Using team / cvs support in own apps [message #266257] |
Tue, 10 August 2004 14:39 |
Originally posted by: fhellerhoff.yahoo.de
Has anybody ever used the eclipse team/cvs packages in own apps or plugins
and and can give my a brief desc. how to use this?
Thanks in advance,
Friedhelm
Re: Using team / cvs support in own apps [message #266517 is a reply to message #266417] |
Wed, 11 August 2004 16:36 |
Thank you very much for this info, it helps me to understand the usage.
Friedhelm
Jean-Michel Lemieux wrote:
> The CVS plug-in was not designed to work directly on java.io.File.
> Team support is based on the IResource plug-in. If you RCP application
> includes the IResource plug-in and you have views that contain elements
> that adapt (e.g. IAdaptable) to IResource, then Team plug-ins will just
> work. In your view ensure that you allow ADDITIONS to your context menu
> and then the Team menu should appear.
> Jean-Michel
FUDForum. Page generated in 0.03533 seconds
