Converting installation from JEE Dev package to Eclipse Classic [message #264940] |
Fri, 26 September 2008 17:02  |
Originally posted by: spayne.s4isystems.com
Hello all,
This seems like it should be an easy question but for some odd reason I
am unable to get it working:
We have a workstation here with the "Eclipse IDE for Java EE Developers
(163 MB)" package installed and are trying to install Aptana as a plugin
for it (this is using Eclipse 3.4 by the way). Unfortunately, Aptana
requires a package with the Eclipse SDK, but we have a number of plugins
and configuration settings already applied for the installed package. We
tried using P2 to install "Eclipse SDK" and "Eclipse Platform SDK" and
neither will install, throwing errors. How do we convert our existing
installation into the Eclipse Classic installation without download and
having to reconfigure everything - or better yet, what plugins do we
have to download to get Aptana to work properly? Thank you!
Sean Payne
S4i Systems, Inc.
Re: Converting installation from JEE Dev package to Eclipse Classic [message #264942 is a reply to message #264940] |
Fri, 26 September 2008 18:28  |
Originally posted by: codeslave.ca.ibm.com
If you compare what's in the JEE vs. Classic packages, you'll see all
you're missing is source:
http://www.eclipse.org/downloads/packages/compare-packages
Are you running with Sun JDK 5 or 6?
Sean Payne wrote:
> Hello all,
> Sean Payne
> S4i Systems, Inc.
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
FUDForum. Page generated in 0.07440 seconds
