Encoding problems in Tomcat [message #26073] |
Fri, 18 May 2007 14:28  |
--------------050909030705050106080305
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi, I've posted this problem in equinox newsgroup but I'm not sure about
the correct site to place it, In any case if somebody has any idea...
All Strings in code appears wrong, but the text load from database
appears correct, I've attached a screenshot.
Of course, when I launch the app from eclipse, all characters appear
perfectly.
I was comparing both System.getProperties() and I found 2 properties
that are in eclipse-mode but don't appear in tomcat:
// osgi.nl=es_ES
// org.osgi.framework.language=es
I've setted those propeties manually in tomcat but without effect.
I've setted properties from osgi console, with setprop command too.
Any idea ?
Thanks in advance.
Roberto.
Content-Type: image/png;
name="encoding_screenshot.png"
Content-Disposition: inline;
filename="encoding_screenshot.png"
iVBORw0KGgoAAAANSUhEUgAAAUYAAAEOCAYAAAD13L7xAAAABmJLR0QA/wD/ AP+gvaeTAAAA
CXBIWXMAAAsTAAALEwEAmpwYAAAAB3RJTUUH1wUSESE0QdC+QgAAIABJREFU eNrsnXlcVNf5
/9+TzJSLmUEGwYTYuICNSx34xiVqFonaitYqZrFWYxZSCzZuccNCviEtthhN 3DVVYqtRoknF
KBqr8VdFTeKulCUqURSwSr6CjmEmcMmMmd8fw84Mi2Ii+rxfL18O957tec65 nznnzr3n0Tgc
Dgc/ANk5Fwls34bMr3MAuJKVS58+IRXnDx3ax1N7nZ+TOmfx6xERbsv6ZEtC neebK5s/3si5
3Dxi/jgdQRB+PO4RFwiCIIgwCoIgiDAKgiCIMAqCIIgwCoIgiDAKgiCIMAqC IPxQaMUFtx/Z
ORfFCYIgwiiUIw93C4IIo1CFp58ZSWmp+EEQfmzkHqMgCIIIoyAIggijIAiC CKMgCIIIoyAI
ggijIAjCraPZPq7zyZYE6T1BEEQYy7kTd+8WBEGW0oIgCCKMgiAIIoyCIAgi jIIgCCKMgiAI
IoyCIAgijILQHLGbycrMIN8qrhBEGAUBgCNLniW4ZxAdJq1HFXcIIozCXU/+ VvrFtOFYfg7x
G57n76kW8YkgwugStYCsrNzbZPZgJy/zBFn5TdUalS9WzWP7ubtTAOzWPFJT 87ADWC+RVRTM
NXUd3YztmKY6GPPAZc7lizgKIoy1sJ5aTXBwe9Jvi3tOJWzr2YOxH59sovJs /GfiLNIK7Xfl
AFbPfEjfvh9iAaxn/k5w8EeUVDmfs7ojXVeflCtdEGGsha4l0B+dyyvLglV1 LSqq1ULNM3bV
gtoIDbKrao0yDExQHRyd0L3eNtTOW/s8gIcJFF3DbKrPPlzY67ptDfNDXTZY rWq18uwNzmuv
qFv/SBSqGoWxop+V6v3csj8mRddouwURxrsUlS9WRaJ4e+HrrWPkgp1YATUr iZEjpxI7MRhv
Xy/0obPJslam13t74a3XEBr6Ah9lWVCz1jNy4nrKJ6NZH01l5kenUc8l0UvR oPf2RK9oiN98
AjsWPpo4gNDQEcRvz3bbBnv+YWJDK/Mu2JVbSxiOrJ2K3tsTRfFiYgZ4oHVb XjWrs5IYOTKS
2PAy+3rFkGq2O+0In83mtfMI7RVJqtXCrgUj0Ncqqw4/VMl/KMOV/ZX1zxyp wdfXk5ELkti1
dip6by/0SiRHzHY3vnPWfWRtDIqic9Y9cSU5X67nuQnrqW8x4L5fBUGEsYL8 7dEMnNiKtEIH
6rWzPBIzhEmbs7HbrrBt2yK8h6zmwvnjTNoXy9J9ueRtn8LAibD7q6sUXkgn aF8iF4vt2IsL
2baqEFtZucWFe1h68Ru0hm4sP5ZD4bUSzh9cTdzocE5YDYTNfpfe+5LZnPON 2zZkbIhgXlAy
11QHF9J242srqd72vbH0iyhk58nLFF5IJwooxe62vGqSarvCtm0J3D86kQsX ThHPHPouPIjd
ZmHbhljWn23J9EWRsHMGw2M6cPBCCdcuHKd9zBD+uDnbvR9q5A/0dWV/Zf3t J5zi/LEP2BYz
ktczenHywlkShiUwYXW6G985+6xfxEm2pl2mMP8srwSUcvmbAj75e0H9M1c3 /SoIrmiW247V
txdj/duSqexPWgT0Z9W8qYAnOcC2U4Us/VkpmFbw6tDuKMBL84PomZXLkwcT MM0/zuNtjYCW
TiYoAsrXbZWLtVaY0KE1tuJa8kLCp28n52o6EIYOUIxt6BgCPpS6bcP01h0g 5g3i219lwGP9
GTO0XfW2L5+DaX46TwX4AQbamqCoDptWPx1YJb/Tvt8NMqEA4YviiBmYyrXf ACxmXVwkChZW
hSYQsiydR/wUoDvjEsIIXrGHXl5u/EBplfyAvYDU7bXtr6j/qc4odh3jgC4v PUOAn0JxaH8o
wo3vVPavWQTxxxnUyQ/wY9S0yVgzF9d9F6WG3dX79WuWVfGt7PEpNGthbJj4 1WWtjVIrEPUa
k/4QjL3EjnbcRN718YGcw5BRWuUeVCtM3IOlqgrWvFtp8qj42MIDKL3OrujW DN8bx8FNezEZ
