Home » Newcomers » Newcomers » Delete project (especially on Mac)
Delete project (especially on Mac) [message #264955] Sat, 27 September 2008 22:48 Go to next message
Hi there,
I'm using a Mac and new to Eclipse, and managed to mess up my first
attempts at building projects. (This is fine, I've gotten a project to
build successfully since.)
Then I wanted to delete the messed up projects, and couldn't find anything
in the "File" menu that enables this. "Delete project" in the help search
didn't bring anything up either, so I was stuck.
I found an online tutorial at <a
href=" http://www.cs.umd.edu/class/sum2005/cmsc131/EclipseTutorial/ advanced.html"> http://www.cs.umd.edu/class/sum2005/cmsc131/EclipseTutorial/ advanced.html</a>
which gives the tip of right-clicking on the project in the package
viewer, which gives a menu with a delete option.
So on a Mac, if you want to delete a project entirely, control + click on
the project and you'll get a menu that gives you this option.
-Dominic
Re: Delete project (especially on Mac) [message #264956 is a reply to message #264955] Sun, 28 September 2008 07:35 Go to previous messageGo to next message
Dominic,
Selecting one and using the menubar's Edit menu works as well...
Dominic Widdows wrote:
> Hi there,
> anything in the "File" menu that enables this. "Delete project" in the
> help search didn't bring anything up either, so I was stuck.
> on the project and you'll get a menu that gives you this option.
> -Dominic
Re: Delete project (especially on Mac) [message #264997 is a reply to message #264955] Mon, 29 September 2008 12:05 Go to previous message
On 9/27/2008 10:48 PM, Dominic Widdows wrote:
> Hi there,
On Windows, using the Delete key when a project is selected will do it,
too. I'd be surprised if that doesn't have some equivalent on OS X.
Eric
Previous Topic:Insert spaces for tabs
Next Topic:Simple way to create bean setter/getter methods?
Current Time: Mon Jul 21 22:02:22 EDT 2025
Powered by FUDForum. Page generated in 0.09556 seconds
