Home » Eclipse Projects » Plugin Development Environment (PDE) » Mnemonics underscore
Mnemonics underscore [message #26099] Mon, 13 October 2008 03:35 Go to next message
Is there a way to change Mnemonics underscore (menu alphabet show with
underscore sign when user presses ‘Alt’ key. Used to select the menu
through keyboard)
Like, I want to change the mnemonics for 'Close All' menu (File -> Close
All) to 'C' from its current as 'l'
Thanks in advance for your inputs!
Cheers!
Anup
Re: Mnemonics underscore [message #26181 is a reply to message #26099] Mon, 13 October 2008 09:15 Go to previous messageGo to next message
I do not believe that there is. Eclipse allows you to add
functionality, but you cannot remove or change existing functionality.
If you're talking about the Eclipse IDE, rather than an RCP app, then
I'm a little concerned that you even want to do this. Doing so would
confused users who are used to the existing behavior.
Anup wrote:
> Hi
> underscore sign when user presses �Alt� key. Used to select the menu
> through keyboard)
> Cheers!
> Anup
Re: Mnemonics underscore [message #26454 is a reply to message #26181] Tue, 14 October 2008 02:24 Go to previous messageGo to next message
Thanks for your reply Simon. Yes, you are right, I wanted to do this
changes for Lotus Expeditor (Its a Eclipse based tool.) and not for the
Eclipse IDE.
I am just wondering if we can just re-write the Close All menu using
'org.eclipse.ui.actionSets' extension point and mentioning all attributes
value same as might be defined by Eclipse. Is there a way to do this?
Anup
Re: Mnemonics underscore [message #27855 is a reply to message #26454] Tue, 21 October 2008 10:29 Go to previous message
> attributes value same as might be defined by Eclipse. Is there a way to
> do this?
I do not know. But it sounds unlikely. Replacing anything in Eclipse,
where not directly supported, is typically problematic.
Re: Mnemonics underscore [message #582614 is a reply to message #26099] Mon, 13 October 2008 09:15 Go to previous message
Anup wrote:
> Hi
> through keyboard)
> Cheers!
> Anup
Re: Mnemonics underscore [message #582739 is a reply to message #26181] Tue, 14 October 2008 02:24 Go to previous message
Eclipse IDE.
Anup
Re: Mnemonics underscore [message #583122 is a reply to message #26454] Tue, 21 October 2008 10:29 Go to previous message
> do this?
Previous Topic:How to deselect repeated plug-ins from a Target Platform automatically
Next Topic:Headless build configs="win32,win32,x86_64"
Current Time: Sat Jul 26 09:11:38 EDT 2025
Powered by FUDForum. Page generated in 0.04808 seconds