Munr/2bFrPI7AK67bYOfPomTXf7Fjn0pzOwbTkbUbqxxA8qabytri63W8tqt TbWotM9uKwFa
VinFjcB4AFeLy5asbvxQkd9ep/0V/tW25n9MUGQrARRspU6/uM5ro7Sonv61 qdT0TGFOCvjb
qtdb5QvspseUIEvp5k0KOWcvUZB/iby8q3QZMhrmpfA1PgS0bYOuKJ09By7W vtaccseA8RFk
TJ/H9tQMvti8pOy+XlmCjM85mW+hIGsnSyem4ONhx5wDDOlFl7YGso8eJKNW yS144rmxLtrw
FXtXJVL88CAmxCxkeXwQHM6r8qiRgT4jw8jY+jnnzCoFWXvZmAEe6N2UV9sm Ms6TY1ZRzadZ
N3MOpvjeeFdLYODJ58PYt3KL8z6c9TQfvpTMsBmhDHHnhxryWL/9FfO4BuY1 8MQrYyFmHUfy
Lditl9i1dg1nvqvMqTzQGZjF37afRrXbKcjaysyl8FS3B9z0qyDcYTPGxuG8 dEf3bFNxJGR+
CptiF9Gvg1fFsahNZxkKYKq+FPPxgICn32Fr/AyG9w1i2LjXCCk7r3/kOeYP m0K/DolAGOOG
gZeHnqF/+QBT8BC855WXFFYxP/kJcLUUAkYtYVN2eI02fIkxby09HwqvyLfp 5LPoq1jTbexb
RK3sQlf/KRXHRqJ1U95ZF75YRE//Rc4/R6/g/LTekHm4mt2dXnyPhCOtCfaN dR4Yt5oLozrj
h2s/UM1vSp32V63Ho8ow1JUdcZc3YNQC3j82qop90Rw8cD90KxvM/sNJ2xRH 8LNdiCtLMSw2
mTcHtYNM1/0qCK7QOBwOxw9RUXbORQLbtyHz6xwArmTl0qdP5WV16NA+ntrr /JzUOavOZc0n
WxKabNlT/tiJojfU/S1ht1Bg0eFnVMCaQbhvED2PFTGhmwGwYzVb0BqNzvtr VfKYLWA0Gqoc
yyVe3x5192XiHvdz3wa7ilW11dEuO2azBc+addZjkzVzCb7hkH90Mp5WFUWv 1Okfq9mMDU+M
RqUBfqjts1r2N7hj3Od12qdD767tdhWzpQSdpwG9opWrXJAZY6MdoBiqzcbc op7kV/59KpeE
kz5gQYUYaNEbjS4KN1D1cOryEfSdngyMZffDxrrboFXcX/hldRpd1VmfTTaV ciPqE0Wgtl11
+qFu+xvXMe7z1ttnWqVSyAVBhPEWou9NSv5lrlqKQedFW//GX/FdxrzLySGL ad22HfofyfP6
Lr/n/AUtxh/RD4IgwngnaaPRD/1N6IBifJCAH1tHFCP+yo/rB0G43ZHddQRB EEQYBUEQRBgF
QRBEGAVBEEQYBUEQRBgFQRBEGAVBEEQYBUEQRBgFQRBEGAVBEEQYBUEQRBgF QRBEGG9DPDxu
/N9bb/35tipDEIQfhrtidx1Vtd+yMjbPcG42+/Q7BTdUxoH5bar9/dj0izIq BUGE8Yej8Phh
8lf+lft+3oOAKW/WOn9u8Z/59svj+Ee+jm+P3vWWt2WmHyOnTQcgaaYfI94u aFR7DsxvQ/9Z
6QA4HKBBQ8q8NiKOgiBL6R9QFJfF4f/tT/j2P0c4t/jPtUTR+p8j+H/7E/KX xlF4/HCd5SXP
8uO5qdMr/n5u6nSSZ/k1qk2O7xt2TBAEmTHeEkrzzuJQr+PzP8H4aBxkHjrA qUu/w6vPAIoO
7cGWd5Gf/8/jaDQOLqUeoDTvrNuyPoluzbNTYyr+1gAO4LmpMWyOvp9fz/m/ hgmjw4Hjeomz
DI0Dh0PD9z9MCB5BEGTGCG2efh59n75kHNzH90UqPw98BB/Lda68/w98LNfp GvAIfFNM5oH9
6Pv0pc3Tz7ssZ/v/tubpaXFo7m0B93iiubcFjntbwL2eOO715Olpcfzr9fsb 1Kbvv3fAdSvY
rTjs36KxW/n+ugijIIgw/oAETHkTfdteZB75Asc3JbS6x5uuP+2G7z3e8E0x Gce+4L62vVze
fwTYGfsAYdMW4LhXj+Pe+9Bo9XDvfWi096G5Vw9lfw+fPp+dsfWL4/XvwWG3 wnWLUxyvW2Up
LQiylP7hCVwyh/888RhF6RkY2gWULWnBmncOrtsJXDLH/bfIPbBj6QznulkD v5q6smwR7eRf
C8eDw7m0vvdeTf0zxusOsBfhqCGWgiCIMP7wFNvAQ4vDolIuX47vbFBqqzPb oD99XfF59+wH
QFs9bOi992gY+EZ+nWXs+tMDaMpvSmoAu6WauF7/3uFMg/P8L9/8WkapIIgw 3lqyJ0fjKLGj
b+0PJd9VSJK+pT/f52aRPTm6zlljxezxXg1ovdBUKBzc24AbE99/D79+7Z3K A3aL8/8ysfzV
5HfQOJxS+cmi6TJCBeFH4K66x5g9OZqiTz7h5+0eBiC/IJvMrC/JL8gG4Oft HuabT7aRPTm6
3rLuvYeye4wG0OrR3KtH0wBvDo77muQF09Bct6K5/m3ZPcZvcdi/xVH2QwzX v2Xr/OkMjvs/
GaGCIMJ46/j6g01883EyP3+4Kw4cZGZmYH/8lzz4lz9jf/yXZGZmoEHDzx/u yjcfJ/P1B5vq
dtw9Gij7wUWjvQ+HVu+cRTaAoX+5zOYFsTiuF8P3JTiuF6O5XgzXS9BcL2Hz glh+9VcRRUGQ
pfStNrTzTwEwX8njYv43tHwmrHLJ/PyzZAOZHyfzoL9XZfr/nnZbnkajQXOv J1D21opGwz0a
TYPb8+s5l9k0y49npziXy+VL+qTF8wmbWyAjUxBkxnjr8e3Rm7bJq2uLYhmB S+bQ8pkwLuUX
0TZ5db2vBLpaNmsa6c2wuQUkLZxf8XfSQhFFQZAZ448gjr7/Pen2fOCSOdCA H17AudlDytyb
3wBixNsFbGzERhSCIIgwNglz5/71FpXxarW/PqunHrft8HutydopCIIIY72U lsIf//jmHVGG
IAg/DLKDtyAIggijIAiCCKMgCIIIoyAIggijIAiCCKMgCIIIoyAIggijIAiC CKMgCIIIoyAI
ggijIAiCCKMgCIIIoyAIggijIAjCnYf2bnfAO+80fg/EGTNel5EjyDi6g+2W GWMjiYqKEicI
Mo7ucLu1MkSdvP56/d9iNpvNzRmVvKwcSgB0rQgM8BPHyji6gXHkxJqfTVrW GWw6I/4BD9PJ
