Home » Archived » BIRT » Birt in a java application
Birt in a java application [message #263002] Mon, 10 December 2007 09:13 Go to next message
Originally posted by: jochen800.gmx.de
I have to use BIRT for a java application. I have started reading
tutorials about BIRT and I am overwhelmed by the huge functionality. Also
I am lost because of the functionality. I try to figure out the basic
steps for a BIRT report in a application and I hope you can help with this.
My data is in a sql database and I want to get access the data via
hibernate and hsqldb. For the beginning the data in the database is really
simple. It is just a table with number which I want to sort via BIRT. Can
I do this with the report api?
The output should be a html file or pdf. It does'nt really matter.
What are the steps I have to do?
Thank you
Re: Birt in a java application [message #263013 is a reply to message #263002] Mon, 10 December 2007 15:20 Go to previous messageGo to next message
Originally posted by: johnw.innoventsolutions.com
jochen: Jason had written an article some time back for BIRT 1, but it
should still work in the BIRT 2.0 series.
http://www.eclipsezone.com/eclipse/forums/t65535.html
Look in there for an atachement from him.
John
jochen wrote:
> Hello,
> Also I am lost because of the functionality. I try to figure out the
> basic steps for a BIRT report in a application and I hope you can help
> with this.
> really simple. It is just a table with number which I want to sort via
> BIRT. Can I do this with the report api?
> Thank you
Re: Birt in a java application [message #263114 is a reply to message #263013] Wed, 12 December 2007 04:32 Go to previous message
Hey,
thanks for the link. it helped a lot.
jochen
Previous Topic:Importing java objects into report
Next Topic:Saving an HTML report for later web viewing
Current Time: Thu Jul 17 21:49:31 EDT 2025
Powered by FUDForum. Page generated in 0.48259 seconds
