Home » Modeling » GMF (Graphical Modeling Framework) » MindMap Tutorial
MindMap Tutorial [message #26038] Tue, 22 August 2006 11:50 Go to next message
Originally posted by: kpi-595h.myamail.com
I cannot manage to redo the example given on the Mindmap Tutorial and
shown at the begining of the Webinar # 3.
This is what I got when I try to create the projet from mindmap.xsd :
If somebody already came through the same error or has an idea on how to
solve this problem I would be very thankful.
!SESSION 2006-08-22 14:59:36.105
eclipse.buildId=M20060629-1905
java.version=1.4.2_09
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=fr_FR
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.emf.importer 2 0 2006-08-22 15:02:25.848
!MESSAGE
!STACK 0
org.apache.crimson.tree.ElementNode2.getAttributeNodeNS(Elem entNode2.java:432)
org.apache.crimson.tree.ElementNode2.hasAttributeNS(ElementN ode2.java:388)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEcoreAttribute(XSDE coreBuilder.java:2649)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEcoreAttribute(XSDE coreBuilder.java:2642)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEStructuralFeature( XSDEcoreBuilder.java:2424)
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:2526)
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:2487)
org.eclipse.xsd.ecore.importer.XSDImporter.doComputeEPackage s(XSDImporter.java:123)
org.eclipse.emf.importer.ModelImporter.computeEPackages(Mode lImporter.java:519)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.refreshModel(ModelImporterDetailPage.java:391)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage$3.execute(ModelImporterDetailPage.java:337)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.refreshModel(ModelImporterDetailPage.java:360)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.browseFileSystem(ModelImporterDetailPage.java:285)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rURIPage.doHandleEvent(ModelConverterURIPage.java:175)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.doHandleEvent(ModelImporterDetailPage.java:175)
org.eclipse.xsd.ecore.importer.ui.XSDDetailPage.doHandleEven t(XSDDetailPage.java:92)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPage.handleEvent(ModelConverterPage.java:135)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3164)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2840)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:116)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: MindMap Tutorial [message #26163 is a reply to message #26038] Tue, 22 August 2006 12:25 Go to previous messageGo to next message
--------------060708020204090909010800
Corentin,
This is the ever popular "Crimson DOM" problem. Follow these
instructions to work around it:
http://www.eclipse.org/emf/downloads-xerces.php
Or use a JDK that doesn't have this problem; only the Sun JDK 1.4.x has
this problem.
> to solve this problem I would be very thankful.
> !MESSAGE !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
<html>
<head>
http-equiv="Content-Type">
</head>
Corentin,<br>
<br>
Re: MindMap Tutorial [message #26440 is a reply to message #26163] Tue, 22 August 2006 19:51 Go to previous message
------=_NextPart_000_0016_01C6C60B.3423F730
charset="iso-8859-15"
Or start from mindmap.ecore, eventually I got it to work from this. ;-)
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:ecfb35$97p$2@utils.eclipse.org...
Corentin,
This is the ever popular "Crimson DOM" problem. Follow these =
Or use a JDK that doesn't have this problem; only the Sun JDK 1.4.x =
has this problem.
Corentin M. wrote:=20
I cannot manage to redo the example given on the Mindmap Tutorial =
and shown at the begining of the Webinar # 3.=20
This is what I got when I try to create the projet from mindmap.xsd =
:=20
If somebody already came through the same error or has an idea on =
how to solve this problem I would be very thankful.=20
!SESSION 2006-08-22 14:59:36.105 =
-----------------------------------------------=20
eclipse.buildId=3DM20060629-1905=20
java.version=3D1.4.2_09=20
java.vendor=3DSun Microsystems Inc.=20
BootLoader constants: OS=3Dlinux, ARCH=3Dx86, WS=3Dgtk, NL=3Dfr_FR=20
Command-line arguments: -os linux -ws gtk -arch x86=20
!ENTRY org.eclipse.emf.importer 2 0 2006-08-22 15:02:25.848=20
!MESSAGE !STACK 0=20
java.lang.NullPointerException=20
at =
org.apache.crimson.tree.ElementNode2.getAttributeNodeNS(Elem entNode2.java=
:432)=20
at =
org.apache.crimson.tree.ElementNode2.hasAttributeNS(ElementN ode2.java:388=
)=20
at =
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEcoreAttribute(XSDE coreBuilder.j=
ava:2649)=20
at =
ava:2642)=20
at =
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEStructuralFeature( XSDEcoreBuild=
er.java:2424)=20
at =
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:2526)=
=20
at =
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:2487)=
=20
at =
org.eclipse.xsd.ecore.importer.XSDImporter.doComputeEPackage s(XSDImporter=
..java:123)=20
at =
org.eclipse.emf.importer.ModelImporter.computeEPackages(Mode lImporter.jav=
a:519)=20
at =
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.ref=
reshModel(ModelImporterDetailPage.java:391)=20
at =
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage$3.e=
xecute(ModelImporterDetailPage.java:337)=20
at =
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOper=
ation.java:101)=20
