Home » Archived » BIRT » BIRT 2.2: IllegalArgumentException for an image (byte[]) in a scripted data set column of type "
BIRT 2.2: IllegalArgumentException for an image (byte[]) in a scripted data set column of type " [message #264755] Thu, 17 January 2008 07:33 Go to next message
for the display of an image created dynamically by an own java class I use a
table and a scripted data set with one column of type "any".
A ScriptedDataSetEventAdapter sets the column value with a byte[] (as
described in a BIRT example).
For very large images we cut the image into slices and each call of the
method fetch() of the ScriptedDataSetEventAdapter provides a byte[]
representing one image slice.
Using BIRT 2.1 this works fine and all slices are displayed within the
table. The user has the impression that it's only one image.
Using BIRT 2.2 only the first table row (= first image slice) is displayed
and an exception is written into the log file:
WARNING: An error happen during population of data. This might be caused by
including data of mixed type in a column of "ANY" type.
java.lang.IllegalArgumentException: An error happen during population of
data. This might be caused by including data of mixed type in a column of
"ANY" type.
org.eclipse.birt.data.engine.script.DataRow.setColumnValue(D ataRow.java:153)
org.eclipse.birt.report.engine.script.internal.UpdatableData SetRow.setColumn
Value(UpdatableDataSetRow.java:44)
de.visualrules.docgenerator.html.internal.adapter.FlowImageS licesScriptedDat
aSetEventAdapter.fetch(FlowImageSlicesScriptedDataSetEventAd apter.java:97)
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.h
andleFetch(ScriptDataSetScriptExecutor.java:114)
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch (ScriptDataSetRu
ntime.java:102)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecuto
r$CustomDataSet.fetch(PreparedScriptDSQuery.java:257)
org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java
:150)
org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.j
ava:91)
org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next(Expa
ndableRowResultSet.java:62)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .populateData(Sm
artCacheHelper.java:288)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initInstance(Sm
artCacheHelper.java:261)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .getResultSetCac
he(SmartCacheHelper.java:224)
org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.jav
a:68)
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.populateOdiRes
ultSet(PassUtil.java:108)
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.pass(PassUtil.
java:61)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.doSinglePas
s(PassManager.java:185)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.pass(PassMa
nager.java:90)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateRes
ultSet(PassManager.java:72)
org.eclipse.birt.data.engine.executor.transform.ResultSetPop ulator.populateR
esultSet(ResultSetPopulator.java:208)
org.eclipse.birt.data.engine.executor.transform.CachedResult Set. <init>(Cache
dResultSet.java:132)
org.eclipse.birt.data.engine.executor.CandidateQuery.execute (CandidateQuery.
java:106)
r.executeOdiQuery(PreparedScriptDSQuery.java:223)
org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:7
67)
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(Servic
eForQueryResults.java:217)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResult
s.java:157)
org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet
..java:83)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteData
Engine.java:157)
Engine.java:117)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractD
ataEngine.java:182)
org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(Execut
ionContext.java:1683)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(Query
ItemExecutor.java:76)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemE
xecutor.java:61)
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemEx
ecutor.execute(SuppressDuplicateItemExecutor.java:42)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecu
tor.execute(WrappedReportItemExecutor.java:45)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExe
cutor.execute(LocalizedReportItemExecutor.java:33)
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(H
TMLBlockStackingLM.java:63)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java
:85)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTM
LReportLayoutEngine.java:106)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderT
ask.java:140)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTas
k.java:68)
Is there already a bugzilla bug report for this behavior?
Does anybody know a workaround for this problem using BIRT 2.2?
Does anybody know an alternative way to integrate large images dynamically
into a BIRT report? It has to be a "dynamic component" within our rptdesign
because we don't know the number of image slices before.
Thanks in advance!
Gerald.
Re: BIRT 2.2: IllegalArgumentException for an image (byte[]) in a scripted data set column of type & [message #264785 is a reply to message #264755] Thu, 17 January 2008 15:16 Go to previous messageGo to next message
See http://dev.eclipse.org/newslists/news.eclipse.birt/msg25352. html
Snjeza
Gerald Ploner wrote:
> "ANY" type.
