Home » Eclipse Projects » Eclipse Platform » runtime-work-bench problem
runtime-work-bench problem [message #263630] Sat, 24 July 2004 00:56 Go to next message
Originally posted by: crscca.bol.net.in
I downloaded eclipse-SDK-3.0RC3-win32 and used it.
I have one issue with it.
It does not have the plugin - org.apache.xerces_4.0.13 unlike the release
M7
So I borrowed this plugin from M7 and put it here in the plugins directory.
When I run eclipse and do a help>about>plugin-details the plugin shows up
in the list.
It however does not show up in the view window>show view>plugins
I guess because of that when I do a run as runtime-work-bench it does not
appear in the help>about>plugin-details of the runtime-work-bench.
Got any soluttion?
Re: runtime-work-bench problem [message #263633 is a reply to message #263630] Sat, 24 July 2004 01:19 Go to previous messageGo to next message
Originally posted by: wassimm.ibm.canada
Go to the Plug-in Development > Target Platform preference page, and make
sure the xerces plug-in is explicitly checked.
Wassim.
> M7
> in the list.
> Got any soluttion?
Re: runtime-work-bench problem [message #263666 is a reply to message #263633] Sun, 25 July 2004 05:11 Go to previous messageGo to next message
That didnt (I think) help because the plugin dos not appear at all in that
list.
It also does not show up in the view window>show view>plugins.
It does however appear in the help>about>plugin-details. Thats the only
place it appears in.
In the runtime-workbench it does not appear at all.
Has anyone encountered this issue? Is that a bug in
eclipse-SDK-3.0RC3-win32?
Is there any solution?
I am also pasting the plugin.xml of org.apache.xerces_4.0.13 below.
<?xml version="1.0" encoding="UTF-8" ?>
<?eclipse version="3.0"?>
<plugin name="%pluginName" id="org.apache.xerces" version="4.0.13"
provider-name="%providerName">
<!-- This is an IBM maintenance branch of xerces 2.0.0 -->
<runtime>
<library name="xmlParserAPIs.jar">
<export name="*" />
<packages prefixes="javax.xml,org.w3c.dom,org.xml.sax" />
</library>
<library name="xercesImpl.jar">
<export name="*" />
<packages prefixes="org.apache,org.w3c.dom" />
</library>
</runtime>
</plugin>
> Wassim.
> > M7
> > in the list.
> > Got any soluttion?
Re: runtime-work-bench problem [message #263720 is a reply to message #263666] Mon, 26 July 2004 00:58 Go to previous messageGo to next message
1. Why are you using RC3 and not the final 3.0 release?
2. Is there anything in the log regarding the xerces plug-in being
rejected?
Try to press 'Reload' on the target platform preference page and see if it
appears or if something gets logged.
Wassim.
> list.
> <runtime>
> <export name="*" />
> </library>
> <export name="*" />
> </library>
> </runtime>
> </plugin>
> > Wassim.
> > > M7
directory.
> > > in the list.
> > > Got any soluttion?
Re: runtime-work-bench problem [message #264155 is a reply to message #263720] Tue, 27 July 2004 23:26 Go to previous message
ok switched to final. problem was still there. but i think the problem is
mot eclipse related. something with my project settings i guess. only the
same settings worked well in M7. but thats ok. i found a workaround.
thanks
> rejected?
> Wassim.
> > list.
> > <runtime>
> > <export name="*" />
> > </library>
> > <export name="*" />
> > </library>
> > </runtime>
> > </plugin>
> > > Wassim.
release
> > > > M7
> directory.
up
> > > > in the list.
not
> > > > Got any soluttion?
Previous Topic:[RCP] PDE Export Issues
Next Topic:CVS: problems checking out project
Current Time: Tue Jul 22 22:54:21 EDT 2025
Powered by FUDForum. Page generated in 0.04633 seconds