3yh2l523GALx1xaQZzHQ1k+RGeNtjXqGpWO7EBzcheCuG7CIR4QbJHVtJL4d OjJw5jzmvNaH
4A4+hK/NELuBA3/tyMcXVc4ljmLekVsbXliEsSlQTLx91MG1Y4sB0FU5ZVdV 7A0spjFphTuQ
/J30jUhg2LLjqEf38OlRB19tjSbzv9eqJctcNYLQ5SfcFlPf+eZpt4XMw2MZ 0knh1BdeDH+0
nQhjc8FeZaWgnkuil6JB7+2JXtEQv/kEdnsu8aEDWJtprujsjyYOIG79itpp xZ13HecObQZe
Y+7L3SuOtR0Ux64/9Kq+JC0t4mppHUvWes43N7vzvljPggWxxGSks2XVStZs SGb+vCV8kaeK
MDYLqkwVtYZuLD+WQ+G1Es4fXE3c6HBOqO0ICUkhYv5up/Dlp/DSqis8/uhT tdNaxZ13G3mp
CZjiXyCg2g1qLUajclfb7RPQnU5qGqaoN3jCP5dtwxYze8wT+Btu3Z18EcZb hNbYimuHVhIe
1pvhEeFAB3RA77EbYcNsTqiQ9fEiGDebkPau0wp3EyrmC+Dj4brn1aw1KIoG RdHQd3oKGTE9
Kv5elWmp93xztRu7HcW/I97A6KcH8sB3Vxg9rD+PPtKdAKMIY/MQw4q+tbMr ujXDV3oS895e
Du7aj4kibIC2bSjLQtL5W+J6Vk1PYdn4J9njJq1wN6Hws8fD2Lf1AGZXZzuN 5VphEdesJeyO
D8IUu59r1hIKC0t4uZuh3vPN1W5r9j8ZqugYGJfCwfhneXh0AhuWjmXmLf5B SoTxZrFbyDt3
CatqZv/2LWDyAOyYc4AhvejS1kD20YNUdqOBsNg4Nkx8nqWmuYR186wjrXA3 0S1sMqZ94/nt
gq3kmy1YzQV8sXYqIxccBrQoegOKVqEFkMFPULQKer1S9mhYfeebp936TmP4 9MIOQoZ9wMaN
7zGaaC4cTePtF023dpIjw/FmhfEMv+/ag30A9Cdh/zPoURj6lw8wBQ/Be155 wrCK5bFf7zFM
Ihb+9Cx+9aQV7iL8BrDrWDIRPcPoEFM5FhL2B1RL1qr7VJbxgNti6jvf3OzO T93Pg89FYs/a
yaWoX+D3Q6z+ZDQ6qe/hU/crge58ai1BVW1o9YYKh+o7jeGodRhmCxiNNZYy 2kDeVh0Vf9aZ
Vrg7xlEZxm7D2ag6UK0W7OjQ62v/8NL2qZcZV0cZ9Z1vbnb7D4pnNQCRfBr3 w9gjwkgTvKak
VVBcDGC0BowNfWmhMWmFO3McVf2+1RvE7h+Ru14YZ8x4ne+/l4takHEkdlci P74IgiCIMAqC
IIgwCoIgiDAKgiCIMAqCIIgwCoIgiDAKgiCIMAqCIIgwCoIgiDAKgiCIMAqC IDQL7vp3pe/W
QOmCjCOxW2aMTcbdGihdkHF0N9kt246VccMBw+0Wzp2+iKFjZ6rG/1YLsrlk b01bg5mMM2B6
pG2TOFvN28mCjTBt+mCqbXSmFnAu90pZSAQdnj6taevXuC2c7Na8Jm2rjKNG jKMq1Bd4/o6z
u+rY1enwad0OP722/usgCaZNq3EdyIzxduEys3t24c+7c6scs/D3hzoy6uMc 1DMf0rfvhzRV
OCL7lXTiXk+npObFdGoDXYO7EBzcheDgjjz8kBcjF3zWqDCsTd1WofE0JPD8 nUa1sdu1Iw/5
6liwK7v+6yCm9nUgwnjbzLkD+UN8EKvWpFAR5bbgKNOBvz7TBf0jUahqFFW/ 8+2q2mDBqpVW
5wF41A59oPMA+nPwmgNVdXAsYSzbNqRWiJy7Oqsed9VWsKNKkOsfhgYFnr8D KR+7hQ5UtYj3
x0HM69tdBseqRAFTSzyhbNdvEcbbjqARs2DbQo6X9eS5zz8C02J6+WtRs9bz 3IT1WAF7/mFi
QzXovT3RKxoW7MpFzVrPyInO8wBZH01l5kenUc8l0UupTBu/+UQDOt8LXdkK pH1nE2Sobstx
15bytoLKkbUxKIoOb72G0IkryReBvKXUF3j+7sDAoOeiKY8I5+76QOcBGR/x Rngw3r5e6HvF
kFlwjgWhA1ibaq5YuX00cQDxe3NFGH8MlICniCKdLQcuASp74hMYPWMoRsBe XMAnfy8AIGND
BPOCkrmmOriQthtfWwn24kK2rSqsCJdaXLiHpRe/QWvoxvJjORReK+H8wdXE jQ7nhLW+liQz
/bWpzJw4At9+sxj9/nD83JTjui2Vbc3fHk2/iJNsTbtMYf5ZXgko5YoqfX0r qS/w/J1OcYkd
uzWb9cvnwOgH8QS314eTFNqPTuTChVPE+8yh53sX6R1yhYj4Hc4v/7xPeWnV FUKC2zV+ISjD
sSl4kKfn96fvmgPMDnmIiRmwc0Bg2TKhyorBqwPEvEF8+6sMeKw/Y4a2Q83c VSNZK0zo0Bpb
cS15IeHTt5NzNZ2GRg4cPuQZennbMD0IES/9lT9cWMC1Q7XLcd2WT8tKUdm/ ZhHEH2dQJz/A
j1HTJks331LKAs/ff7fGh0xh4ENlto9ewYXVz6EAVh0urw8oBdMKfjfIhAKE x8YRMzCVh8/P
hrgwDlvH0CJpNoyby+M38NuVzBibCNOwV2Hbu/w9YRmErKCnixiP3cYlcXL3 bO7/Jo2Zfduj
j93jXB6bPCrStPAAuM6u6NYMX+lJzHt7ObhrPyaKqD8OWxghoU/y6OMDeDFm MaNJZOU01+W4
bQsANkqLpE9/4HVHnYHn73z6s7/QxrFlY2HDDr6set+m1vVRTmnFmLXbnD/D aP0HkTAM4ubN
Iz4mnYRJT91Qa0QYmwht2xDiTSlMj0lk0uTB6GulsLB3VSLFDw9iQsxClscH weE8VBuQ8Tkn
8y0UZO1k6cQUfDzsmHOAIb3o0tZA9tGDNOx3yfPk5hVgzs9m1/L/ZQPwwDVX 5bhuS2mV+zxP
vDIWYtZxJN+C3XqJXWvXkCVL6VtKXYHn75KriG7j3mPTpGQGdwgn1Qq4vD7K kmd8zUWrHbs1
l+TlczDFP4IRhWEzF7Nv3iy2hSxmWCflBlsiNBF+DJ0RQcxLZxjxWI17Gt2c i4Hv8tbS86Hw
itndppPP8kCAhfnDptCvQyIQxrhh4OWhZ+hfPsAUPATveZWzQV218mriAaTz bNfWZd+yY9lw
