Home » Newcomers » Newcomers » searching project doesn't ignore .svn directories
searching project doesn't ignore .svn directories [message #263849] Thu, 28 August 2008 16:31 Go to next message
I've got a large project that we use our own set of svn-related tools to
check in and out and so forth, so I'm not using any sort of internal
subversion support or subclipse here.
When I search the entire project for a term by clicking it in the PHP
Explorer (this is with prelease PDT 2.0, the 8/27 nightly that is, and
Ganymede), it fails to ignore all the .svn directories in the project tree
and therefore spits back to me a ton of spurious results. I can't figure
out how to make search ignore these, even though they're not showing up in
the actual explorer view.
Eclipse SDK
Version: 3.4.0
Build id: I20080617-2000
PDT is org.eclipse.php_feature-N20080827 nightly.
Any help would be appreciated -- searching an entire package is unusable
for me right now and it's pretty important given our codebase. :P
Thanks!
Re: searching project doesn't ignore .svn directories [message #263897 is a reply to message #263849] Sat, 30 August 2008 01:35 Go to previous message
Originally posted by: nospam.nospam.nospam
"gmorehoudh " <gordonm@darkhorse.com> wrote in message
news:ce6dec395269b653391c01b7b6ba9053$1@www.eclipse.org...
> Eclipse SDK
> Version: 3.4.0
> Thanks!
you can mark all the .svn folder as "derived", but that could be a lot of
work. Best way is to install SVN Eclipse plugin
http://www.eclipse.org/subversive/
Jan
Jan Bares
http://jan.baresovi.cz
Previous Topic:Programatically create working set
Next Topic:problem with menu bar in eclipse on solaris
Current Time: Tue Jul 22 15:32:33 EDT 2025
Powered by FUDForum. Page generated in 0.09888 seconds
