Home » Eclipse Projects » Eclipse Platform » problem with Help under WinXP Pro
problem with Help under WinXP Pro [message #264916] Sun, 01 August 2004 18:42 Go to next message
I have a new Windows XP Pro system with JDK 1.4.2_05 installed (which I
have verified executes java code just fine). When I try and view any of
the Eclipse help pages, the browser window is blank regardless of which
brower I tell the Help system to use (IE, Mozilla or FireFox). The help
system uses the loopback address 127.0.0.1 and some port to access the
help pages.
I believe the Help server is not starting up, but have been unable to
determine why. I believe it is a startup problem because neither Tomcat
or the Sun App Server startup either; after execution of their startup
scripts, http://localhost:8080 and http://127.0.0.1 are unavailable.
Has anyone else using WinXP Pro seen this problem and know of a
solution?
Gil
Re: problem with Help under WinXP Pro [message #265017 is a reply to message #264916] Mon, 02 August 2004 05:15 Go to previous messageGo to next message
> determine why.
Try putting your external IP (not the 127.0.0.1) into
Preferences->Help->Help Server->IP.
Ciao, Michael.
Re: problem with Help under WinXP Pro [message #265169 is a reply to message #265017] Tue, 03 August 2004 00:38 Go to previous messageGo to next message
In article <cel0ji$o9c$1@eclipse.org>, michael.keppler@gmx.de says...
> > determine why.
Michael - Thanks for the suggestion, but unfortunately it does not work.
One gets a Help Error: "Help cannot be displayed. The embedded
application server could not run help web application. Check the log for
details." Even if this worked it would not be the ideal solution given
my IP address is dynamic.
I noticed sarangkamat@hotmail.com also is having problems getting
Eclipse 3's Help system to display; he posted the log details today.
Here are mine which indicates the issue is that Tomcat cannot be
started. The log indicates to me this is a bug under WinXP Pro.
--Gil
Eclipse .log:
!ENTRY org.eclipse.help.base 4 0 Aug 02, 2004 23:25:46.421
!MESSAGE Help cannot be displayed. The embedded application server
could not run help web application. Check the log for details.
!STACK 1
org.eclipse.core.runtime.CoreException: Exception occurred starting
application server.
at org.eclipse.tomcat.internal.TomcatAppServer.start
(TomcatAppServer.java:207)
org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer
(AppserverPlugin.java:145)
org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver
(AppserverPlugin.java:42)
at org.eclipse.help.internal.appserver.WebappManager.start
(WebappManager.java:57)
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning
(BaseHelpSystem.java:182)
at org.eclipse.help.internal.base.HelpDisplay.displayHelpURL
(HelpDisplay.java:156)
at org.eclipse.help.internal.base.HelpDisplay.displayHelpResour ce
(HelpDisplay.java:80)
> Ciao, Michael.
Re: problem with Help under WinXP Pro [message #265228 is a reply to message #265169] Tue, 03 August 2004 10:26 Go to previous messageGo to next message
Help uses embedded appserver to provide content to the browser. There are
another logs written by Tomcat plug-in. Look at
workspace/.metadata/.plugins/org.eclipse.tomcat/catalina.*.l og files for
clues why embedded appserver cannot start.
Konrad
"Gil Hansen" <hansengj@sbcglobal.net> wrote in message
news:MPG.1b78d2aca1a250b1989681@news.eclipse.org...
> > > determine why.
> --Gil
> Eclipse .log:
> !STACK 1
> application server.
> at
> at
> at
> at
> > Ciao, Michael.
Re: problem with Help under WinXP Pro [message #265782 is a reply to message #264916] Fri, 06 August 2004 13:01 Go to previous messageGo to next message
I finally solved my problem whose solution I'm posting for others that
encounter it.
Eclipse 3.0's help pages are served up by Tomcat. Eclipse's log stated
Tomcat could not start up under SDK 1.4.2_05. When I switched to SDK
1.4.2_03, Tomcat started up and I was able to see the help pages.
Additional info: Tomcat 5.0.27 will not start up under SDK 1.4.2_05, but
does start up under 1.4.2_04.
--gil
In article <MPG.1b772db24b818339989680@news.eclipse.org>,
hansengj@sbcglobal.net says...
> help pages.
> solution?
> Gil
Re: problem with Help under WinXP Pro [message #276920 is a reply to message #265228] Wed, 01 December 2004 04:45 Go to previous message
Originally posted by: gilblais.yahoo.com
Konrad - I have no such directory of
" workspace/.metadata/.plugins/org.eclipse.tomcat/catalina.*.l og " on my
system and there aren't even any .log files under the plugins directory ????
Gil Blais
"Konrad Kolosowski" <konradk@ca.ibm.com> wrote in message
news:ceo776$niu$1@eclipse.org...
> Konrad
to
> > > > determine why.
> > --Gil
> > Eclipse .log:
> > !STACK 1
> > application server.
> > at
> > at
> > at
> > at
> > > Ciao, Michael.
Previous Topic:sharing the workspace between Linux&Windows
Next Topic:Need help cause Help don't work ;-)
Current Time: Sun Jul 27 08:46:23 EDT 2025
Powered by FUDForum. Page generated in 0.04157 seconds
