Starting corona M8 on OS X - hacks and help needed [message #2180] |
Tue, 27 February 2007 22:03  |
I think I have the server side of corona M8 running on OS X. Here are
the current instructions on how to hack it ...
Download Eclipse 3.3M5 for OS X
Download the server all in one for Linux --- yes, Linux
Navigate to the eclipse directory in the Linux distro
Delete eclipse and eclipse.ini
Copy eclipse and Eclipse.app from the OS X distro to the eclipse
Copy the following plugins from the OS X distro to the eclipse plugins
org.eclipse.equinox.launcher.carbon.macosx_1.0.0.v20070208a
org.eclipse.core.filesystem.macosx_1.0.0.v20060603.jar
Open a terminal and run the server with the following:
../eclipse -clean -console
NOTE: I'm getting a couple of errors on the console at startup. Could
somone on the corona team please take a look and see if this is
something that needs to be debugged?
Once I hear that the server console output looks good, or have lots
more time, I'll try to get the client side up and running.
Bryan
Console output ...
osgi> [INFO] logReaderService: org.eclipse.equinox.log.LogReaderService@8202f4
[WARN] [2007.02.27 08:42:06 CST] [org.eclipse.corona.logger.log4j]:
CoronaLogManager is not available; log level settings won't work.
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona.logger.log4j]:
[{org.osgi.service.event.EventHandler}={event.topics=[org/ec lipse/corona/log/NEW_LOGLEVEL],
service.id=46}]: ServiceEvent REGISTERED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona.logger.log4j]: Log
service enabled...
service.id=47}]: ServiceEvent REGISTERED
[{org.eclipse.osgi.framework.console.CommandProvider}={servi ce.id=48}]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona]:
[{org.osgi.service.event.EventHandler}={event.topics=[org/ec lipse/corona/log/LOGGER_START,org/eclipse/corona/log/LOGGER_ STOP],
service.id=49}]: ServiceEvent REGISTERED
[{org.eclipse.corona.log.ICoronaLogManager}={service.id=50}] :
service.id=51}]: ServiceEvent REGISTERED
[{org.eclipse.osgi.framework.console.CommandProvider}={servi ce.id=52}]:
[{org.eclipse.corona.core.IRuntimeContextFactory}={service.i d=53}]:
[{org.eclipse.osgi.framework.console.CommandProvider}={servi ce.id=54}]:
[org.eclipse.corona.collaboration.ecf.container]:
service.id=55}]: ServiceEvent REGISTERED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona.container]:
service.id=56}]: ServiceEvent REGISTERED
[{org.eclipse.corona.container.event.IContextContainerEventA dmin}={service.id=57}]:
[{org.osgi.service.event.EventHandler}={event.topics=[org/ec lipse/corona/container/*],
service.id=58}]: ServiceEvent REGISTERED
[org.eclipse.corona.container.services]:
service.id=59}]: ServiceEvent REGISTERED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona]: Starting
bundles: [org.eclipse.equinox.event,
org.eclipse.corona.collaboration.ecf.container, org.eclipse.corona,
org.eclipse.corona.collaboration.ecf]
[ERROR] [2007.02.27 08:42:06 CST] [org.eclipse.corona]: All not
persistent start attempts didn't work for
[ERROR] [2007.02.27 08:42:06 CST] [org.eclipse.corona]: Failed to start
org.eclipse.corona.collaboration.ecf non persistently; starting
persistently
[org.eclipse.corona.collaboration.ecf]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.commonj.sdo]:
BundleEvent STARTED
[{org.eclipse.osgi.framework.console.CommandProvider}={servi ce.id=60}]:
[org.eclipse.corona.container.services]: Specified system environment
variable CORONA_CONFIG_HOME is not a directory.
[org.eclipse.corona.container.services]: Plugin preferences
CORONA_CONFIG_HOME value is not a directory. Possible bug!
[org.eclipse.corona.container.services]: CORONA_CONFIG_HOME value was
not specified. Setting default directory as corona configuration.
[{org.eclipse.corona.core.resources.IConfigurationManager}={ service.id=61}]:
[{org.eclipse.corona.container.manager.service.ContainerMana ger}={service.id=62}]:
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.common]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.ecore]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.ecore.sdo]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.ecore.xmi]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.emf.ecore.change]:
BundleEvent STARTED
context container name: System
context container uri: org.eclipse.corona.container/System
[org.eclipse.corona.container.services]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.corona.container]:
service.id=63}]: ServiceEvent REGISTERED
[{org.eclipse.corona.container.event.router.IContextContaine rEventRouter}={service.id=64}]:
[{org.eclipse.corona.collaboration.topic.ITopicManager}={ser vice.id=65}]:
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.corona.container]: Corona
Topic Manager started.
