Needed some help in package [message #263519] |
Fri, 22 August 2008 07:16 |
We have built the eclipse(3.3.2) sdk with 64 bit gtk in HPUX. Now we are
in the process of creating the rcp delta pack, here comes the issue
We came to know that releng packages are used to build delta package, So
we have downloaded org.eclipse.releng (Version - R3_3_2),
org.eclipse.releng.basebuilder (Version - R3_3_2) and
org.eclipse.releng.eclipsebuilder (Version - R3_3_2)
There is a document(very old docu.,) from
org.eclipse.releng.eclipsebuilder saying that
"java -cp ../org.eclipse.releng.basebuilder/startup.jar
org.eclipse.core.launcher.Main -application org.eclipse.ant.core.antRunner
-buildfile build.xml -Dcomponent=<component name specified in table below>
[Ant properties to override in a component's build.properties] "
can be used to generate package.
Since there is no mentioned path to download the these releng packages We
have downloaded to plugins directory where we built the eclipse SDK.
1- I dont see any startup.jar in releng.eclipsebuilder package. In this
place we used org.eclipse.equinox.launcher_1.0.1.R33x_v20080118.jar
2- we used org.eclipse.equinox.launcher in the place of
Following is the command we used:-
java -cp
../org.eclipse.releng.basebuilder/org.eclipse.equinox.launch er_1.0.1.R33x_v20080118.jar
org.eclipse.equinox.launcher.Main -application
org.eclipse.ant.core.AntRunner -buildfile build.xml -Dcomponent=sdk.rcp
There is no error after executing this command. Help us to generate this
package.
Thank you,
Ganeshraj.S
FUDForum. Page generated in 0.06365 seconds
