Home » Newcomers » Newcomers » eclipse for solaris
eclipse for solaris [message #267073] Fri, 12 December 2008 11:18 Go to next message
Can someone point me to the packages for eclipse on Solaris 10 x86.
Many thanks
Re: eclipse for solaris [message #267077 is a reply to message #267073] Fri, 12 December 2008 12:02 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
http://www.eclipse.org/ > click "Download Eclipse" >
http://www.eclipse.org/downloads/ > click "Eclipse Classic - Other
Downloads" >
http://download.eclipse.org/eclipse/downloads/ > click 3.4.1 >
http://download.eclipse.org/eclipse/downloads/drops/R-3.4.1- 200809111700/index.php
> click Solaris >
http://www.eclipse.org/downloads/download.php?file=/eclipse/ downloads/drops/R-3.4.1-200809111700/eclipse-SDK-3.4.1-solar is-gtk.zip
> pick a mirror > download zip.
Then install whatever else you need via
Help > Software Updates > Available Software > Ganymede site > ...
Nick
Mahesh wrote:
> Hi
> Many thanks
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: eclipse for solaris [message #267090 is a reply to message #267077] Sat, 13 December 2008 15:00 Go to previous messageGo to next message
Thanks Nick.
I downloaded: unfortunately it seems to the build is for Solaris on Sparc.
Is there a build for Solaris 10 on x86.
Mesh
Re: eclipse for solaris [message #267091 is a reply to message #267090] Sat, 13 December 2008 23:43 Go to previous messageGo to next message
If your platform/OS combination is not listed on the eclipse.org site,
then you'll have to build it yourself.
Googling, I found these:
http://blogs.zdnet.com/Burnette/?p=112
http://rollerweblogger.org/roller/entry/eclipse_for_solaris_ x86_no
http://wiki.blastwave.org/
And finally, this:
http://code.google.com/p/solipse/wiki/BasicHowToBuild
Mahesh wrote:
> Thanks Nick.
> Cheers, Mesh
Re: eclipse for solaris [message #267095 is a reply to message #267091] Sun, 14 December 2008 20:15 Go to previous messageGo to next message
Thanks Nick.
I attempted to compile eclipse on x86 but found that it needed sunstudio
which is defendant on netbeans5.5.5. I had netbeans6.5 installed and I
could not find a way to tell sunstudio to use my version.
Anyway I have now installed solaris 2008.11 in VirtualBox and have found a
version of eclipse that works on that platform.
I'm getting there !
Cheers
Re: eclipse for solaris [message #267096 is a reply to message #267095] Mon, 15 December 2008 00:36 Go to previous messageGo to next message
If you're running VirtualBox why not pick a linux that's supported by
Eclipse, like Fedora 10? If you run Fedora 10 in a VBox instance,
Eclipse is available as an .rpm, so you can install it simply with `yum
install eclipse...`
http://spins.fedoraproject.org/ (eg., Developer spins)
http://fedoraproject.org/en/get-fedora (other options)
I have the following rpms installed:
eclipse-ecj-3.4.1-5.fc10.i386
eclipse-swt-3.4.1-5.fc10.i386
eclipse-rcp-3.4.1-5.fc10.i386
eclipse-platform-3.4.1-5.fc10.i386
eclipse-jdt-3.4.1-5.fc10.i386
eclipse-pde-3.4.1-5.fc10.i386
Of course other linuxes work too (debian, ubuntu, gentoo), Fedora's just
nice because it comes with a JDK that actually works with Eclipse
(OpenJDK 6), so you don't have to remove gcj and/or install something by
hand.
$0.02,
Nick
Mahesh wrote:
> Thanks Nick.
> a version of eclipse that works on that platform.
> I'm getting there !
> Cheers
Re: eclipse for solaris [message #267100 is a reply to message #267096] Mon, 15 December 2008 03:59 Go to previous messageGo to next message
I've eclipse working (well the gui appears, have not tried anything else
yet) on my platform. If I have issues I will take your suggestion with
Fedora.
Just need to install ZK Studio and attempt to learn.
My aim is to create a small app which can record time spent on a task.
Record that info in a dB and produce some graphs.
So
Input from the user:
user A spent x time on task y
user B spent x time on task z
user A spent x time on task z
Info stored in db (mysql)
Output = graph with various options ie
graph for task(s)
graph per user
graph for all users
graph over time for task
I've lots of learning to do as I'm a complete newbie :)
Thanks for your advice.
Re: eclipse for solaris [message #267107 is a reply to message #267100] Mon, 15 December 2008 09:43 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Some of this is already done with the Mylyn plugin for eclipse. I think
there is even a report plugin for Mylyn that will produce the graph you
mention.
Dave
> Fedora.
> So Input from the user:
> user A spent x time on task y user B spent x time on task z user A spent
> x time on task z
> Output = graph with various options ie graph for task(s)
> graph per user
> graph for all users
Re: eclipse for solaris [message #267108 is a reply to message #267107] Mon, 15 December 2008 14:13 Go to previous messageGo to next message
Still more of it is done in Tasktop, which extends Mylyn.
http://tasktop.com/products/tour/
I don't think they back into a database, however. I suspect it's just
XML files.
> mention.
> Dave
>> else yet) on my platform. If I have issues I will take your suggestion
>> with Fedora.
>> graph per user
>> graph for all users
Re: eclipse for solaris [message #267264 is a reply to message #267107] Tue, 23 December 2008 09:15 Go to previous messageGo to next message
Thanks Dave - I'll have a look at the pluggin.
