RCP - move "configuration" folder to some user-specific path? [message #263181] |
Thu, 22 July 2004 10:19  |
is there a way to have all variable ("state") information stored in a
user-specific path instead of below the RCP installation directory?
I'd like to deploy an RCP application to a Citrix MetaFrame server
farm, and this would require that multiple concurrent sessions use the
same installation path - I'd like to have predictable, user-specific
results though. I hope I'm not askiing to be spoon-fed here, I'd be
grateful for a pointer...
-- Jan
Re: RCP - move "configuration" folder to some user-specific path? [message #263435 is a reply to message #263221] |
Fri, 23 July 2004 04:44   |
On Thu, 22 Jul 2004 15:19:51 +0000 (UTC), moritzpost@gmx.de (Moritz
Post) wrote:
>in eclipse 3.0 the preferences framework has changed quite a bit from 2.1
>a good reading is this:
> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/documents/user_settings/faq.html
>when you want to specify the location of your preferences (other than the
>default ones INSTANCE, CONFIGURATION, PROJECT, DEFAULT etc) you would have
>to implement the IScopeContext with its getLocation() methode. Or extend
>the AbstractScope.
I had already read that, but what I was trying to ask was whether it
was possible to change not the logical hierarchy (ie. scope) in which
to store the preferences, but to store them in a different filesystem
path for each user (actually a Windows user profile). From my
understanding, scopes won't help me with that, or will they?
-- Jan
FUDForum. Page generated in 0.60088 seconds