8DK/bPH/2FWrHNdtua/4HxVlB4xawPvHRtGvg1dZmmjSfiO9fGuHUN2B5+9s vGihdc6ch759
kfk5bejb38T5o2NdXB+6svE+h2DfOc7swxbz1eQnATB2H8RowHd6GDf6BKjG 4XA4fgizs3Mu
Eti+DZlf5wBwJSuXPn1CKs4fOrSPp/Y6Pyd1zuLXIyLclvXJloQ6zzeG8lea GvNE/vff38R9
ILuKVbWh6A1VvpXsWM0WtEZj9YdV7RbMFjAabzLWrrtyXLalZhILqt114Hfh 1o0jV4Hn7wa7
3YxC19cHYLerWCy2amPbmroE375HOXZtHd1u0H0yY+QHfk1Jq7gY7Fr0Rhff bVoDxqZ46cFd
OS7bUjOJwcVtAeFWj6PbJfD87XH9uLk+AK1WqfGrvcrHf5wC8YduWBRFGLl7 A6ULMo7uTLsV
hq25SKHfgzcpxYIgCHcQRv8Hb7qMm/pV2nIpm9MZGeRa5JUIQRDuHBokjGru HmbHxDBvzWeV
7wOrGbzapiNdgpZRJBNPQRDuNmG0XTlG7Jw5zFqYWrGbRcb7b5AIJOcsx2QQ RwqCcBcIo2qp
3HXF0H0aJSUllBx/teK5oJ/95l3Onr3Ir9q5ny2qFnkiWBCEZiiMmgGRbM0o fwnJzumdK3lh
gAZPL090mmBmrz+MNftf/P5Xv+XtLWcBlcNrYvD0aUPHjm3QaQawco9z7zT1 dBIvDBhBzJI1
zIsMxtPLE80LK8kVfRQEoVnNGFMSCAuKI9cOl3bG0mXIeBJT+jN39QfMfQ1i n9+HuTifxJRk
Ui4Vk50UTZ/wORAUwYrVc+lPCuMHdmTlCTM22xUSU5KZMyWcncUdCAJIHM9H aWbxtCAIzW0p
fZ6vSyzsWuF8vSZu90dEvTyGqIVpFBVNxrsssRfFfJa4CIC5CW8R+XIU78zt D8BHn39VUWjY
4uPsWbeFhLlhABz4z3nxtCAIzUcYg8o+VH1Jx+O+yvuGBs/qj4+XbzSglO+I qni5LbxFS0P1
TIIgCM1BGNPLPtgw0Oc3zvePZ/WZzJqtO0laEommxxIqN1ZvQciIsQBMmTGH rTvXsHBKMgCD
eweINwVBuCMom/YZ0AGdx7zDjkIYMiWB8LBEAPpHJ+NJftlUEjq/vISNFyyM jJ1DWIrzcPQH
x5nW24+S8r2xPKpXYvDSiacFQWg2uN5dx65itpSg9TRgUFw/jmO3mDGrdhSD H4YGvKx9u++u
0xjuhEDpQtNyt46jO9Vu16pXa8cKF0kMRvzuwge7o6KiZNMJQcbRHW63vMtX xs0FSlfJy8px
vhWka0VggF/TOVYtIPX4cQps9/Ggf1s6BrZDaUDhdmseGWfA9Ehb6eTmMo6q BZ73pHXbdhi1
zuNZucW069SuYj9CtSCX3BIvOrW2u85zJ9jd0EskbycLNsK06YNpqt0rJbRB k4jXGZaOLQ8Y
vqHpAtYXHCbcuzV9B87iveUT6RncnidXnmhgkz6kb98P62yLNXMJirIEecr0 9qB64Pn2+OuD
WXukAOup1QQHtye9SpTIU+vaE/zwe/zXTZ47we6GYr+STtzr6RWvK4sw3i4o Jt4+6uDascVA
9Uef3AW6d9nBNdJm/jOaDcTxlZrGxo1pWM/vYEi1kFh2VDeF6x+JQlWjam3t XjU4uaID8MBT
evD2oFrg+cskDEsnYsIGrulaAv2rjSudV38wtUTrJo/5DrC7wgbVglW115Pf g6b8iVeEsQmx
V9Esl4Hu7bnEhw5gbWb1gOBx61fUToszDhAhD9G6/L6H/2DiJvQGVI6sjUFR dHjrNYROXEnO
yfWMDJ/N5rXzCO0VyaHU9Tw3wRmoXM1KYuTISGKrBCdPLcgkbuwUYDxhocGE zkzCKl14G+HH
MzPnQkbl/S5dlXWiDq868+juALt1qHyxKhLF2wtfbx0jF+wsG8/Vx3pacdO3 QoSxSb/5Kj9q
XQW6V9sREpJCxPzdzllbfgovrbrC448+VTutFX7aawTsC+fJ8Nl8tP0zsvKd gpq/PZp+ESfZ
mnaZwvyzvBJQymWrhW0bYll/tiXTF0Xy0+sFfPL3gjLBvsK2bQncXx6cnDn0 XWpm3F+jgTiW
JP6bxKhQCWFwu6B1fmke+PcHEFL+7FsK4UNHMHKk89/kicngU1+e5m3319uj GTixFWmFDtRr
Z3kkZgiTNmdjt1Uf6+1ugblaNXcPby/6N61Df0fk4EAZlE3lWGMrriXXDnTf fexGeHg2J/72
HC0/XgTjZhPSvhV71tRO6/foZPJP9mbXjl0k/akfL2XAsPn/5um9iyD+OIM6 +QF+jJo2GWvm
EmAx6+IinYHKMz+r0poawckXOYOT637zAABt/PxEFG8bUujrrSn7PJad519C f+V9ACKjY+nT
Emih48v2yexLryNPs7d7FMdjjEB/Vs2bCniSA2w7VcjSn5XWMdab6Pq1Xckk dtEc+nd4jsjB
MixvypkVM0Y7u6JbM3xvHAc37cVkyKSv/5vYAG3bUJaFjORvievxnZ7CsmOb 2BPt4zItgDGg
N6Mm9GbUhDfI3xVDh+EHGBhSx3Le7Zmawclbct1GtWDmwu1AEJvS/s1jrRUM Rmf0RusVgDB6
9OleEeBJ1ykM9rrP0/zttrDWCkS9xqQ/BGMvsaMdN5F3fXwg53A9Y70pltI6 54XhVefNMxWL
KnuHufaNhbxzl7CqZvZv31ImNHbMObgIdA9gICw2jg0Tn2epaS5h3Tzdpk1d NZX47ScosKqo
agEnPt8OIQ8R8spYiFnHkXwLdusldq1dw5nv6mlE5iM+AAAgAElEQVRnxnly zCqq+TTrZs7B
FN8b3xZekLGDtHwzVrNF+vK2oBUPtvPDWEvgirBVUQIbRVRuQuAuT3O228AT z42FeSl8jQ8B
bdugK0pnz4GLP0hr7qm44e6hA3JZEvkCI0YMYPbWbLBfImleJBqdJ16enmgG RLJHNlesIYxn
+H3XNvh6+zA8BhKWP4MehaF/+QDTvCF4KzqCh88CvCpuQfr1HsMkYNKfnsWv jrQPdOxA3LM9
