Re: unit tests [message #49061 is a reply to message #48916] |
Wed, 05 September 2007 12:21   |
Originally posted by: mshekov.gmx.de
@Ali B.
About your 1st question: as I was so fortunate to meet Sebastian Bergman
in person a few weeks ago I did also ask him about that, and indeed
PHPUnit will be integrated into Zend Neon (in a similar way as JUnit
Tests are integrated with Eclipse for example)
About using PHPUnit with PDT: As I am german I had a look at the
mentioned article, but I think it is done in a too complicated way
there. If you use the php files which are generated by the skeleton
generator of PHPUnit you are able to run the Unit tests by either the
commandline ("phpunit testfile") or just by executing that php script
with php.exe. So this is exactly what I do in eclipse: I create the
skeleton (using command line), copy it to the right place in my
directory structure (./tests/...) and then edit it inside Eclipse/PDT. I
do use XDebug instead of the Zend Debugger Plugin for PDT. Then I can
simply create a "Run" or "Debug" configuration for the file I want to
start (e.g. one of the AllTests or a specific test) and use it just
fine. The advantages are that you are actually able to debug, and also
able to echo/var_dump variables, etc. when running your PHPUnit scripts
with php.exe instead of the phpunit wrapper.
I hope I was able to give you the idea of what I meant.
Greetings,
Marius
Ali B. wrote:
> I have found a how-to article on PDT and PHPUnit. The problem is I don't
> know German (Well, a little if you count google translation in :)). Here
> is a link to the article:
> http://www.redbrick.de/index.php?cat=howto
> I tried translating the page through google but it wouldn't display
> right. I guess I am going to have to translate each paragraph's text.
> Another interesting thing are some screenshots published by Sebastian
> Bergmann of "Zend Neon" testing the PHPunit integration with it. Is it
> integrated with it? or was it just Sabastian playing around with the
> IDE? I don't really know. Perhaps Zend's and/or PDT's people can shed
> some light on if we should expect any PHPUnit support in PDT any time soon?
> PS: We would understand if the Zend team are not willing to expose any
> deep stuff about the Neon just yet ;)
> I am sure that almost all of you are noticing the increasing popularity
> for PDT by now. Don't you agree that by making code testing easier would
> give PDT even higher ranks?
> I would love to hear anyone's opinion about all of that. After all, PDT
> is all about its community ;)
> Cheers,
> Ali
> Jack Bates wrote:
>> I understand there is a unit test framework for testing PDT itself:
>> http://wiki.eclipse.org/index.php/PDT_Testing_Framework
>> Does PDT integrate with any PHP unit test frameworks for testing PHP
>> projects developed with PDT? e.g. http://www.phpunit.de/
>> Thanks, Jack
Re: unit tests [message #49093 is a reply to message #49061] |
Wed, 05 September 2007 14:17   |
Marius,
Thanks a lot for the idea. I can see that the way you do it gives you
more option to run/debug. I will certainly give it a try.
As for integrating into Neon, It's great to hear that it will have
native support for PHPUnit. The question is, would PDT do?
Anyway, I guess time will certainly tell ;)
Thanks again.
Ali
Marius Shekow wrote:
> @Ali B.
> Greetings,
> Marius
>> don't know German (Well, a little if you count google translation in
>> :)). Here is a link to the article:
>> soon?
>> popularity for PDT by now. Don't you agree that by making code testing
>> easier would give PDT even higher ranks?
>> PDT is all about its community ;)
>> Cheers,
>> Ali
>>> Thanks, Jack
Re: unit tests [message #49298 is a reply to message #49093] |
Thu, 06 September 2007 09:35  |
Originally posted by: mep_eisen.web.de
Yes, it works. You are executing simple scripts and You are looking at the
console view.
Looking at bugs should answer this question (id 150506). Maybe we should
vote on this request since it got no comments for one year. I am thinking
of a small community project (since I cannot wait any more) and maybe it
will be integrated in PDT one time :-)
* Integrate a launch configuration based on pdt's launch configuration
* Integrate some commands (run as PHPUnit test...)
* Integrate a simple view (like JUnit's view)
Those should be fairly simple. But it does not cover PHPUnits power. There
are some other features:
* Code coverage (using XDebug)
* Software metrics (as of PHPUnit 3.2)
One might want to create PHPUnit tests on the fly. Also there should be
respect on other extensions (Mock objects, DBUnit port.....).
FUDForum. Page generated in 0.06164 seconds
