Home » Modeling » OCL » setInstanceContext() method
setInstanceContext() method [message #26406] Fri, 01 June 2007 20:30 Go to next message
Originally posted by: asma.charfi.com
Hi Christian,
concerning the bug 189981,I changed
helper.setInstanceContext((Classifier)classifiers.get(0));
but parsing did not succed. here is the exeption :(Cannot find operation
(getAllAttributes()) for the type (OclAny))
here is the value of helper.getContextClassifier()
"org.eclipse.ocl.uml.impl.AnyTypeImpl@1eac903 (name: <unset>, visibility:
<unset>) (isLeaf: false, visibility: public, isAbstract: false)"
So I added the "helper.setContext((Classifier)classifiers.get(0))"
the value of helper.getContextClassifier() is
"org.eclipse.uml2.uml.internal.impl.StereotypeImpl@f9d4f7 (name: Client,
visibility: <unset>) (isLeaf: false, visibility: public, isAbstract: false)
(isActive: false, isAbstract: false)"
but the same problem persist: ERROR in (operationCallExpCS): (Cannot find
operation (getAllAttributes()) for the type (Client)).
(isLeaf:
what sould I do?
thanks
asma
Re: setInstanceContext() method [message #26444 is a reply to message #26406] Fri, 01 June 2007 12:17 Go to previous messageGo to next message
Hi, Asma,
That's bizarre. When I change the test_parseStereotypeConstraint() method
of the ProfilesTest class (in the org.eclipse.ocl.uml.tests plug-in) to
look like the following:
public void test_parseStereotypeConstraint() {
helper.setInstanceContext(testStereotype); // a Stereotype
try {
Constraint constraint = helper.createInvariant(
"self.getAllAttributes()->exists(name = 'yesno')");
// the 'Stereo1' Stereotype has an attribute named 'yesno'
assertTrue(ocl.check(testStereotype, constraint));
} catch (Exception e) {
fail("Failed to parse or evaluate: " + e.getLocalizedMessage());
it works just fine. So, I'm not sure what is different in your situation.
If you can send me a ZIPped up Eclipse project with an example of your code
that doesn't work, then I may be better able to figure out what's going
wrong.
Christian
charfi asma wrote:
> Hi Christian,
> false) (isActive: false, isAbstract: false)"
> (isLeaf:
> what sould I do?
> thanks
> asma
Re: setInstanceContext() method [message #26639 is a reply to message #26406] Mon, 04 June 2007 14:05 Go to previous messageGo to next message
Hi, Asma,
Testing this with your code that you sent me (thanks) revealed what I should
have seen sooner: that the stereotype constraint was attempting to access
the getAllAttributes() operation in the Client stereotype (which does not
exist) instead of in the Class metaclass that Client extends. It had
nothing to do with requiring setInstanceContext() which, actually, is not
correct; sorry about that.
So, you need the following:
self.base_Class.getAllAttributes()->select(name->exists(name='adresse'))- >size()>0
instead of
self.getAllAttributes()->select(name->exists(name='adresse'))- >size()>0
Then, everything should work as you expect. The constraint *seemed* to work
using the Ecore environment because it was looking at the metamodel: the
Stereotype EClass, which does defined a getAllAttributes() operation
(inherited from Classifier). It would pass because Client, itself, defines
an "adresse" attribute). However, the stereotype constraint needs to be
parsed at the model level because a profile is a UML model, so
setInstanceContext() is appropriate (as you tried, below). Just include
the navigation of the base_Class extension end and all should be well.
Christian
charfi asma wrote:
> Hi Christian,
> (isLeaf:
> what sould I do?
