Home » Archived » Test and Performance Tools Platform (TPTP) » Web services testing.
Web services testing. [message #26129] Wed, 10 August 2005 09:33 Go to next message
Originally posted by: ada_nospam_m._No_softfab_Spam.com
Dear All,
I appologise in advance for posting to 2 newsgroups however I am unsure
which group would be dealing with this.
I work for the UK NHS & we're in the midst of a fairly large health care
project. A large part of this involves pushing XML messages about the
place via SOAP etc.
We end up it an interaction diagram which in essence looks like
System A System B
Message1 > Received
Received < Message2
Message3 > Received
Received < Message4
etc. showing the which XML messages are sent in which order.
We'd like to be able to automate the testing of this to a degree & are
in the midst of looking at creating some Eclipse plugins to cover the
entire lifecycle from inception through modeling to testing.
What I was wondering is that given the above can be fairly easily mapped
into an XML file we should be able to autocreate a testsuite from it (at
the very least at the schema checking level).
i.e. Supplier A sends us Message1 which we receive & test with a
schemachecker. We then want to reply with a test message conformant to
the schema of Message2 etc.
There might be a fairly lengthy conversation involving a fair few
different messages flying backwards & forwards. We want to be able to
produce a test report (at the very least for the schema compliance of
the messages received in the conversation) & we want to ensure that the
messages are received & sent in the right order etc.
I am wondering if there is anything within the TPTP or webtools which
can create the 2 relevant webservice stubs.
We might then at some point want to fit content checking & bouncing
(i.e. if this value should be returned, pull it out & put it into the
reply) etc. but that's someway down the road.
We'd want stubs for both sides of the conversation so we could check our
own replies before letting the test out into the wild for suppliers to use.
It should be possible using something like servlet filters as we are
only caring about the XML as an XML document (message/payload) & would
not need to test the outer layers of the onion (i.e. the soap layer, the
security layer etc).
TIA
Adam
Re: Web services testing. [message #31110 is a reply to message #26129] Wed, 14 September 2005 08:34 Go to previous message
Hi Adam,
There is no function currently in TPTP to create web service stubs. WTP
should provide this function. TPTP does provide function for HTTP/URL
testing but protocol and/or API level web service based testing is provided
by various upstream products.
Paul
"Adam Flinton" <ada_nospam_m@_No_softfab_Spam.com> wrote in message
news:ddcvmn$kpu$1@news.eclipse.org...
> Dear All,
> place via SOAP etc.
> System A System B
> Message1 > Received
> Received < Message2
> Message3 > Received
> Received < Message4
use.
> TIA
> Adam
Previous Topic:Question about Hitchhiker
Next Topic:Does this Work with JAVA 5?
Current Time: Tue Jul 22 13:59:16 EDT 2025
Powered by FUDForum. Page generated in 0.05088 seconds
