Home » Archived » OHF » Converting your groups ATNA TLS Certificates for use at Connectathon'07 by OHF users
Converting your groups ATNA TLS Certificates for use at Connectathon'07 by OHF users [message #26164] Thu, 04 January 2007 14:47
Originally posted by: rgd.us.ibm.com
Hi everyone,
I've sent e-mail directly to those groups I know of who are using OHF
for this year's Connecathon, but I'm posting here as well to make sure I
contact everyone:
Steve Moore has issued new certificates for the systems being test at
the Connectathon. Steve issued these in PEM format, so they need to be
converted to the JKS format used by Java and OHF.
I will do the conversion for each of your systems private keys into the
JKS format, but I need you to send the private key from KUDU that your
system has been assigned. Each group's systems keys are visible in
KUDU only when you log in with the specific organizations Kudu ID.
Here's the link to the page:
http://ihe-kudu.wustl.edu/na2007/certificates.php?highlight= 6_6
If someone from your group can go to this page and download the Private
Key and send it to me, I will do the conversion and send it back, as
well as make sure it is on the central OHF Bridge config server we are
bringing to Connectathon.
TrustStore:
Also, for those of you are using the OHF plugins directly you'll need
the following truststore which contains all the public keys converted
from PEM to JKS in one file:
The file is check in the plugin in CVS at:
org.eclipse.ohf.ihe.atna.agent/resources/security
regards,
Glenn Deen
Previous Topic:Converting your groups ATNA TLS Certificates for use at Connectathon'07 by OHF users
Next Topic:Can I plug Open Healthcare Framework in to IBM Rational Software Architect(RSA)
Current Time: Sat Jul 26 07:40:40 EDT 2025
Powered by FUDForum. Page generated in 0.03344 seconds