Re: eclipse for solaris [message #267266 is a reply to message #267108] Tue, 23 December 2008 09:28 Go to previous messageGo to next message
Thanks for the pointer.
TaskTop / Mylyn seem very good - probably too complicated for what I need.
My intention was to use ZK - they have a charting zul - have a look
(http://www.zkoss.org/zkdemo/userguide/#d2). So my intention is use the
front end and plug it into a dB.
Unfortunately - I'm having problems downloading Web Tool Platform 3.0.3
(WTP) as there seems to be a dependency on installing which I can't find.
The dependency
is :
requires feature "org.eclipse.platform (3.4.0)", or compatible.
Any ideas on how to get the dependency. I'll also mail on the elcipse WTP
forum.
Thanks for your help guys.
Re: eclipse for solaris [message #267269 is a reply to message #267266] Tue, 23 December 2008 09:33 Go to previous messageGo to next message
You need to be running Eclipse 3.4. to install Web Tools 3.0.3.
Dave
Mahesh wrote:
> Thanks for the pointer. TaskTop / Mylyn seem very good - probably too
> find. The dependency is :
> WTP forum.
Re: eclipse for solaris [message #267274 is a reply to message #267269] Tue, 23 December 2008 11:58 Go to previous messageGo to next message
I have 3.2 installed.
I attempt to install WTP 3.0.2 - I get the following:-
Requested operation cannot be performed because it would invalidate the
current configuration. See details for more information.
Web Page Editor (Optional) (2.0.1.v20080811-32-9oA55S5M5J) requires
plug-in "org.eclipse.emf.ecore (2.2.0)", or compatible.
Apache MyFaces Trinidad Tag Support (Optional)
(2.0.1.v200808071446-1-8Y7w311919182557) requires plug-in
"org.eclipse.emf.ecore.xmi (2.2.0)", or compatible.
XSL Tools (Incubating) (0.5.0.v200808041223-6872EC3wSUIU7eJGVdY_1)
requires feature "org.eclipse.wst.xml_ui.feature (3.0.0)", or compatible.
How do I get these plugs?
My aim is to install the zk studio plugin which requires WTP.
The only reason I'm using eclipse version 3.2 is that its the only version
I can find that works on Solaris 10 x86 my preferred operating system.
Thanks again
Re: eclipse for solaris [message #267277 is a reply to message #267274] Tue, 23 December 2008 13:16 Go to previous messageGo to next message
If you stick with Eclipse 3.2, you can only run WTP 1.5. Here's the latest.
http://archive.eclipse.org/webtools/downloads/drops/R1.5/R-1 .5.5-200708291442/
For Eclipse 3.3, you can use WTP 2, which requires EMF 2.3.
For Eclipse 3.4, you can use WTP 2, which requires EMF 2.4.
You might want to try solipse, aka Eclipse 3.4 for Solaris x86:
Or, failing that, Fedora 10, ubuntu 8.10... or any of the other 'nixes
which ARE supported. :)
> My aim is to install the zk studio plugin which requires WTP. The only
> reason I'm using eclipse version 3.2 is that its the only version I can
> Thanks again
Re: eclipse for solaris [message #267280 is a reply to message #267277] Tue, 23 December 2008 15:08 Go to previous messageGo to next message
If you want ZX Studio to work in Ganymede (Eclipse 3.4), you'll want to
make sure you're getting version 0.8 - see
http://www.zkoss.org/smalltalks/zkstudio0.8/
Hope this helps,
Eric
>> the current configuration. See details for more information.
>> Thanks again
Re: eclipse for solaris [message #267283 is a reply to message #267280] Wed, 24 December 2008 04:03 Go to previous messageGo to next message
Nick -thanks for the great link that explains how to build Eclipse for
Solaris x86. Unfortunately, the build did not work for me - issues with
the Make file and to debug (imo) will take a lot of time.
It seems I'm hitting a big brick wall (and its hurting). It looks like I
need a new build of Eclipse to run ZK Studio (thanks for the info Eric)
which is not easily available for my OS (Solaris 10 x86).
So, it looks like the option for me is (which Nick suggested) to install
Fedora 10 - ubuntu 8.10 in a VM and go from there. I've been using
Solaris for many years, another unix OS will be a bit of a learning curve
- but learning is good :).
If you have any other suggestions, please let me know.
Have a great Christmas - thanks for your help.
> Hope this helps,
> Eric
Re: eclipse for solaris [message #267308 is a reply to message #267283] Wed, 24 December 2008 11:53 Go to previous message
You can run the live CD in a Vbox or VMware session. Or you can copy the
live CD image [1] onto a USB key [2], and reboot your box from that key
for faster performance and pervasive storage. 2G or larger recommended.
[1] http://fedoraproject.org/en/get-fedora
[2] https://fedorahosted.org/liveusb-creator/
Of course Fedora's not the only choice, but it's one I use and thus
recommend. :)
Nick
> I need a new build of Eclipse to run ZK Studio (thanks for the info
> Eric) which is not easily available for my OS (Solaris 10 x86).
> curve - but learning is good :).
>> to make sure you're getting version 0.8 - see
>> Hope this helps,
>> Eric
>>> latest.
Previous Topic:Xp themes in Linux
Next Topic:no multiline search and replace
Current Time: Tue Jul 22 08:28:38 EDT 2025
Powered by FUDForum. Page generated in 0.38126 seconds
