are using all widgets of Composite parent and also ADDING it to
the Composite object i.e. parent..
Please explain..
Re: JFace "Composite" and "Control" Query [message #267719 is a reply to message #267715] Wed, 14 January 2009 10:51 Go to previous messageGo to next message
> JFace application and using the "method"
> to the Composite object i.e. parent..
Because that is the most general type that can be returned.
createContents() does not have to return a Composite; the contents can
be any single Control (and don't forget that a Composite is a Control).
This seems obvious, so it is not clear exactly what you are asking...
Eric
Re: JFace "Composite" and "Control" Query [message #267810 is a reply to message #267719] Sat, 17 January 2009 06:49 Go to previous message
In manning i read about the hierarchy of the widget,control,composite
,button..etc..
There "Control is below Widget below which is button and Scrollable and
others..and Composite is just below Scrollable"
In SWT/Jface programs..generally the parent is Composite right??
For e.g.
public class EditorTry7 extends ApplicationWindow
public EditorTry7()
super(null);
getShell().setText("Graphical Editor ");
getShell().setBounds(200,100,600,400);
getShell().setMaximized(false);
parent.getShell().setMaximized(false);
parent.pack();
return parent;
public static void main(String args[])
EditorTry7 ET7 = new EditorTry7();
ET7.setBlockOnOpen(true);
ET7.open();
Display.getCurrent().dispose();
and the widget Button is also added to Composite object (say object name =
parent)..then how is that possible (though i have added it successfully
and executed) to add a widget to an object which is at a higher level in
the Hierarchy??!
Previous Topic:General Help
Next Topic:"Convert for loops to enhanced" save action
Current Time: Thu Jul 17 22:35:56 EDT 2025
Powered by FUDForum. Page generated in 0.37969 seconds
