Home » Eclipse Projects » Eclipse Platform » newbie treeviewer question
newbie treeviewer question [message #267649] Wed, 18 August 2004 17:29 Go to next message
Originally posted by: crf.xxxxxxx.com
i have to make a view that is kind of like the java class hierarchy
view, and i need to read all the files that are in the workspace to
show all the member variables in one view. do you know where i should
start with this? what input do i give to my contentprovider- the
workspace root? what should i do with this input in the
contentprovider? i have no idea where to start right now. ANY help
with this would be great- thank you!
thanks,
christine
Re: newbie treeviewer question [message #267669 is a reply to message #267649] Wed, 18 August 2004 19:12 Go to previous messageGo to next message
Originally posted by: rpm.motorola.com
Hey Christine....try this out to work with views
http://www.eclipse.org/articles/viewArticle/ViewArticle2.htm l
http://www-106.ibm.com/developerworks/java/library/os-ecgui1 /
the second one is more of what you need....
the first one is an intro to creating views
:wq
rohit
> thanks,
> christine
Re: newbie treeviewer question [message #267675 is a reply to message #267649] Wed, 18 August 2004 19:32 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
Add org.eclipse.ui.views to your plug-in dependency list and
then do Ctrl-Shift-T 'ResourceNavigator'. It uses a treeviewer.
See getInitialInput();
The Java Package Explorer uses the JavaModel, which may be
more than you want to.
Chris
"Christine Francis" <crf@xxxxxxx.com> wrote in message
news:qbi7i0pnhhnuetpt1vg5tf0soiqebuu95b@4ax.com...
> thanks,
> christine
Re: newbie treeviewer question [message #268111 is a reply to message #267669] Fri, 20 August 2004 22:54 Go to previous message
This one is *really* well done, my respect, thanks and best regards to
the author Dave Springgay! It covers/touches almost every aspect of
view programming "the right way". Read it, if you haven't already,
reread, if you have. You might find yourself having forgotten about
Eclipse views "good practice" somewhere.
Thanks Rohit for these pointers
Georg
___ ___
| + | |__ Georg Rehfeld Woltmanstr. 12 20097 Hamburg
|_|_\ |___ georg.rehfeld.nospam@gmx.de +49 (40) 23 53 27 10
Previous Topic:Eclipse 3.0, Ant and the Ant input tag...
Next Topic:Action-How to activate via Keystroke (does not work)
Current Time: Sun Nov 09 05:38:27 EST 2025
Powered by FUDForum. Page generated in 0.16300 seconds