eMjXE2/v1jy7YygHE8fSZdQC3p+URr8OXuh92zA8omxnI1ONtnWr6FxgET39 PfH270JMtxVs
ndYbJbA/8SHJDOzgg++g1fLjy22Bl5sfTsoD0lf+jY9XPXmat90Bo5awKfY8 /Tp4oeg96dBz
CF+WL6XcjvUmWv1V7NJdepH1MWOZkpAOYz9g9fBAPpsdzMjYdPpHLCbq6fYc XfEGx74uYUC7
Oy/4uvuHt+tB6c6n1hJU1Ya2SuB6facxHLUOcx3oXhvI22rlm5hu0z41GVV9 Fau1BKoFX/dj
1Nt7eHa2BdVeeVw9WplV320K6jHnZyulYFpM/tHJeFpVlPJytO2Y9qmDV1UV rVaRB8F/zHEE
6LtFoqqRDTrebdwW1HHOz67y3Al2g5GhMVuwTrOg2p2xtp1jdLLbsd5kwli+ 12LilCEkAgTF
cXHdGIzYsZU47+6mHNpDcKvHCH5lGWE9jHfcYL7pgOFapVJsqh13E+jeZRnu 0mrRuwm+rlUM
DbvJblMpX5+7aqeiKAi3wTgSu29unDdlnRWfgoIgPR3Sk9h7+jXGdDbQb+Yp Nj6wkf+3J4VF
c2YBMHb1Kda93PmO6dS7IVC6vsvvOX9BixFBxpHY3RAqnmMcOzWRUxsjgHSe 7xLLabuZv4eP
4oRXMK9E/y9zx5ZtafsTuQiaHYoRfz8J5SgIjRZGSyl0fu4tFocBLGJU7Gf4 d23FnPAw+vQZ
yKzEdMKiP2DBmM7iNUEQ7mi0BlMkDkfljc/JWxxMrvhrOLY4lZISG+g83e7N KAiCcEcJY70J
tAoGg9ycFwThLlxKC4IgCCKMgiAIIoyCIAgijIIgCCKMgiAIIoyCIAhNL4xL TkgoJEEQhKpo
pyzcQcS6MdytTyrerYHSBRlHYnddS+nEHZyRLRYbzN26g4og4+huslsLiRw4 8y4m0929ycBN
BQwHUAtIPX6cAtt9POjflo6B7eDSThYkwbRpDQsEXjVwOE0QRNxuzSPjDJge advEey3aObJ2
Dhstj/P6sO94twE2qnmN80VjysjbtYSlx3yZFjUGf20zHkc1As/7GO/Hz6g0 eMwojfRbU46P
G7fbwrmsi7g64+nTnrZ+Ctb8bNKyzmDTGfEPeJhO/kZQC8jKLaZdp3a17Taf YMHf/sOTzz7m
MjKB5333UfLt91XyquRlnsF+/88I8FPKZozAiYyLCDdBwWHCvVvTd+As3ls+ kZ7B7Xly5Qln
IPCYhgcCrxo4vCmCiKtnPqRv3w+pK2iBNXMJirKkUXGIrZl/p19ELI8N6YW2 gTY21heNKaNt
v0EQ9zyT159u1sOoZuD5h/w9CZ25hvwGjpnG+q0h4+PWG32GWeU21/g3/Z8n SV0biW+Hjgyc
OY85r/UhuIMP4WszsJ5aTXBwe9JdbDufd2AlMXu+5i035U5Z/k61vKnLf8vD PYM4W1J1KQ38
9AEvEbebIPOf0Wwgjq/UNDZuTMN6fgdDsAEKmFriSfVA95Ujs0Yg8aqBw10E EberqosAQHbc
xSLXPxKFqkbV2oexalsUHYAHnjVLdVmXs75988dD7CGeDjCUBTtWXG6tX72M enzh7qJuSBlK
Z2J2x7EtYiV5zXkgVQs8byNtUxz7loYT89Hpho0ZN33szm/uxscPir47G1UH quqg8NhiYDGF
ZX9vfOYyfSMSGLbsOOrRPXx61MFXW6PJ/O810LUE+rsYdyoH1yQwKeplNrkp d93zXYH+tFDA
vHc2facn835aEYPaKtWFsbW37NV3M9gAQh6idfn9Cf/BxE3o7Ry0GTuIn1gW 6D50NllWZ+e5
CiTuVhzyDxMbqkHv7Yle0bBgVy6gcmRtDIqiw1uvIXTiSnJOVg9Efih1Pc9N WF8WpDyJkSMj
iQ0va0uvGFILMokbOwUYT1hoMKEzk7jmsq6qs+P9/GkDvP/b4Jr3ZDCnridU GcGOY/trl+HW
F42wuY4yjD1GMJpFJB0puENGlZZOQ99g//z+bHhpIVn2+seMyz422936Tc2q HB+3I+cObQZe
Y+7L3StXB4Pi2PWHXnXMQE/yj21BjOj1YD2lt6EwYyuDBscSu/MiozpV18B7 IIxePxNhvBl+
2msE7AvnyfDZfLT9M7Lyqy5Mk/EespoL548zaV8sS/flku8mkLg7MjZEMC8o mWuqgwtpu/G1
lZC/PZp+ESfZmnaZwvyzvBJQymVr9UDkP71ewCd/dwqF3XaFbdsSuH90Ihcu nCKeOfRdambc
X6OBOJYk/pvEqFDOu6ir2rj7v0wyiGNAgFL5rRDiQW7qevz7Ps/w3e/ywP5J bsqo7YvG2Fxn
GYqJcVEQ8/m5O2psPfrSnzFxhuwt9Y8Zl3288KBbv9mLK8fH7UheagKm+BcI 0Fb/wjDWcd/V
nLadfaZXCa5zGuwBJDK4bxjdlh0n5qnaInpP/7nT6S66eFP4PTqZ/JOHmNET kv7Uj+AOPoxc
/hn2skD3rw7tjp9/d16aH8SqrFz2Jy0CDrFq3lRmxv+dVGDDqUL3KyyvDrD0 DeKXr+HL4kDG
DG3P/jWLID6WQZ380BsDGTVtMl1bVAYiH/R4d7yrjR9nW343yISfX2fCF8XB vFR0Dz4AtKSN
nx9+fgYXdVXfmPjiiT2Y4gfhV3Upt288wX2fJ37/VSY8/qCbMlz54utG2Fx/ GQ8PiMZ07ds7
a3Bp78OH7/lPckPGjOs+vubOb7d1aEEV8wXw8WhMI+0c3RDLsBm/qCdGjDPs rMkEG1YmkeXi
qZx73p38pChbE2AM6M2oCW+w8aiD81uj2Tb9oHOJklFa5V5PK0zcQ2lFIPHX +MPLv2P+Vxe5
MDnYbdndxiVxcvds7v8mjZl926OP3U1JUV3Dw/2AsFfMLpwzsOs2ymJhu6tr T7XydB4GF4Ns
LFHjgoh54z3y6yqjli90jbC5/jLs3zmjKd4Bq+gK8vcnsQ89muKGjpnafUwj fX97oPCzx8PY
t/VA3T8MVp1N2s+yYRW83K9dA8oPY/Wui8xnDsFhS6g5b76ns+xBe9OkrppK /PYTFFhVVLWA
E59vh5DWtR4jcD6S0KKRgcQt7F2VSPHDg5gQs5Dl8UFwuIAer4yFmHUcybdg t15i19o1nPmu
