Home » Eclipse Projects » e(fx)clipse » Log message during startup
Log message during startup [message #1469427] |
Tue, 11 November 2014 15:47 |
Uwe San Messages: 119 Registered: January 2012 |
when I'm starting up my e(fx)clipse E4 application, I see the following output on my console:
!ENTRY org.eclipse.equinox.ds 1 0 2014-11-11 16:39:12.087
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.adapterservice. The reference is: Reference[name = AdapterProvider, interface = org.eclipse.fx.core.adapter.AdapterProvider, policy = static, cardinality = 0..n, target = null, bind = registerAdapterProviderService, unbind = unregisterAdapterProviderService]
It's really not a big issue, but I would like to know where this comes from and if there's a way to get rid of it.
Uwe
Re: Log message during startup [message #1469645 is a reply to message #1469427] |
Tue, 11 November 2014 19:54 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Hard to tell. Did you try to turn on tracing? What types of
AdapterProvider instances are registered?
Tom
On 11.11.14 16:47, Uwe San wrote:
> Cheers,
> Uwe
Re: Log message during startup [message #1470409 is a reply to message #1469645] |
Wed, 12 November 2014 10:06 |
The tracing output does not give me much additional insight. Here's the relevant output:
10:42:46.268 INFO org.eclipse.equinox.ds - [DS perf] Start building component ServiceComponentProp[
name = org.eclipse.fx.core.adapterservice
state = Activating
properties = {component.name=org.eclipse.fx.core.adapterservice, component.id=32, objectClass=String[org.eclipse.fx.core.adapter.AdapterService]}]
10:42:46.268 INFO org.eclipse.equinox.ds - [DS perf] Start building instance of component ServiceComponentProp[
state = Activating
10:42:46.272 INFO org.eclipse.equinox.ds - Could not bind a reference of component org.eclipse.fx.core.adapterservice. The reference is: Reference[name = AdapterProvider, interface = org.eclipse.fx.core.adapter.AdapterProvider, policy = static, cardinality = 0..n, target = null, bind = registerAdapterProviderService, unbind = unregisterAdapterProviderService]
10:42:46.308 INFO org.eclipse.equinox.ds - [DS perf] The instance of component ServiceComponentProp[
state = Active
properties = {component.name=org.eclipse.fx.core.adapterservice, component.id=32, objectClass=String[org.eclipse.fx.core.adapter.AdapterService]}] is built for 9ms
10:42:46.309 INFO org.eclipse.equinox.ds - [DS perf] Start building instance of component ServiceComponentProp[
state = Active
10:42:46.310 INFO org.eclipse.equinox.ds - [DS perf] The instance of component ServiceComponentProp[
state = Active
properties = {component.name=org.eclipse.fx.core.adapterservice, component.id=32, objectClass=String[org.eclipse.fx.core.adapter.AdapterService]}] is built for 0ms
The only instances of AdapterProvider that I could find are located in org.eclipse.fx.core.adapter.internal.AdapterServiceImpl. I do not use any AdapterProviders myself.
Re: Log message during startup [message #1470447 is a reply to message #1470409] |
Wed, 12 November 2014 10:44 |
Looking at https://bugs.eclipse.org/bugs/show_bug.cgi?id=402750 it looks
like a warning issued when the binding is declared static.
We should have anyways used dynamic for that binding so I filed bug
45115 and pushed the fix so the next nightly will come with it.
Tom
> relevant output:
> state = Activating
> component.id=32,
> state = Activating
> component.id=32,
> state = Active
> component.id=32,
> built for 9ms
> state = Active
> component.id=32,
> state = Active
> component.id=32,
> built for 0ms
Current Time: Mon Apr 29 04:45:43 GMT 2024
Powered by FUDForum. Page generated in 0.02947 seconds
