Home » Archived » Corona » Starting corona M8 on OS X - hacks and help needed
Starting corona M8 on OS X - hacks and help needed [message #2180] Tue, 27 February 2007 22:03 Go to next message
I think I have the server side of corona M8 running on OS X. Here are
the current instructions on how to hack it ...
Download Eclipse 3.3M5 for OS X
Download the server all in one for Linux --- yes, Linux
Navigate to the eclipse directory in the Linux distro
Delete eclipse and eclipse.ini
Copy eclipse and Eclipse.app from the OS X distro to the eclipse
Copy the following plugins from the OS X distro to the eclipse plugins
org.eclipse.equinox.launcher.carbon.macosx_1.0.0.v20070208a
org.eclipse.core.filesystem.macosx_1.0.0.v20060603.jar
Open a terminal and run the server with the following:
../eclipse -clean -console
NOTE: I'm getting a couple of errors on the console at startup. Could
somone on the corona team please take a look and see if this is
something that needs to be debugged?
Once I hear that the server console output looks good, or have lots
more time, I'll try to get the client side up and running.
Bryan
Console output ...
osgi> [INFO] logReaderService: org.eclipse.equinox.log.LogReaderService@8202f4
[WARN] [2007.02.27 08:42:06 CST] [org.eclipse.corona.logger.log4j]:
CoronaLogManager is not available; log level settings won't work.
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona.logger.log4j]:
[{org.osgi.service.event.EventHandler}={event.topics=[org/ec lipse/corona/log/NEW_LOGLEVEL],
service.id=46}]: ServiceEvent REGISTERED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona.logger.log4j]: Log
service enabled...
service.id=47}]: ServiceEvent REGISTERED
[{org.eclipse.osgi.framework.console.CommandProvider}={servi ce.id=48}]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona]:
[{org.osgi.service.event.EventHandler}={event.topics=[org/ec lipse/corona/log/LOGGER_START,org/eclipse/corona/log/LOGGER_ STOP],
service.id=49}]: ServiceEvent REGISTERED
[{org.eclipse.corona.log.ICoronaLogManager}={service.id=50}] :
service.id=51}]: ServiceEvent REGISTERED
[{org.eclipse.osgi.framework.console.CommandProvider}={servi ce.id=52}]:
[{org.eclipse.corona.core.IRuntimeContextFactory}={service.i d=53}]:
[{org.eclipse.osgi.framework.console.CommandProvider}={servi ce.id=54}]:
[org.eclipse.corona.collaboration.ecf.container]:
service.id=55}]: ServiceEvent REGISTERED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona.container]:
service.id=56}]: ServiceEvent REGISTERED
[{org.eclipse.corona.container.event.IContextContainerEventA dmin}={service.id=57}]:
[{org.osgi.service.event.EventHandler}={event.topics=[org/ec lipse/corona/container/*],
service.id=58}]: ServiceEvent REGISTERED
[org.eclipse.corona.container.services]:
service.id=59}]: ServiceEvent REGISTERED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona]: Starting
bundles: [org.eclipse.equinox.event,
org.eclipse.corona.collaboration.ecf.container, org.eclipse.corona,
org.eclipse.corona.collaboration.ecf]
[ERROR] [2007.02.27 08:42:06 CST] [org.eclipse.corona]: All not
persistent start attempts didn't work for
[ERROR] [2007.02.27 08:42:06 CST] [org.eclipse.corona]: Failed to start
org.eclipse.corona.collaboration.ecf non persistently; starting
persistently
[org.eclipse.corona.collaboration.ecf]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.commonj.sdo]:
BundleEvent STARTED
[{org.eclipse.osgi.framework.console.CommandProvider}={servi ce.id=60}]:
[org.eclipse.corona.container.services]: Specified system environment
variable CORONA_CONFIG_HOME is not a directory.
[org.eclipse.corona.container.services]: Plugin preferences
CORONA_CONFIG_HOME value is not a directory. Possible bug!
[org.eclipse.corona.container.services]: CORONA_CONFIG_HOME value was
not specified. Setting default directory as corona configuration.
[{org.eclipse.corona.core.resources.IConfigurationManager}={ service.id=61}]:
[{org.eclipse.corona.container.manager.service.ContainerMana ger}={service.id=62}]:
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.common]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.ecore]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.ecore.sdo]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:06 CST] [org.eclipse.emf.ecore.xmi]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.emf.ecore.change]:
BundleEvent STARTED
context container name: System
context container uri: org.eclipse.corona.container/System
[org.eclipse.corona.container.services]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.corona.container]:
service.id=63}]: ServiceEvent REGISTERED
[{org.eclipse.corona.container.event.router.IContextContaine rEventRouter}={service.id=64}]:
[{org.eclipse.corona.collaboration.topic.ITopicManager}={ser vice.id=65}]:
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.corona.container]: Corona
Topic Manager started.
