Home » Newcomers » Newcomers » SQL File & Version
SQL File & Version [message #265864] Mon, 27 October 2008 04:48 Go to next message
Hi All
I installed version 3.4 on my pc (windows) and have been looking at a few
tutorials on the web such as the one found here:
http://www.vogella.de/articles/EclipseDataToolsPlatform/arti cle.html
In section 5.1 of the tutorial you are told to create a SQL File but I
somehow do not have that option. Any ideas as to why I cannot see that
option ?
Also I have noticed that when I select "Help" and "About Eclipse....."
(not sure of the exact wording) but I want to check the version of
Eclipse. The window indicting the version does not appear.
I do recall updating my pc last week and I do know that I was on version
3.4.
Help or some advice is much appreciated.
Re: SQL File & Version [message #265914 is a reply to message #265864] Tue, 28 October 2008 09:29 Go to previous messageGo to next message
On 10/27/2008 4:48 AM, simon wrote:
> Hi All
> few tutorials on the web such as the one found here:
> option ?
Remember that Eclipse is a platform and has lots of separate plugins
that provide various functionality. You probably did not download a
package that includes the Data Tools plugins (at
http://www.eclipse.org/downloads/ only the "IDE for Java EE Developers"
and "IDE for Java and Report Developers" packages includes Data Tools).
However, it is easy to install the Data Tools plugins into your Eclipse.
Just go to Help > Software Updates. On the Available Software tab, find
the Ganymede entry in the tree, expand it and check the Database
Development branch. Then click the Install button to install all of
those plugins.
Hope this helps,
Eric
Re: SQL File & Version [message #265927 is a reply to message #265914] Wed, 29 October 2008 03:32 Go to previous messageGo to next message
HI Eric
Thanks for the reply but I have done all that you told me and its still
the same. Also how come can I not see the version number and build of
Eclipse ?
Kind Regards,
Simon
Re: SQL File & Version [message #265934 is a reply to message #265927] Wed, 29 October 2008 11:09 Go to previous messageGo to next message
On 10/29/2008 3:32 AM, simon wrote:
> HI Eric
> Eclipse ?
What do you see in the About box, if not the version number?
Are you certain that you are running Eclipse with a Java 5 VM, according
to http://wiki.eclipse.org/Eclipse.ini and
http://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F#Find_the _JRE
Also, what OS is this on? If Linux, see also
< http://wiki.eclipse.org/IRC_FAQ#I_just_installed_Eclipse_on_ Linux.2C_but_it_does_not_start._What_is_the_problem.3F>
Hope this helps,
Eric
Re: SQL File & Version [message #265978 is a reply to message #265934] Fri, 31 October 2008 04:19 Go to previous message
Hi Eric
Thanks for all your help, your last message pointed me in the right
direction. I was running on my XP machine the latest Java VM and when i
installed Java 5 as you recommended I no longer had any problems.
Thanks again
Simon
Previous Topic:Loading resources via Classloader
Next Topic:How to make Server/Tomcat pick up dynamic properties file in WEB-INF/classes
Current Time: Mon Jul 21 13:12:35 EDT 2025
Powered by FUDForum. Page generated in 0.09170 seconds
