Home » Eclipse Projects » Eclipse Platform » LauncherConfigurationDelegate
LauncherConfigurationDelegate [message #265701] Fri, 06 August 2004 08:21 Go to next message
i try to access a plugin from a LauncherConfigurationDelegate. But i get a
ClassNotFoundException. I have no idea why this problem occurs.
Thanks for any help in advance.
Andreas
Re: LauncherConfigurationDelegate [message #265778 is a reply to message #265701] Fri, 06 August 2004 13:36 Go to previous message
Your plugins runtime requirements are not set up correctly.
In your plugin.xml you will need to add an import for the plugin containing
the class that is not found.
As an example, for LaunchConfigurationDelegate and the launch configuration
framework you will need debug core.
<requires>
<import plugin="org.eclipse.debug.core"/>
</requires>
HTH
Darins
"Andreas Br
Previous Topic:How to set java.library.path for VMRunnerConfiguration
Next Topic:Console with inputstream/outputstream
Current Time: Mon Jul 14 23:05:00 EDT 2025
Powered by FUDForum. Page generated in 0.67858 seconds