[{org.eclipse.corona.container.repository.IRepositoryAdapter Factory}={service.id=66}]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.ecf.identity]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.ecf.provider]:
BundleEvent STARTED
[org.eclipse.corona.collaboration.ecf.container]: Corona ECF server
listening on port: 3001
[org.eclipse.corona.collaboration.ecf.container]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:07 CST] [org.eclipse.corona.soa.common.axis2]:
BundleEvent STARTED
Host org.apache.axiom.api;version="1.2.0" Bundle org.apache.axiom.dom
Host org.apache.axiom.api;version="1.2.0" Bundle org.apache.axiom.impl
Host org.apache.axis2;version="1.1.0" Bundle org.apache.axis2.databinding
Host org.eclipse.core.resources;bundle-version="[3.2.0,4.0.0)" Bundle
org.eclipse.core.resources.compatibility
Host org.eclipse.equinox.registry;bundle-version="[3.2.0,3.3.0)" Bundle
org.eclipse.core.runtime.compatibility.registry
Host org.eclipse.core.filesystem;bundle-version="[1.0.0,2.0.0)" Bundle
Host org.apache.axis2;bundle-version="[1.0.0,2.0.0)" Bundle
org.eclipse.corona.axis2.sdo
Host org.apache.axis2;bundle-version="1.1.0" Bundle
org.eclipse.corona.axis2.util
Host org.eclipse.equinox.launcher;bundle-version="1.0.0" Bundle
org.eclipse.equinox.launcher.gtk.linux.x86
[INFO] [2007.02.27 08:42:08 CST]
[org.eclipse.corona.soa.provider.axis2]:
[{org.apache.muse.osgi.soa.core.SOAPProvider}={MajorVersion= 2,
Name=Axis, MinorVersion=0, service.id=67}]: ServiceEvent REGISTERED
[INFO] [2007.02.27 08:42:08 CST] [org.apache.muse.osgi.soa.axis2]:
[{org.apache.muse.core.platform.osgi.ResourceManagementProvi der}={service.id=68}]:
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.corona]: ...deploying web
service for: TeamRepository
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.corona]: Jump starting
web service extension bundle:
org.eclipse.corona.container.project.services
[org.eclipse.corona.soa.provider.axis2]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.corona.soa.client.axis2]:
[{org.eclipse.corona.soa.client.SOAPProxyProvider}={MajorVer sion=2,
Name=Axis, MinorVersion=0, service.id=69}]: ServiceEvent REGISTERED
BundleEvent STARTED
[org.eclipse.corona.container.project]:
service.id=70}]: ServiceEvent REGISTERED
[{org.eclipse.corona.container.project.event.IProjectContain erEventFactory}={service.id=71}]:
[org.eclipse.corona.container.project]: BundleEvent STARTED
[org.eclipse.corona.repository.adapter.team]: BundleEvent STARTED
[org.eclipse.corona.repository.xml.team]: BundleEvent STARTED
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.osgi]: FrameworkEvent
PACKAGES REFRESHED
[INFO] [2007.02.27 08:42:08 CST] [org.eclipse.update.configurator]:
[{org.eclipse.core.runtime.IBundleGroupProvider}={service.id =72}]:
BundleEvent STARTED
[INFO] [2007.02.27 08:42:08 CST] [org.w3c.dom]: BundleEvent STARTED
[org.eclipse.corona.container.project.services]:
service.id=73}]: ServiceEvent REGISTERED
[org.eclipse.corona.container.project.services]: BundleEvent STARTED
STARTLEVEL CHANGED
[INFO] [2007.02.27 08:42:09 CST]
[{org.eclipse.corona.container.project.repository.team.IProj ectTeamRepository}={service.name=TeamRepository,
web.context=ProjectTeamRepository, service.id=74}]: ServiceEvent
REGISTERED
[INFO] [2007.02.27 08:42:09 CST] [org.eclipse.corona]: ...deploying web
service for: ProjectContainerManager
[INFO] [2007.02.27 08:42:09 CST] [org.eclipse.corona]: web service
extension bundle already active:
[{org.eclipse.corona.core.resources.IContainerHome}={service .id=75}]:
[JAM] Warning: failed to resolve class
org.eclipse.corona.soa.common.annotations.IdempotentStrategy
[{org.eclipse.corona.container.project.manager.IProjectConta inerManager}={service.name=ProjectContainerManager,
web.context=ProjectContextContainer, service.id=76}]: ServiceEvent
REGISTERED
service for: ContextContainerManager
extension bundle already active: org.eclipse.corona.container.services
[{org.eclipse.corona.container.manager.IContextContainerMana ger}={service.name=ContextContainerManager,
web.context=ContextContainer, service.id=77}]: ServiceEvent REGISTERED
Re: Starting corona M8 on OS X - hacks and help needed [message #2243 is a reply to message #2180] Wed, 28 February 2007 04:57 Go to previous messageGo to next message
Thanks for MacOS hints. Maybe we will make an Mac OS version on this...
The log seems to be fine. All crucial plugins started, so it should
work. More comments inline.
> persistently
> [INFO] [2007.02.27 08:42:06 CST] [org.eclipse.corona.collaboration.ecf]:
> BundleEvent STARTED
Seems to be OK. For some reason it wasn't able to start it
"non-persistently", but the final info says it has been started. To
double check you can type "ss" in console and check if
org.eclipse.corona.collaboration.ecf is active.
This is fine. Means that you haven't configured Corona, but it has a
default configuration in one of the plugins and it will use it.
We have it too. We haven't yet resolved, what caused it. But it works
with it.
Marcin
Re: Starting corona M8 on OS X - hacks and help needed [message #2273 is a reply to message #2243] Wed, 28 February 2007 09:22 Go to previous message
On 2007-02-28 03:57:34 -0600, Marcin Okraszewski
>> persistently
I did the ss command and org.eclipse.corona.collaboration.ecf is
active. I'll try to get the client up and running in the next day or
two.
Bryan
Previous Topic:Thoughts on corona
Next Topic:Where is the team project set?
Current Time: Thu Jul 17 20:26:00 EDT 2025
Powered by FUDForum. Page generated in 0.04429 seconds
