Home » Eclipse Projects » Eclipse Platform » How to write a custom notifier / listener
How to write a custom notifier / listener [message #264528] Thu, 29 July 2004 16:40 Go to next message
Originally posted by: gary_.pureedge.com
Is there a way to write a custom notifier in Eclipse?
I want to be able to notify particular listeners when an event occurs
including those in other Plugins that I might write in the future.
I probably need to write both a notifier and a listener and the interface
for them but how would I implement this?
Re: How to write a custom notifier / listener [message #264833 is a reply to message #264528] Fri, 30 July 2004 22:48 Go to previous message
You just described the essence of Eclipse.
Declare an extension point with a Java interface as an element.
Name your listener interface something with "Listener" in it
and create executable extensions during creation of you plugin
(or when the platform changes if you are a dynamic plugin).
All this is described at http://eclipsefaq.org (see FAQ 85 and 86 in
Chapter 4 that describes the PDE).
For dynamic listeners, you have to set up a registration service.
In your notifier you keep an arraylist and you add listeners.
Don't forget to allow listeners to unregister.
If you want to get some inspiration: Ctrl-Shift-T + *Listener*
Chris
Previous Topic:VariableDeclaratorId expected..?
Next Topic:How to open internal browser?
Current Time: Fri Jul 25 20:28:09 EDT 2025
Powered by FUDForum. Page generated in 0.03800 seconds