> thanks
> asma
Re: setInstanceContext() method [message #26678 is a reply to message #26639] Tue, 05 June 2007 03:53 Go to previous messageGo to next message
Hi Christian,
thank you very much the constraint is parsed very well!
but when I try to evaluate it using
ocl.evaluate(helper.getContextClassifier(),parsed);
or ocl.check((helper.getContextClassifier(),parsed) evaluation did not work
the exeption is "no such property base_Class) but the stereotype Client has
a base_Class property !!!
the value of helper.getcontexteClassifier() is
"org.eclipse.uml2.uml.internal.impl.StereotypeImpl@b1be82 (name: Client,
(isActive: false, isAbstract: false)[OCL] variableExpCS: Variable
Expression: self"
thank you Christian
"Christian W. Damus" <cdamus@ca.ibm.com> a
Re: setInstanceContext() method [message #26803 is a reply to message #26678] Tue, 05 June 2007 09:41 Go to previous messageGo to next message
Hi, Asma,
Have a look at the update of your project that I sent you.
When you evaluate an OCL constraint on a model element, you must evaluate it
on that element, not its metaclass.
Try this:
ocl.evaluate(<selected element>, parsed);
ocl.check(<selected element>, parsed);
Christian
charfi asma wrote:
> Hi Christian,
> work
> has a base_Class property !!!
> false) (isActive: false, isAbstract: false)[OCL] variableExpCS: Variable
> Expression: self"
> thank you Christian
> "Christian W. Damus" <cdamus@ca.ibm.com> a �rit dans le message de news:
> f41k9l$6lk$1@build.eclipse.org...
<snip>
Re: setInstanceContext() method [message #27159 is a reply to message #26803] Thu, 07 June 2007 20:02 Go to previous messageGo to next message
Hi christian,
thank you very much. it works but only when I write this:
constraint parsed=null;
parsed=helper.createrInvariant(body);
a=ocl.check(objectselected,parsed) it works perfectly!
but when I change to:
org.eclipse.ocl.uml.OCLExpression parsed=null;
parsed = helper.createQuery(body);
a=ocl.check(objectselected, parsed);
it always return false and here is my console:
[OCL] Result : org.eclipse.uml2.uml.internal.impl.ClassImpl@adb3f (name:
Client1, visibility: <unset>) (isLeaf: false, visibility: public,
isAbstract: false) (isActive: false, isAbstract: false)
[OCL] Evaluate: self.base_Class.getAllAttributes()->select(temp1 : Property
| Set {temp1.name}->exists(temp2 : String |
temp1.name.=('adresse')))->size().>(0)
[OCL] Result : OclInvalid
thank you very much!
Re: setInstanceContext() method [message #27199 is a reply to message #27159] Thu, 07 June 2007 11:32 Go to previous messageGo to next message
Hi, Asma,
You would want to use the helper.createInvariant(body) method, anyway, if
you're dealing with constraints, because it validates the well-formedness
of the constraint (including that it is a boolean-valued expression,
doesn't use @pre, etc.)
The query expression doesn't work for you because the helper returns an
OCLExpression that isn't contained by an ExpressionInOCL, which is required
in order to determine the context classifier and whether that classifier is
a stereotype. The consequence of this is that the query is evaluated on
the base Element (which doesn't make sense, resulting in OclInvalid)
instead of on the stereotype instance.
Christian
charfi asma wrote:
> Hi christian,
> [Property
> f43p4k$kj$1@build.eclipse.org...
>> Hi, Asma,
>> it
>> Try this:
>> Cheers,
>> Christian
>> charfi asma wrote:
>>> Hi Christian,
>>> work
>>> Expression: self"
>>> thank you Christian
>>> "Christian W. Damus" <cdamus@ca.ibm.com> a ?rit dans le message de news:
>> <snip>
Re: setInstanceContext() method [message #27340 is a reply to message #27199] Fri, 08 June 2007 03:56 Go to previous message
Hi christian,
it was well explained!
asma
Previous Topic:[Announce] MDT OCL 1.1.0 I200706071327 is available
Next Topic:[Announce] MDT OCL 1.1.0 1.1RC3 is available
Current Time: Wed Jul 16 17:22:55 EDT 2025
Powered by FUDForum. Page generated in 0.04937 seconds
