JVM crash when rendering the BIRT report [message #1478620] |
Tue, 18 November 2014 15:57  |
Hi ,
We are getting JVM crash daily once when one of BIRT renders.
below is from hs_err)pid log file. we are using birt 2.6.2 version.
# JRE version: 6.0_26-b03
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.1-b02 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# J org.eclipse.birt.chart.computation.withaxes.PlotWith2DAxes.getSeriesRenderingHints(Lorg/eclipse/birt/chart/model/data/SeriesDefinition;Lorg/eclipse/birt/chart/model/component/Series;)Lorg/eclipse/birt/chart/render/ISeriesRenderingHints;
RAX=0x0000000716f33170 is an oop
java.lang.Double
- klass: 'java/lang/Double'
RBX=0x0000000045446890 is pointing into the stack for thread: 0x000000005f24a800
RCX=0x000000000000001a is an unknown value
RDX=0x0000000000000000 is an unknown value
RSP=0x0000000045446810 is pointing into the stack for thread: 0x000000005f24a800
RBP=0x00000000fdc92418 is an unknown value
RSI=0x00000007ee8035c0 is an oop
org.eclipse.birt.chart.computation.DataSetIterator
- klass: 'org/eclipse/birt/chart/computation/DataSetIterator'
RDI=0x00000007ee8037d8 is an unknown value
R8 =0x0000000000000000 is an unknown value
R9 =0x00000000dda902ce is an unknown value
R10=0x40462aaaaaaaaaaa is an unknown value
R11=0x0000000000000000 is an unknown value
R12=0x0000000000000000 is an unknown value
any suggestion? thanks in advance.
FUDForum. Page generated in 0.28432 seconds
