Home » Modeling » M2T (model-to-text transformation) » difference between Jet Project and Jet Transformation Project
difference between Jet Project and Jet Transformation Project [message #26195] Thu, 12 July 2007 07:51 Go to next message
Originally posted by: axelDOTazertyA.TlaposteDO.Tnet
Hello
In eclipse, I have two choices related to JET :
"EMFT JET Transformation Project" and "Convert Projects to JET
Projects". What are the difference between these two ?
I have created an ecore model, and a instance (as a xmi file) of this
model. If I want to transform this one to text (in other words, generate
code), what is the procedure ? I m totally new to the new JET (I used
the old JET , I was generating code from java objects, not from
xml/model file, calling the generation from a java class) and I did'nt
found any recent documentation about how to use JET for code generation
from a model.
Thanks in advance.
Axel
Re: difference between Jet Project and Jet Transformation Project [message #27026 is a reply to message #26195] Tue, 17 July 2007 10:14 Go to previous message
Axel:
You want "EMFT JET Transformation Project". The Convert Projects to JET
Projects wizard adds the old JET builders (org.eclipse.emf.codegen...).
Paul
"Axel" <axelDOTazertyA@TlaposteDO.Tnet> wrote in message
news:f754kg$h7g$1@build.eclipse.org...
> Hello
> "EMFT JET Transformation Project" and "Convert Projects to JET Projects".
> code), what is the procedure ? I m totally new to the new JET (I used the
> old JET , I was generating code from java objects, not from xml/model
> file, calling the generation from a java class) and I did'nt found any
> recent documentation about how to use JET for code generation from a
> model.
> Thanks in advance.
> Axel
Previous Topic:M2T/Jet in Eclipse Europa ?
Next Topic:Problem with XPath comparison operator '>=' ?
Current Time: Thu Jul 17 12:15:17 EDT 2025
Powered by FUDForum. Page generated in 0.27297 seconds