noZmnCfHrKKaT7Nu5hxM8b3xbeEFGTtIyzdjNee7qCuPql+orX/ei4yYXdUH kmkgMcv+Tey+
WXQI/wc76imj0hcAVj55I4wJyz6rx+a6ynCS9fki8G7uQYmucCn3Evl5p9m1 KoYOw+cwadNi
Rv2mgWPGRR971+O325VuYZMx7RvPbxdsJd9swWou4Iu1Uxm54HBZihRyzl6i IP8SeXm55BzZ
zgbieLRBz2wVYfN8kAkpxxm2bwoPzdxabXxJrIIm4IGOHYgb3IO4CqGI5uC/ xqL837vVAoPr
AB+PskDi2eH061D5NEDUprMMheqBw7s5c32Xt5aeD4VXfNNtOvkspoChvH9s VJUyojl44IE6
ApF7AIvo6b/I+efoFZyf1hvF/gDxIeEM7OADpnf455DtDK5RV9Vlif7+bsBA 9pybyajy+4wU
YcePmAv7SX2oH29d7sHhiTXKKF7t0hdYM1ny9lZC979XdV7q0ma3ZQDYM1g+ D0bvD2jGI8kD
SOfZ4DbOP0PG8v7uHEY93g5oyJhx3cdkHnbvt263mQuqjl+/Aew6lkxEzzA6 xFTO9BL2BwCn
nCb2bFOR/JHBP8M0/8PK2zzuygUof8JR3511JzfyZNcwZvQ8xbJRzltHGofD 4fgh7M3OuUhg
+zZkfp3j/F7MyqVPn5CK84cO7eOpvc7PSZ2z+PWICLdlfbIloc7zjaH8labG PJH//fcuH07B
anUu5fT6hk3D7WrNQOJ1Jsaq2mqldZZRf53WzCX4hkP+0cl4WtVa8aVVVUWr VdBq3ddVzhfx
GgbuW03hpy+7v5dTTxkVN8uPzMO/3zXOq/H432AZAKnLB9B3+mAuqFGuL4xb TNONoxsfM/X1
cXO22/mYUV3jPJeZSntMJ0t4MeDm7ZYZI031mpIWvb5xv2I1KpC4VnE5KBpc hk2FjLK7Ny7K
URSl3rrKeXxaOqPjgui/IJCj055sVHtrkvPZDkavea+2KDaijIIvZtN3egrv pyX/KKLYtOPo
JsZMPX3cnO1W6ru2rEUYJ63glwFNY/ddP2O8a1DN5Fu0TRZf2m4t4JJFy4P+ xh/921U1X8Js
N0js7Cbu47sZmTHeLShG/JtwEqHV+9FWf7uY9qDrGaf0sXCDyEa1giAIIoyC IAgijIIgCCKM
giAIIoyCIAgijIIgCCKMgiAIIoyCIAgijIIgCCKMgiAIIoyCIAjNAnlX+jZi 88cbxQmCIMIo
1ORcbp44QRBEGIWaxPxxujhBEH5E5B6jIAiCCKMg3P4UZJ/mdK5ZHCHCKLhF LeD06VzU26Ix
dnIzTnD6UlO1RuWzlfPYmm25K7vWbs3jxIm86iFvzZ/xi45dWHmqSMa+CKPg DsvJ1XTp0p60
20I7SkgO6sGopJNNVJ6N1PGzSCu0353feV99SI8eH1K1azP+OR+id7NwcDsZ /D8S8uNLc0DX
EujvOkS6asGCJwZF6+KUBa2hdlRBu9aA0sCet6sqKEqVMgxMdjiY3IA21M5b u2ytAh5B4KFr
mE312Ve7DgslLtvWMD/UZYPFomIwKBXlodT0tbu8dlS7FkUL+u5R1Iy61GXM Oj73NNywzYLM
GO/m9TWfrYxE4+mFl6eOEfN2YgHU00mMGDGVmMhgPL280A2YzWlLZXqdpxee Og0DBrzA+tMW
1NPrGRG5vmLGcnr9VKauP42anUSwRoPO0xOdRsPspBPYsbA+cgADBoxg9tZs t22wXzpMzIDK
vPN25tYShsNrpqLz9ESj8WJ8Ojjlw3V51aw+ncSIEZHEvFBmX3AMJ8x2px0v zCZpzTwGBEdy
wmJh57wR6GqVVYcfquQ/mObK/sr6p47Q4OXlyYh5SexcMxWdpxc6TSSHzXY3 vnPWfXhNDBqN
zll35ErOZ64nLHI9VqfUOtvs5YWXTtOAPhVEGIVqXNoaTb/xrThV5MBRcpYe s4bwalI2NtsV
kpMX4T10NZcvHue1lFgWpuSSu3UK/cbD/pyrFF1OJzglkf8W27EVF5KcUFhx j6u4cA+L/vsN
Wq9uJKTnUFRSwsXjq4kdGc5xi4Fn3nqXPinJJOV847YN6YkRzAlOpsTh4PKp 3bT+rqR62/fE
0ie8kN1nL1N0OZ1oQMXutrxqC2/bFZKTE3jg+UQuXz7FXObQ4+2D2GwWkhNj SfyqJVHLImHH
DIbM6sDxyyWUXD5Oh1lDmJGU7d4PNfJ3bO3K/sr6O0w+xcX0D0ieNZJZab04 e/ksq8MSiHgv
3Y3vnH3WJ/wkO05dpujqWcYFlvJ/5gK2JhQAkJ3kus3u+lSQpbRQY7a4d+Mi oD8r50wFPDkP
JJ8q5N1OpRC0gsnDu6MArywOIuh0LiEHEghafJwn2xkBLZ2D4BugfH1eORBa EYQOrbEV5o8X
8sKU7Zy/kg6EoQMUYxse7g+HKHXbhqjWHWDWG8R1uMovnujP2OHtqrd9yRyC FqczINAPMNAu
CL6pw6Z1BFbJ77QvYrAJBfj9sjhm9Uvl2miAxXwYH4mChZUDEui/Ip3ufgrQ ncjVYXR5dw+9
vdz4gdIq+QF7Ace31ra/ov4BnVHsOiKAn7/yDIF+CsVD+sM3uPGdyt5/LIK5 xxnc2Q/wY0zU
ZKwZi8sX5vz7XVdt/ow/LXbVp1+zcrjcgxRhFKi8yWjjOwsQ/RqvTQzGXmJH GzmR93x8IOcw
pJdiA+cFTiuCuAdLUdUCatytDPKo+NjCA1Cvs3Nma4bsieP41r0EeWXSw+dN bJXSBFx32wY/
QxJnu/6L7XtTmNojnPTo3djiB5QNNltZW2y1ltdubapFpX12WwnQsnJGWWF3 Ddf9BLhSXLac
duOHivz2Ou2v8K+2Nd2D4BtbCaBgK3X6xXVeG9818kdmZ5tLq9dZ5ctLkKW0 QArnzlyi4NIl
cnOv8vOho2FOCl/jQ2C7NuiK0vl/X1x0eaFDC37xagTpU+ax9UQGnyUtKbuv V5Yg/XNOXrJQ
cHonC8en0Eqxc/U8MLQXXdsZOHv4IOm1Sm7Bk78Z66INX7FnZSLFnQcx+Y2F JMwNgkN5VC6m
