Home » Newcomers » Newcomers » Unreachable code
Unreachable code [message #266271] Thu, 13 November 2008 10:31 Go to next message
Somewhere in Preferences->Java->Compiler->Errors/Warnings, I have a
setting that denies me the possibility of inserting a premature return
statement while debugging.
Frequently, I don't want to execute the statements after that point and I
don't want always to have to comment out the rest of the method.
But, neither can I figure out what (Europa) severity level equates to the
compiler error so I can change it to a warning. If someone knows the name
of this option, or whether it is even an option, please inform me.
Russ Bateman
Re: Unreachable code [message #266273 is a reply to message #266271] Thu, 13 November 2008 10:40 Go to previous messageGo to next message
--------------000108060307070300030202
Russ,
I'm not sure you can turn this off something that's required to be a
diagnosed error by the Java specification. Here's the trick I use instead.
if (true) return;
> and I don't want always to have to comment out the rest of the method.
> the compiler error so I can change it to a warning. If someone knows
> the name of this option, or whether it is even an option, please
> inform me.
> Russ Bateman
<html>
<head>
http-equiv="Content-Type">
</head>
Russ,<br>
<br>
Re: Unreachable code [message #266277 is a reply to message #266271] Thu, 13 November 2008 10:55 Go to previous messageGo to next message
> inform me.
There's no such option.
Dani
> Russ Bateman
Re: Unreachable code [message #266282 is a reply to message #266271] Thu, 13 November 2008 11:37 Go to previous message
Thanks, the if( true ) thing will work.
Previous Topic:How to remove/replace the default binding scheme
Next Topic:inserting extracted methods in bottom-up order (before calling method)
Current Time: Sun Aug 31 18:59:44 EDT 2025
Powered by FUDForum. Page generated in 0.16899 seconds