[{org.eclipse.corona.container.repository.IRepositoryAdapter Factory}={service.id=66}]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.ecf.identity]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.ecf.provider]:
BundleEvent STARTED
[org.eclipse.corona.collaboration.ecf.container]: Corona ECF server
listening on port: 3001
[org.eclipse.corona.collaboration.ecf.container]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.corona.soa.common.axis2]:
BundleEvent STARTED
Host org.apache.axiom.api;version="1.2.0" Bundle org.apache.axiom.dom
Host org.apache.axiom.api;version="1.2.0" Bundle org.apache.axiom.impl
Host org.apache.axis2;version="1.1.0" Bundle org.apache.axis2.databinding
Host org.eclipse.core.resources;bundle-version="[3.2.0,4.0.0)" Bundle
org.eclipse.core.resources.compatibility
Host org.eclipse.equinox.registry;bundle-version="[3.2.0,3.3.0)" Bundle
org.eclipse.core.runtime.compatibility.registry
Host org.eclipse.core.filesystem;bundle-version="[1.0.0,2.0.0)" Bundle
Host org.apache.axis2;bundle-version="[1.0.0,2.0.0)" Bundle
org.eclipse.corona.axis2.sdo
Host org.apache.axis2;bundle-version="1.1.0" Bundle
org.eclipse.corona.axis2.util
Host org.eclipse.equinox.launcher;bundle-version="1.0.0" Bundle
org.eclipse.equinox.launcher.gtk.linux.x86
[INFO] [2007.02.27 08:42:08 CST]
[org.eclipse.corona.soa.provider.axis2]:
[{org.apache.muse.osgi.soa.core.SOAPProvider}={MajorVersion= 2,
Name=Axis, MinorVersion=0, service.id=67}]: ServiceEvent REGISTERED
[INFO] [2007.02.27 08:42:08 CST] [org.apache.muse.osgi.soa.axis2]:
[{org.apache.muse.core.platform.osgi.ResourceManagementProvi der}={service.id=68}]:
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.corona]: ...deploying web
service for: TeamRepository
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.corona]: Jump starting
web service extension bundle:
org.eclipse.corona.container.project.services
[org.eclipse.corona.soa.provider.axis2]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.corona.soa.client.axis2]:
[{org.eclipse.corona.soa.client.SOAPProxyProvider}={MajorVer sion=2,
Name=Axis, MinorVersion=0, service.id=69}]: ServiceEvent REGISTERED
BundleEvent STARTED
[org.eclipse.corona.container.project]:
service.id=70}]: ServiceEvent REGISTERED
[{org.eclipse.corona.container.project.event.IProjectContain erEventFactory}={service.id=71}]:
[org.eclipse.corona.container.project]: BundleEvent STARTED
[org.eclipse.corona.repository.adapter.team]: BundleEvent STARTED
[org.eclipse.corona.repository.xml.team]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.osgi]: FrameworkEvent
PACKAGES REFRESHED
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.update.configurator]:
[{org.eclipse.core.runtime.IBundleGroupProvider}={service.id =72}]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:08 CST] [org.w3c.dom]: BundleEvent STARTED
[org.eclipse.corona.container.project.services]:
service.id=73}]: ServiceEvent REGISTERED
[org.eclipse.corona.container.project.services]: BundleEvent STARTED
STARTLEVEL CHANGED
[INFO] [2007.02.27 08:42:09 CST]
[{org.eclipse.corona.container.project.repository.team.IProj ectTeamRepository}={service.name=TeamRepository,
web.context=ProjectTeamRepository, service.id=74}]: ServiceEvent
REGISTERED
[INFO] [2007.02.27 08:42:09 CST] [org.eclipse.corona]: ...deploying web
service for: ProjectContainerManager
[INFO] [2007.02.27 08:42:09 CST] [org.eclipse.corona]: web service
extension bundle already active:
[{org.eclipse.corona.core.resources.IContainerHome}={service .id=75}]:
[JAM] Warning: failed to resolve class
org.eclipse.corona.soa.common.annotations.IdempotentStrategy
[{org.eclipse.corona.container.project.manager.IProjectConta inerManager}={service.name=ProjectContainerManager,
web.context=ProjectContextContainer, service.id=76}]: ServiceEvent
REGISTERED
service for: ContextContainerManager
extension bundle already active: org.eclipse.corona.container.services
[{org.eclipse.corona.container.manager.IContextContainerMana ger}={service.name=ContextContainerManager,
web.context=ContextContainer, service.id=77}]: ServiceEvent REGISTERED
Re: Starting corona M8 on OS X - hacks and help needed [message #2273 is a reply to message #2243] |
Wed, 28 February 2007 09:22  |
On 2007-02-28 03:57:34 -0600, Marcin Okraszewski
>> persistently
> Seems to be OK. For some reason it wasn't able to start it
> "non-persistently", but the final info says it has been started. To
> double check you can type "ss" in console and check if
> org.eclipse.corona.collaboration.ecf is active.
I did the ss command and org.eclipse.corona.collaboration.ecf is
active. I'll try to get the client up and running in the next day or
two.
Bryan
FUDForum. Page generated in 0.04598 seconds