> at
> at
> at
> at
> at
> ntime.java:102)
> at
> at
> :150)
> at
> ava:91)
> at
> at
> at
> at
> at
> a:68)
> at
> at
> java:61)
> at
> at
> nager.java:90)
> at
> at
> at
> at
> java:106)
> at
> at
> 67)
> at
> at
> s.java:157)
> at
> .java:83)
> at
> Engine.java:157)
> at
> Engine.java:117)
> at
> ataEngine.java:182)
> at
> at
> at
> xecutor.java:61)
> at
> at
> at
> at
> at
> :85)
> at
> at
> ask.java:140)
> at
> k.java:68)
> Thanks in advance!
> Gerald.
Re: BIRT 2.2: IllegalArgumentException for an image (byte[]) in a scripted data set column of type & [message #264867 is a reply to message #264785] Mon, 21 January 2008 03:41 Go to previous messageGo to next message
Snjeza,
thank you for the "workaround plugin". Using this plugin the problem doesn't
occur.
Do you know the bugzilla bug report ID for this problem? You wrote that it
is fixed in BIRT 2.3 but I couldn't find it in the bug list.
Gerald.
"Snjezana Peco" <snjeza.peco@gmail.com> schrieb im Newsbeitrag
news:fmod2j$r4f$1@build.eclipse.org...
> Snjeza
> > Hi,
use a
displayed
by
of
> > "ANY" type.
> > at
> > at
> > at
> > at
> > at
> > ntime.java:102)
> > at
> > at
> > :150)
> > at
> > ava:91)
> > at
> > at
> > at
> > at
> > at
> > a:68)
> > at
> > at
> > java:61)
> > at
> > at
> > nager.java:90)
> > at
> > at
> > at
> > at
> > java:106)
> > at
> > at
> > 67)
> > at
> > at
> > s.java:157)
> > at
> > .java:83)
> > at
> > Engine.java:157)
> > at
> > Engine.java:117)
> > at
> > ataEngine.java:182)
> > at
> > at
> > at
> > xecutor.java:61)
> > at
> > at
> > at
> > at
> > at
> > :85)
> > at
> > at
> > ask.java:140)
> > at
> > k.java:68)
dynamically
rptdesign
> > Thanks in advance!
> > Gerald.
Re: BIRT 2.2: IllegalArgumentException for an image (byte[]) in a scripted data set column of type & [message #264917 is a reply to message #264867] Tue, 22 January 2008 09:15 Go to previous messageGo to next message
You can take a look at this link
http://dev.eclipse.org/newslists/news.eclipse.birt/msg24548. html
I haven't checked this. I have fixed the issue in BIRT 2.2 for my own needs.
Snjeza
> Snjeza,
> occur.
> Gerald.
>> Snjeza
>>> Hi,
> use a
> displayed
> by
> of
>>> "ANY" type.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ntime.java:102)
>>> at
>>> at
>>> :150)
>>> at
>>> ava:91)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> a:68)
>>> at
>>> at
>>> java:61)
>>> at
>>> at
>>> nager.java:90)
>>> at
>>> at
>>> at
>>> at
>>> java:106)
>>> at
>>> at
>>> 67)
>>> at
>>> at
>>> s.java:157)
>>> at
>>> .java:83)
>>> at
>>> Engine.java:157)
>>> at
>>> Engine.java:117)
>>> at
>>> ataEngine.java:182)
>>> at
>>> at
>>> at
>>> xecutor.java:61)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> :85)
>>> at
>>> at
>>> ask.java:140)
>>> at
>>> k.java:68)
> dynamically
> rptdesign
>>> Thanks in advance!
>>> Gerald.
Re: BIRT 2.2: IllegalArgumentException for an image (byte[]) in a scripted data set column of type & [message #361437 is a reply to message #264917] Mon, 31 March 2008 09:42 Go to previous message
Originally posted by: crognon.gmail.com
Hello Snjeza,
can I use the modified 2.2.1 plugin with Birt 2.2.2 without problem or
can you tell me what to modify in the data plugin to create an updated
plugin for 2.2.2 release ?
thanks
Cyril
> needs.
> Snjeza
>> Snjeza,
>> doesn't
>> occur.
>> that it
>> Gerald.
>>> Snjeza
>>>> Hi,
>> use a
>> displayed
>>>> caused
>> by
>>>> population of
>> of
>>>> "ANY" type.
>>>> at
Previous Topic:Viewer.war for JBoss
Next Topic:Dynamic Font Color with Scripted Crosstab
Current Time: Thu Jul 17 22:30:58 EDT 2025
Powered by FUDForum. Page generated in 0.08156 seconds