DTw2Koz0LZ+TbVYpOL2Xj9JBQe+mvNo2kX6eHLOKaj7N6qlzCJrbG+9qCQyE vBhGyrtbnPfi
LKdZ/3wyYbNC+bU7P9QQ6frtr/ol0ZC8Bp4cNxZmrePwJQt2yyV2rllDVml9 bQ5B77JPBZkx
3vU4Z3Qjg9pUHOm/OIXkuEX0aeNVcSw6+SzDAIKqTzJbKRD43DvsmDuDIT2C CIt4jf7ll2P3
51gcNoU+bRKBMCLCwMtDz7C3PiCoyxA855SXFFYxR/EArqgQOGYJydnhNdrw JT65awlqHV6R
L/nss1T9jdX00ltEv9uFjj5TKo6NQuumvLMufLGIIJ9Fzj/HruBiVG/IOFzN 7s4vv8fqg63p
4hXrPBCxmstjOuOHaz9QzW9KnfZXrcejymWkKzviLm/gmAV8cHRUFfuiOXb0 fjDV3WYydrns
U+HWoXE4aj4scGvIzrlIYPs2ZH6dA8CVrFz69AmpOH/o0D6e2uv8nNQ5i1+P iHBb1idbEuo8
7wpzXgZpGef5VmekS69eBBhvv5G1+eONnMvNa9S70nbVQokNPOt7hMNuocCi w8+ogCWDF7yC
6JVexGSTAbBjMVvQGY3VZ092C2YLGI1VZM2ey2xde0r2Xyb+ST/3bbCrWEps dbTLjtlswbNm
nfXYZMlYgtdYuJo2GU+LimKoux8tZjN2PDGW93edfqjts1r2N7hj3Od12qer eNSn3jYLspRu
eux8sfwF/B8OYvCSf7Dm9X509fckfpfzVz1r5hIUZQnN9eUrrWLA0JDn2kpO 8gsfTzQaDRqv
IBJf+4AXKsRAi8GFQKE1VLuwTywZgUbXnljGMqSzse42aJV62qXF6KrO+myy qZDufOumPlEE
MBiN1QWmTj/UbX/jOsZ9Xqd9SsPbLMhSusllMe9fDJyeyLgNZ1n2dCBgZ1ds D4YP/1+eta4j
UOdc/ng2YGam4om+kQ8x3zYYevP51ctcLSoGnRftHjQ2uoiuL7zL2aGLad2u HYYfyWBD199z
8bIW44/oB0FmjM2evIMbgWiing6s+C4YNGkhJhL57MvjxI2dAownLDSY0JlJ FGatZ2T4bDav
nUdor0hSrRZ2LRiB3tsLX28dIxfsxArY8w8TG6pB7+2JXtGwYFcuoPLxzP7M /DDj9tRGox/t
2rW7YTFQjA8SGPjjiWJZI3jQz/Cj+kEQYWz2y+i8LxMxxT9H26qH/XoRaYJP 0+5j3F+jgTiW
JP6bxKhQFJuFbRtiWX+2JdMXRcLOGQyP6cDBCyVcu3Cc9jFD+OPmbDI2RDAv KJlrqoMLabvx
tZUAdii+QuF3MrAEQZbSt7Ewmi+Az/2un/kqshTTuvsDALTx80MPWP/P+aDv ujjng8KrQhMI
WZbOI2UP3Y5LCCN4xWe8OLIDxLxBfPurDHisP2OGOh+2fWZ5Os/IuBKEu2fG qObtIW5qDCt2
nq32+fZF4WeP92ff1gNl76KW6+VFvsiA0Mc6YLcBJg8XkuoanQdwtZSu45I4 uXs293+Txsy+
7dHH7sEu40kQ7j5htBdm8OaiOXyUVVTt8+1M56FRsG88k5bvwazasVtzWfta FzbwGiNMRrQt
vCBjB2n5Zqzmmm/mG3jy+TD2rdxClhWwnubDl5IZNqMnx1YlUvzwICbELGR5 fBAczkNF5ZM3
XuCNj0/LyBKEO1IY7Spms7n65qg658zKq+bnuvL82PcK/Adz4eAHXJo+EH9v HXrf9kQcfo39
598mQAtKYH/iQ5IZ2MEH30GrnTNLU2X+Ti++R0LvWIJ9NSi+XYgbt5p3R/2c 7/LW0vMhTxRF
Q7+YDmz627PosZN/OJEdl4plZAlCM0b7woARPDTqFfpwiH+c7s66hb/m5Jo4 +oSXP7bfnxW7
3yNyQGBdi2wONzrPD4ffI2P4VP0NVrMFm84To77KM2Ladkz71MGrqopWq6DV gnq0Wm5eXObg
mdlmbFUeuh0Utwc1VsWq2lD0lc/c/X6Xg9/LuBKE5i2MiSnJkJJcpmeLOZMU TZ/wRRAUwYqp
gXwUPovxAzvC8as87+a99ew68kR2v10eidCiN7pvi6LU/UCty7xaBb1eHsQV hDtyKd0/bgdF
Dge2XS+Snuh8B3VuwltEvhzFO3Odb5N+9PlXbooo5rNG5xEEQbiNZ4wAXq1b O1/y195bsVuI
oitbHCpe9RZyI3kEQRBu6xkjVbc+GjEWgCkz5rB15xoWTnEuswf3DnBTRIsb yCMIgnCbzxip
8hhf55eXsPGChZGxcwhLcR6L/uA403r7oZa/6Vb1sT+PuvMIgiA0O2GsveuY kefe2ILtNTNm
1Y5i8KN8IxC9aTwOx/iydN2rfMZtHkEQhOY5Y3R1wmCkse/q30geQRCE2w0J bSAIgiDCKAiC
IMIoCIIgwigIgiDCKAiCIMIoCIIgwigIgvCDoRUX3H5k51wUJwiCCKNQTswf p4sTBEGEUSjn
6WdGUloqfhCEHxu5xygIgiDCKAiCIMIoCIIgwigIgiDCKAiCIMIoCIJw62i2 j+t8siVBek8Q
BBHGcn49IkJ6ThAEWUoLgiCIMAqCIIgwCoIgiDAKgiCIMAqCIIgwCoIgiDAK TYFakE1qZjaq
uEIQRBgFJ9qSL+nbsyMLjhSIMwRBhFEA0LYdTv7uucS9vV1mjYLwY1yDd76J Fs5lXcTm4oyn
T3va+im3Zjmct5MFG2Ha9ME0tgZrfjaX/Z8l7c1iLuVbCPA3NL4B5hMs+Ntp Xpj2Syy5V6rZ
r/Nqc2Nl/li3FvJ2siAJpk1rvC8FQWaMLlXmDLOCuxDs4t/0f568ZdXar6QT 93o6JTeQ9+L+
ZQR37UhwzyAW/L+cG6o/78BKYvaB5tQGutaw+w8fn2lWXWi/kk5czI35UhBk xugKfXc2qg6n
RmYuwbcnFKqT0Vebkliw4oleqekOO6pdS83DqtWCVm+o5jy7akGtWobOw/lf XWmqHLdrDRX1
dBq1kLTCNMaymGUvmqqkU0FRanVa7eMqB9ckMGn6myi6bUB/9hfu4VF9A0TI TR0AVquKXq9U
tBmlug/c+7G+Ol37pXKKq9TyZUPaKwgyY7yxRRpfrIpE8fbC11vHyAU7sZYd P7I2BkXR4a3X
