Home » Eclipse Projects » DSDP - Target Management » RSE server packaging
RSE server packaging [message #26024] Thu, 21 August 2008 16:03 Go to next message
I'm working on a Eclipse Tracing prototype for Ericsson's CPP platform and
am evaluating the use of RSE for this task. I have a few questions.
1) How are the rse-3.0-xxxxx.tar archives from the DSDP-TM downloads page
created? I saw that you can do Create JAR by right-clicking on a .jardesc
file in the project, is this how you do it? But is there an automatic way
to package all the .jar files and scripts corresponding to the target
platform in an archive, or is it done manually (Export -> Archive File?)
or with an external script not part of the project files?
2) Is there any difference in the contents of the .jar files or in build
options depending on the target platform? I'm assuming not since I saw for
example all 5 implementations of UniversalXxxxxProcessHandler.class in the
Linux archive's jar files.
3) Some of our CPP nodes only have Java 1.3.1 installed. I saw that there
is a hard requirement for Java 1.4 when launching the server, but by
changing the Executing Environment of the JRE System Library to J2SE-1.3
in the RSE server projects' Java Build Path, I found that the only
incompatibilities occur when the DataStore is using SSL, and in the
document/xml handling of the SystemMessageFile. Do you think that an
'amputated' RSE server could be viable without those two things, in case
Java 1.3.1 in the server side becomes a requirement for our prototype?
Thank you,
Patrick
Re: RSE server (dstore) packaging [message #26068 is a reply to message #26024] Fri, 22 August 2008 06:51 Go to previous messageGo to next message
Hello Patrick,
these questions are dstore specific, others might be more
knowledgeable here than I am, but here's the releng related
answes:
* We build the rseserver-*.tar archives as part of our
nightly releaese engineering process, see the
org.eclipse.rse.build project (shortly to be replaced
by org.eclipse.tm.build)
* Right, the JARs are the same in all server packages,
only the *.sh / *.pl / *.bat scripts differ
* I'd think that "Create Jar" should work to replace
a pre-buildt jar by something from your workspace,
but I can't say for sure -- forwarding to the Developer
Mailing list for comments
* Downgrading to require only Java 1.3 on the server
seems a good idea to me, but I do not know if it is
technically viable - Dave?
Did you consider TCF or SSH on the server side? Why do
you think you'd want dstore?
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> and am evaluating the use of RSE for this task. I have a few questions.
> page created? I saw that you can do Create JAR by right-clicking on a
> .jardesc file in the project, is this how you do it? But is there an
> automatic way to package all the .jar files and scripts corresponding to
> the target platform in an archive, or is it done manually (Export ->
> Archive File?) or with an external script not part of the project files?
> for example all 5 implementations of UniversalXxxxxProcessHandler.class
> in the Linux archive's jar files.
> there is a hard requirement for Java 1.4 when launching the server, but
> by changing the Executing Environment of the JRE System Library to
> J2SE-1.3 in the RSE server projects' Java Build Path, I found that the
> only incompatibilities occur when the DataStore is using SSL, and in the
> Thank you,
> Patrick
Re: RSE server (dstore) packaging [message #576702 is a reply to message #26024] Fri, 22 August 2008 06:51 Go to previous messageGo to next message
Hello Patrick,
answes:
> Thank you,
> Patrick
Re: RSE server (dstore) packaging [message #652404 is a reply to message #576702] Thu, 03 February 2011 13:37 Go to previous message
Does anyone know if Patrick ever built the JAVA 1.3.1 verson of dstore?
Previous Topic:RSE server packaging
Next Topic:cvs on top of rse
Current Time: Tue Jul 22 14:00:02 EDT 2025
Powered by FUDForum. Page generated in 0.05474 seconds