at =
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)=20
at =
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperat=
ion.java:113)=20
at =
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.=
java:369)=20
at =
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)=20
at =
org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)=20
at =
reshModel(ModelImporterDetailPage.java:360)=20
at =
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.bro=
wseFileSystem(ModelImporterDetailPage.java:285)=20
at =
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rURIPage.doHa=
ndleEvent(ModelConverterURIPage.java:175)=20
at =
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.doH=
andleEvent(ModelImporterDetailPage.java:175)=20
at =
org.eclipse.xsd.ecore.importer.ui.XSDDetailPage.doHandleEven t(XSDDetailPa=
ge.java:92)=20
at =
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPage.handleE=
vent(ModelConverterPage.java:135)=20
at =
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)=20
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)=2 0
at =
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3164)=20
at =
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2840)=20
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 ) =
at org.eclipse.jface.window.Window.open(Window.java:796)=20
at =
org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:116)=20
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 ) =
at =
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Act=
ionContributionItem.java:539)=20
at =
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributi=
onItem.java:488)=20
at =
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContr=
ibutionItem.java:400)=20
at =
at =
at =
at =
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)=20
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878) =20
at =
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:41=
9)=20
at =
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)=20
at =
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)=20
at =
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivat=
or.java:78)=20
at =
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicati=
on(EclipseAppLauncher.java:92)=20
at =
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips=
eAppLauncher.java:68)=20
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:4=
00)=20
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
77)=20
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)=20
at =
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java=
:39)=20
at =
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorI=
mpl.java:25)=20
at java.lang.reflect.Method.invoke(Method.java:324)=20
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 ) =
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)=20
at org.eclipse.core.launcher.Main.run(Main.java:977)=20
at org.eclipse.core.launcher.Main.main(Main.java:952)=20
<HTML><HEAD>
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Or start from mindmap.ecore, eventually =
I got it to=20
work from this.&nbsp; ;-)</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:ecfb35$97p$2@utils.eclipse.org">news:ecfb35$97p$2@utils.ecli=
pse.org</A>...</DIV>Corentin,<BR><BR>This=20
is the ever popular "Crimson DOM" problem.&nbsp;&nbsp; Follow these=20
instructions to work around it:<BR>
<BLOCKQUOTE>&nbsp;<A=20
href=3D"http://www.eclipse.org/emf/downloads-xerces.php">http://www.eclip=
se.org/emf/downloads-xerces.php</A><BR></BLOCKQUOTE>Or=20
use a JDK that doesn't have this problem; only the Sun JDK 1.4.x has =
this=20
problem.<BR><BR><BR>Corentin M. wrote:=20
<BLOCKQUOTE =
cite=3Dmid2ec11bdc3b4165c3a79cbabf81e4b17e$1@www.eclipse.org=20
type=3D"cite">I cannot manage to redo the example given on the Mindmap =
Tutorial and shown at the begining of the Webinar # 3. <BR><BR>This =
is what=20
I got when I try to create the projet from mindmap.xsd : <BR>If =
somebody=20
already came through the same error or has an idea on how to solve =
this=20
problem I would be very thankful. <BR><BR><BR>!SESSION 2006-08-22=20
14:59:36.105 -----------------------------------------------=20
<BR>eclipse.buildId=3DM20060629-1905 <BR>java.version=3D1.4.2_09=20
<BR>java.vendor=3DSun Microsystems Inc. <BR>BootLoader constants: =
OS=3Dlinux,=20
ARCH=3Dx86, WS=3Dgtk, NL=3Dfr_FR <BR>Command-line arguments:&nbsp; =
-os linux -ws=20
gtk -arch x86 <BR><BR>!ENTRY org.eclipse.emf.importer 2 0 2006-08-22 =
15:02:25.848 <BR>!MESSAGE !STACK 0 =
<BR>java.lang.NullPointerException=20
<BR>&nbsp;&nbsp;&nbsp;&nbsp;at=20
:432)=20
)=20
ava:2649)=20
ava:2642)=20
er.java:2424)=20
=20
=20
..java:123)=20
a:519)=20
ation.java:101)=20
ion.java:113)=20
java:369)=20
ge.java:92)=20
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3164) =
org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )=20
org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )=20
onItem.java:488)=20
9)=20
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149) =
or.java:78)=20
00)=20
77)=20
:39)=20
mpl.java:25)=20
org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )=20
<BR><BR><BR></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML >
------=_NextPart_000_0016_01C6C60B.3423F730--
Previous Topic:Setting dirty flag
Next Topic:Drag and Drop from Explorer
Current Time: Sat Jul 26 09:11:43 EDT 2025
Powered by FUDForum. Page generated in 0.03741 seconds