EDpxJTknkxg5ciqxE4Px9vVCHzqbLKtzqb5rwQj0tcqovpx3ncZZv97by1lP 6At8lGUBoBig
1LkAVs8l0UvRoPf2RK9oiN98Ajtgzz9MbGjl8QW7cssU7CT/2BbEiF4PVrSg RY01qJq1npHh
s9m8dh6hvSI5lOG6DjUriZEjI5k5UoOvrycjFySxa+1U9N5e6JVIjpjtbvxo 4aOJI1iVanbO
YHfNZmT8TuwABZ8RHjqVTNW1X2q2La248lvcnLqeUGUEO47td227IIgw3hz5 26MZOLEVaYUO
1GtneSRmCJM2Z5O/PZp+ESfZmnaZwvyzvBJQymXrFbZtW4T3kNVcOH+cSfti Wbovl3ObZzA8
pgMHL5Rw7cJx2scM4Y+bs6vV4y5N3vYpDJwIu7+6SuGFdIL2JXKx2F57Wm/o xvJjORReK+H8
wdXEjQ7nhBUyNkQwLyiZa6qDC2m78bU5F5vmtO3sM71KsLG8hBTCR7/AxImR hI8cQfzm09ht
FrZtiGX92ZZMXxRJoK/rOuy2K2zblkD7Cac4f+wDtsWM5PWMXpy8cJaEYQlM WJ3uxo+X+alP
MhM3ZwIqu+bHsi1uBRl2MH+5gw1XO+DY4dovNdvW7h4gxIPc1PX4932e4bvf 5YH9k1zaLgh3
7VK6vr0YG7Ytmcr+pEVAf1bNmwp4kgNsO3WRwamLIP44gzr5AX6MmjYZa+YS MK3g1aHdUYCX
5gfRM+sc//NpAiHL0nnETwG6My4hjOAVn/HG/MrZ4p4VrtLsoZdXAqb5x3m8 rRHQ0skERa46
ydiKa8kLCZ++nZyr6UAYOkDn1QFi3iC+/VUGPNafMUPbAXaObohl2Iyz6KFi 9vry7yPodR/Y
gBb+90NxKbCYdXGRzh807AWkbq9dB5SCaQW/e6ozil3HOKDLS88Q4KdQHNof ikrd+LGQBb+e
C/1SKZhkY+PVCKKGJbD58CWePrGdkMgEDq+Y4tJ3/zu/etusmUdh33iC+0L8 /qtMeNRI5ilX
tjd8jAjCHXmP8eb3ZLRRagWiXmPSH4Kxl9jRjpvIuz4/YcezbrJklFI5n2uF ycVdL50HcLXu
4NDONMVlolVeRvWydFXuc+6Kbs3wvXEc3LQXkyGTvv5vYgMeGZfEyS7/Yse+ FGb2DScjajfW
2AfZsApefr2qUIQR0u9JulVZTlszy0uvu45qdmtb8z8mKLKVAAq2UoDrbvzo gxEdwwhn6bxW
eEW+y9Qegfj/8W2uXk3n+cRAvttYt+8qfV0KjCVqXDoxb7zH6E+j6ObK9rgB FQNa9uwUZCl9
Qxh44rmxMC+Fr/EhoG0bdEXp7DnwDU+8MhZi1nEk34Ldeolda9dw5ruasgrQ giefD2Pfyi3O
+43W03z4UjLDZoRwX5V6XKcJZcj4CDKmz2N7agZfbF7CxAzwKJvNflN6BdRr qNgx5wBDetGl
rYHsowfJKJuJ7l2VSPHDg5gQs5Dl8UFwOAIOdN8AAAKiSURBVI/C07vYQByP +lf9zivCxQq9
Cu7qqE1tyW/hxo8XQf8zhg1LZ97SFMYM6ozRNJzR+xaxKiOCJwJ93frO5W9E poHELPs3sftm
0SH8H+xwYbs88ync9TPGG6byR14CRi1hU3Y4/Tp4VRyL2nSWUaMW8P6xUVWO R3PwwAPV8uoA
Hw/o9OJ7JBxpTbBvrPPEuNVcGNUZMj+Fbs5D7tL48Q5b42cwvG8Qw8a9RkhZ 2anLf8vAmHRg
IGEtj7PpLx9gCh6C97zKGaAOHd/lraXnQ+EVxzadfJa8D5/ANH81ftWM9qKF ti5fKAx1WUdt
n3lUGTa6evwIBno/FwE5gTzRFqAjo6NgQ8nTtNWC1q3vdlWrs1zc7fgRc2E/ qQ/1463LPTg8
sbrtermehSZC43A4HD9ERdk5Fwls34bMr3MAuJKVS58+IRXnDx3ax1N7nZ+T OmfVuRT6ZEtC
ky6V7KoF1Q6Kq0dw7LqKR1Tqwmo2Y8MTo1FpeBq7hQKLDj+jAtYMwn2D6Hms iAndXDx8bbdg
toDRaKjZeKyqraztucxU2mM6WcKLATfwKLS7Om7Sj03hOzcVVrFdEGTG2LRO UAwuZxvujrtC
bzQ2Po16kl/596lctk76gAXd3IiS1oDLKrRKpXBbizBOWsEvA27w/RB3ddyk H5vCd24qbNCX
liCIMDYn9L1Jyb/MVUsx6Lxo62+8yfJMxLxtEr8KgghjM9dGox96o/hBEG4n ZHcdQRAEEUZB
EAQRRkEQBBHG/9/OHdoACAMBFJUdgk3YgllgAVwFzMIWbIJigQoEoqq2CdCE 95KKmlOXLw9A
GAGEEUAYAYQRQBgBhBFAGAGEEUAYGxRC/YtxbmoG8I5fXNdJ6XpsxjblW9nD clbN2Neu+Pfj
YSvhYzeMqh8jtdv2QAAAAABJRU5ErkJggg==
--------------050909030705050106080305--
Re: Encoding problems in Tomcat [message #26160 is a reply to message #26119] |
Fri, 18 May 2007 18:43  |
FIXED, Changing iso-8859-1 --> MacRoman (or cp1232) further details in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=187895
Regards.
Roberto.
Roberto Sánchez escribió:
> I've opened a bug entry:
> I'm desperate, My first release is only waiting for this problem.
> Please help...
>> about the correct site to place it, In any case if somebody has any
>> idea...
>> perfectly.
>> // osgi.nl=es_ES
>> Any idea ?
>> Thanks in advance.
>> Roberto.
FUDForum. Page generated in 0.04589 seconds
