Home » Newcomers » Newcomers » problems with plugins
problems with plugins [message #267146] Wed, 17 December 2008 07:07 Go to next message
i'm new to eclipse. We have eclipse 3.2 running on a SuSE 10.2 linux
system. I installed the packages via rpm/yast. Then we tried to install
some plugins.
First we used a normal useraccount. This ends up with errors. Then we
installed some plugins as root. This installation suceed. But when i look
as a user in Help ==> Software Updates ==> Manage Configuration ==> View
Installation History,
i don't see the plugins which i installed as root.
Whem i look as root in "View Installation History", i see of course the
plugins.
Questions: Are the plugins which i installed as root usable for all other
users ?
If not, how can i install plugins as a normal user with root rights ?
Thanks in advance.
Bernd
Re: problems with plugins [message #267149 is a reply to message #267146] Wed, 17 December 2008 07:19 Go to previous messageGo to next message
Sorry, of course i mean as a normal user without root rights.
Bernd
Re: problems with plugins [message #267152 is a reply to message #267146] Wed, 17 December 2008 07:50 Go to previous messageGo to next message
> some plugins.
If you have problem with SuSE's packages, then you should consult with
the SuSE packaging team as I'd imagine they've packaged it in some way
wherein it's intended to be usable in some sort of a multi-user setup.
I'd suggest getting the Eclipse binary from eclipse.org personally.
In any case, this document may help.
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/multi_user_installs.html
Remy
Re: problems with plugins [message #267169 is a reply to message #267152] Thu, 18 December 2008 03:36 Go to previous message
"Remy Chi Jian Suen" <remy.suen@gmail.com> wrote in message
news:giasik$rh3$1@build.eclipse.org...
>> some plugins.
> If you have problem with SuSE's packages, then you should consult with the
> SuSE packaging team as I'd imagine they've packaged it in some way wherein
And I'd suggest getting an up to date version of Eclipse. 3.2 is two and a
half years old, we're up to 3.4.2 now.
Previous Topic:Class Loading
Next Topic:Open Type/Open Resource error with Eclipse Ganymede
Current Time: Wed Jul 16 17:07:26 EDT 2025
Powered by FUDForum. Page generated in 0.12382 seconds
