Home » Archived » BIRT » Setting parameters via API
Setting parameters via API [message #265037] Thu, 24 January 2008 16:53 Go to next message
Originally posted by: pmills.systemcore.ca
I'm missing something that I suspect must be obvious. Using the report
engine API, I have no problem running and rendering a report. I also see
calls to find out all kinds of information about report parameters through
the IGetParameterDefinitionTask. What I don't see is the mechanism for
setting a parameter.
Let's say I schedule a report to run every Sunday night to calculate the
past week's activity. In my scheduler code (Java), I know the start and
end times, which I want to map to '?' parameters in my SQL. What chain of
events has to happen?
Re: Setting parameters via API [message #265043 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous messageGo to next message
Phillip,
In the report engine api the run task and the runandrendertask have
methods that use task.setParameterValue(s)
either use task.setParameterValue(parmname, parmvalue)
task.setParameterValues(parmmap);
IGetParameterDefinitionTask is used to get parameter info, primarily to
build user entry dialogs.
Jason
Re: Setting parameters via API [message #265056 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Thanks! I'll have a look in that direction.
(A "BIRT Cookbook" would be wonderful. There's a big contrast between the
helpfulness of the report design tutorials and the bare API listings in the
programming sections of Eclipse help books.)
Re: Setting parameters via API [message #265756 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #265768 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #266481 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #266491 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #267203 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #267216 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #267908 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #267919 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #268613 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #268624 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #269325 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #269336 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #270053 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #270062 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #270762 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #270773 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #271476 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #271489 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #272216 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #272229 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #272781 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #272789 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #273087 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #273091 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #273530 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #273538 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #273933 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #273941 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #274312 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #274320 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #274703 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #274711 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #275089 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #275094 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #275486 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #275493 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #275884 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #275892 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #276276 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #276284 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #276677 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #276685 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #277079 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #277087 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #277459 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #277466 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #277874 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #277881 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #278248 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #278255 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #278653 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #278662 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #279048 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #279056 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #279464 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #279472 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #279832 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #279841 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #280227 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #280234 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #280624 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #280633 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #281022 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #281030 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #281418 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #281424 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #281812 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #281820 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #282200 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #282208 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #282598 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #282605 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #282995 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #283003 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #283389 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #283397 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #283783 is a reply to message #265037] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #283790 is a reply to message #265043] Fri, 25 January 2008 08:46 Go to previous message
Previous Topic:Using Parameters in JDBC Connection String
Next Topic:Setting parameters via API
Current Time: Fri Oct 24 17:32:21 EDT 2025
Powered by FUDForum. Page generated in 0.19013 seconds
