Home » Modeling » M2T (model-to-text transformation) » Problem with XPath comparison operator '>=' ?
Problem with XPath comparison operator '>=' ? [message #26153] Thu, 12 July 2007 06:02 Go to next message
Originally posted by: guillaume.riby.fr.ibm.com
Hi guys,
I encountered a problem in some tests i'm doing, using <c:if> tag. I'm
pretty sure that the problem comes from my syntax but i cannot find where,
could you help me please?
Here is my Jet template :
##### TEST PART BEGIN #####
<c:if test="1 >= 1">
TEST #1 :: 1 >= 1
</c:if>
<c:if test="not(not(1 >= 1))">
TEST #2 :: not(not(1 >= 1))
</c:if>
<c:if test="(1 > 1) or (1 = 1)">
TEST #3 :: (1 > 1) or (1 = 1)
</c:if>
<c:if test="not(1 < 1)">
TEST #4 :: not(1 < 1)
</c:if>
##### TEST PART END #####
These 4 equivalent tests actually don't give the same result. What is
generated is :
Regards.
Guillaume Riby
Re: Problem with XPath comparison operator '>=' ? [message #26315 is a reply to message #26153] Thu, 12 July 2007 08:27 Go to previous messageGo to next message
Guillaume:
Yes, it's a bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=196294).
There is a similar problem with <=.
Paul
"Guillaume Riby" <guillaume.riby@fr.ibm.com> wrote in message
news:08396ec7f3e84a2e5ba1df11fc9ee693$1@www.eclipse.org...
> Hi guys,
> TEST #1 :: 1 >= 1
> </c:if>
> </c:if>
> </c:if>
> </c:if>
> generated is :
> Regards.
> Guillaume Riby
Re: Problem with XPath comparison operator '>=' ? [message #27066 is a reply to message #26315] Tue, 17 July 2007 10:15 Go to previous message
The most recent JET 0.8.1 maintenance build (not this is not a release, just
a weekly integration build) contains the fix.
http://www.eclipse.org/modeling/m2t/downloads/?showAll=1& ;hlbuild=M200707120943&project=jet#M200707120943
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:f756pe$n59$1@build.eclipse.org...
> Guillaume:
> Paul
>> Hi guys,
>> where, could you help me please?
>> TEST #1 :: 1 >= 1
>> </c:if>
>> </c:if>
>> </c:if>
>> </c:if>
>> generated is :
>> Regards.
>> Guillaume Riby
Previous Topic:difference between Jet Project and Jet Transformation Project
Next Topic:Xpath node
Current Time: Tue Jul 22 13:59:23 EDT 2025
Powered by FUDForum. Page generated in 0.39617 seconds
